Question about Whirlpool Washing Machines
I loaded the Whirlpool Top Loader AGW 032 this morning with 2 towels and a heavy dressing gown. It made aweful noises during wash, then cut out. I am unable to open top because it hasn't finihed its programme. The water needs to be drained, but it just keeps cutting out. How can I get the clothes out please? Does the problem seem serious? I would be grateful for some assistabce.Many thanks. Mary Scott
SOURCE: washing machine not spinning or draining water
I have the same washer, WT-R801. Does the machine stop all together when the spin cycle arrives?, if so check the pump on the drain. Mine was burnt out. Its available for $61.00 delivered from Adelaide. Steve.
Posted on Mar 31, 2008
SOURCE: hoover 600mb 6.0 kg top load washing machine (not as below)
Machine unbalanced or belt is worn maybe
Posted on Apr 04, 2008
ngfam1
  • 639 Answers
SOURCE: kitchen aid top loader washing machine does not spin
Peace Friend,
ngfam1 At your service!
Sounds like a belt problem!
Or the linkage connecting the transmission to the agitator.
Or the WORST THE TRANSMISSION IS GOING!
If the appliance is 10 years old or more you may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
Posted on Aug 31, 2008
mark_37388
  • 100 Answers
SOURCE: spin cycle not working,
sounds like you have a broken motor coupling between the motor and transmission
Posted on Mar 30, 2009
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
Tip
Purchased my Whirlpool front loader 4/2004, we are on our 7th bellow, new inner...
This advice is for the Kenmore Elite and Whirlpool Duet FRONT LOADER style washing machines. A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn’t cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
I hope you find these instructions helpful and good luck to you.
on Feb 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool wtw4950xw2 top loader washing machine sounds like a jet taking off during spin cycle ... How can I fix it ?
You can unbalance the load more to get a quieter spin, but otherwise you may have a worn out gear system that produces more noise than the spinning tub itself. Check with service to determine the exact cause of the noise.
Feb 01, 2015 | Whirlpool WTW4950XW Top Load Washers
Kenmore Elite Oasis HT makes loud noises during spin cycle.
The tub may be unbalanced and wobbling. This may be due to washing heavy items such as rugs, towels, etc. If it is noisy with regular laundry loads, the mechanism that supports the tub may be loose or broken.
Sep 10, 2012 | Kenmore Oasis Agitator 4.5 cu. ft....
Spin vefy fast
A rapid spin cycle is actually a GOOD thing. This is an indication that the gearcase (transmission) and the drive motor are both running strong.
If the washer shudders during the spin cycle the first thing you need to do is check to ensure the washer is properly leveled. The following link explains:
http://www.fixya.com/support/r3868923-level_whirlpool_top_loading_washer
The model Whirlpool top loader you have, has an auto-leveler mechanism on the back two legs that can become unlevel periodicailly. You should check the washer level from time to time when it is empty. You need to also make sure the washer is level in ALL directions (front-to-back and side-to-side).
Accidental unbalance problems that can occur from washing blankets, comforters, or heavy loads of towels can also cause the washer to become unlevel and shake. This can also contribute to the level mechanism becoming unbalanced.
Overloading the washer can also cause unbalance problems. Washing blankets or conforters can cause the load weight to shift to one side of the tub. This will result in a tub that shakes violently and bangs against the cabinet. You may have to redistribute the load weight when washing heavy items. This can also occur when washing loads of towels. This is NORMAL as some heavy items do not distribute the weight evenly.
Another problem (which is less common) that can contribute to wash unbalance problems is a weak floor under the washer. If the floor flexes (even the slightest) during the spin cycle, it can cause the washer to bounce or shake. Mobile homes or laundry rooms on the second floor of a home are notorious for having weaker floor structures. This washer has a 35 gallon tub capacity. Coupled with the weight of a wet load and the spinning action, this can put a lot of centrifugal force on a floor.
If you have any questions or concerns, please post back and let me know. I hope this information is helpful to you.
Apr 25, 2010 | Whirlpool LSR5132PQ Top Load Washer
HELP
ww.repairclinic.com/RepairHelp/RepairHelp.aspx
www.acmehowto.com/howto/appliance/washer/washer.php
home.howstuffworks.com/how-to-repair-a-washing-machine.htm
http://www.managemyhome.com/mmh/Troubleshooting_Guides/TopLoadWasher.pdf
Nov 16, 2009 | Washing Machines
Kenmore Elite Oasis 110.2706 Top Loader Grinding Noise
If you remove the back panel, there are two pumps towards ethier side at the botom of the tub. If you remove the back hoses (have some towels ready) You may find something in one of the two pumps.
Jun 13, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Dec 29, 2007 | Whirlpool LHW0050PQ Front Load Washer
My old Hoover top loader Washer is noisy & doesn't spin out properly - how can I fix it?
Sounds like the switch which cuts the machine off when the load is unbalanced. My guess is that: This switch is being triggered too easily The springs holding the bowl up are either stretched or one is broken; The machine may not be level.
Mar 30, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
