Question about Creative Labs Zen V MP3 Player
My creative zen 4gb player,when switched on the screen appears to be white
When i switched on my player the screen appears to be white always.Then i have to reset for each and every time.MY players name is creative zen.Pls help me!
    Scholar:
  • 64 Answers
If this doesn’t work then I would send it back under the warranty.....Because this is not normal...but you probably know that....I will post a link to creative website that will give you 2 different ways to reset you Zen V MP3 player....
http://support.creative.com/kb/ShowArticle.aspx?sid=9770 &
http://support.creative.com/kb/ShowArticle.aspx?url=http://203.211.142.197:80/srvs/cgi-bin/webcgi.exe/,/?st=357,e=0000000000342903798,k=6058,sxi=1,varset=ws:http://us.creative.com,case=4794
From what I got from Creative Labs this is a common problem so Good luck and let me know if this helped ….
cbinny1
Posted on Oct 21, 2008
  • 94 Answers
If you need to reset your device everytime you turn it on, it might be a firmware problem or device problem. You may want to try reloading or upgrading the firmware of your player. However, there are risk when you perform the upgrade. It might not work completely if it is not properly done.
For specific firmware upgrade instructions, please refer to the firmware released posted at http://creative.com/products/mp3 or follow the instructions on the screen.
Hope it helps!
Firmware Update problem.(Failed) hi i have Creative Zen 4GB Mp3 player. When i plug it via USB on my PC i can't upgrade frimware.İt always run in recovery mode.i start firmware upgrade and...
When i plug it via USB on my PC i can't upgrade frimware.İt always run in recovery mode.i start firmware upgrade and installer says "firmware upgrade failed.".Media explorer says Storage Media is 50 mb.Please help i don't know anything to repair it...
Feb 21, 2010 | Creative Labs Zen Digital Media Player
Service center for creative mp3 in kerala?
I had the same problem....ok here's what you do, make sure the ZEN is off first then switch it on my pushing the switch down (like usual).So switch it on and press the play/pause button at the same time. It may take a couple of tries but after you get it, the screen will say "Recovery Mode" at the top. Now go down to "Clean Up" and click it. It will then ask, "Disk cleanup will be performed. Continue?" Click yes. When it's done, turn off the ZEN and turn it back on. Does it work!? Ha I'm a 13 year old genius.
Jan 14, 2010 | Creative Labs Zen Digital Media Player
Only white screen appears while starting.
My Creative Zen 16Gb got to the stage where every time I turned it on I would get a white screen. I tried many so called solutions, including those on the Creative website - nothing really workd for any length of time. Eventually, suspecting is was a connection issue with the dispaly, I held the Zen in both hands and twisted the case a few times - nothing broke and my Zen has been working faultlessy for the last three days. Hope this helps.
Nov 17, 2009 | Audio Players & Recorders
Blank screen and switches off when plug in headphones
I found someone that fixing the and he does a good job. Here is is web page address http://firehouse7777.weebly.com/. I hope this helps
Aug 27, 2009 | Creative Labs ZEN Vision:M Digital Media...
I did not use my Zen MP3 4GB player for several months. On attempting to re-start it, I was unable to get anything except a blank -although lit - display screen. The player has been charged for many hours,...
try to drain the charge of the battery. the try to recharge it. most white screen issue of creative zen is due to power surge specially when it's connected to a usb port.
Aug 16, 2009 | Creative Labs Zen V MP3 Player
White screen
I get the white screen of death as well from time to time and I found this video and it actually worked for me.
Hope you have the same problem as me and this should help out just do what he does:
When the screen goes white, let the music play, put it on hold, wait until the screen turns black then take it off hold and the screen should be back on hope this helps.
http://www.youtube.com/watch?v=a8g0sh7pc54
Jun 07, 2009 | Creative Labs Zen Digital Media Player
Zen screen stays white
The white screen of death is due to a hardware failure in the LCD screen and the only way to fix it is to replace the screen itself. You can find a screen and repair services at www.TheGadgetDr.com
Aug 13, 2008 | Creative Labs Zen Digital Media Player
My Creative Zen 4GB MP3 Player is just not turning On
I had the exact same issue and this is how i fixed it.
go to the zen website and download the latest drivers.
  1. Turn off your player.
  2. Disconnect your player from your computer.
  3. Press and hold the Play/Pause button. Continue to hold the button while you perform steps 4 and 5. If you accidentally release the button, start the procedure again.
  4. Gently push a straightened paper clip into the Reset hole.
  5. Slide the On/Off switch towards the USB port and hold until the display lights up. The Recovery Mode screen appears with four options: Clean Up, Format All, Reload Firmware, and Reboot.
  6. Select Reload Firmware, followed by Yes.
  7. Connect your player to your computer.
  8. Double-click the downloaded file and follow the instructions on the screen.
May 31, 2008 | Creative Labs Zen Micro MP3 Player
Creative Zen vplus 4gb Stuck on start up screen that says "ZEN vplus"; it will not shut down once on, unless using the reset button
see recovery mode info here:
http://www.anythingbutipod.com/forum/showthread.php?t=6714
(thank you)
holding play button while powering up, then running Clean Up & rebooting did the trick.
Mar 14, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative Labs Zen V MP3 Player Logo
71 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
