Question about RCA P52939 52" Rear Projection Television
Rca picture concave 52 in rear projection
I have a 52 in. rear projection rca tv
when i turn on the tv picture is ok but after few mins the picture goes concave
plz help me fix this problem thanks
  • 77 Answers
Sounds like your color guns are out of alignment and need adjusting. its a cheap fix with a tv tech but i wouldnt recommend doing it yourself. plus, a visit from a tech can tell you if there is anything else wrong/about to b wrong
Posted on Oct 21, 2008
I was given a P52960 ,2002 rca 52 projection tv and the sides of the piture are concaved in.Can this be fixed easy enough,i am good with electronics/wireing..iI was told by the old owner that the solu
concave or bloated pictures on crt projection tv's are corrected with what's called a 'pincushion' adjustment. Look for it in the menu under video controls.
Dec 22, 2012 | RCA P52960 52" Rear Projection Television
I have an RCA 52" projection Tv, After it has been on for about 30-40 Mins the picture Goes concave.
Replace the deflection board. You can get a replacement board from www.tvrepairworld.com which also contains the Cd with installation instructions.
Jan 13, 2010 | RCA D52W19 52" Rear Projection Television
Concave picture
the convergence power supply module has failed
if you go into the menu you will not find convergence adjustments in the menu
the power supply module can be repaired
or you may want to get local help
if you want to try to repair you can get parts at mcm or encompas or tvrepairworld.com
Oct 26, 2009 | RCA P52937 52" Rear Projection Television
52" rca rear projection
the picture is bent inward and shadow looking sides are cut off.
Aug 10, 2009 | RCA D52130 52" Rear Projection Television
Screen has double images on both sides, picture looks concaved. tv goes back and forth in this mode from normal to concaved
IC chips are Failing, and or A few Resistors in the Convergence circuit. Commen problem for Projection sets!... OneGeo.
Jul 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA projection TV - the picture only shows red green and yellow and the picture is distorted almost concaved. It overlaps and nothing is clear. All 3 bulbs seem to be working. No idea what is wrong.
Sounds like convergence problems. This TV may not have the standard "STK.." modules. These sets are bad to lose voltage feeding the convergence amplifiers.
Mar 31, 2009 | RCA P52926 52" Rear Projection Television
RCA 52" projection tv convergence problems,can i fix it?i try auto convergence? the model is P52920BL and is a 1998 i try the green centering blue & red convergence in the setup of the tv,and it goes back...
My RCA 52 rear projection TV has the letters getting blurry on top and bottom, Picture is OK but visually losing my eyesight staring at blurry numbers and letters.
Is this a bulb or simple fix ??
Mar 28, 2009 | RCA P52920BL 52" Rear Projection...
Loosing picture
ironically i working on the exact tv with the same issue here at the shop. we have determined it to be bad crt and crt board 345 dollars for part 150 for labor
Mar 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Covergence problem
your set has indications of several problems. red green and blue. indcate convegence issue. the fact that the picture is concave is a indication of totall loss of covergence power supply. the convegence menu missing idicate loss of some voltages from what know as the flyback.AND SHUTDOWN. indicate further problems. generally when convergence fails ..not always the set wont shut down. it could be a simple issue but further trobleshooting would have to occur to narrow it down.
Feb 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
My RCA Tv has a concave picture!!!
Convergence problems. FIrst try going into customer setup and seeing if convergence options are there and if adjustments can be made. unfortunately when the picture is bowed like that it idicates a complete loss of convergence which idicates one of three boards have gone bad.
Dec 21, 2007 | RCA HD52W56 52" Rear Projection HDTV
RCA P52939 52" Rear Projection Television Logo
373 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
