Question about Fuji FinePix Z3 Digital Camera
Getting a zoom Error message!!!
Everytime I turn on my Camera it starts to make a beeping sound and then I'll get the "Zoom Error" message on the screen. I am not able to take pictures. The only thing it lets me do is view the pictures I have already taken.
Does anyone know how to fix this problem or how it could have happened?!
Thanks everyone.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 27, 2010
The zoom browser does not recognise the camera is connected to PC
Windows updates change the registry. Sometimes this means our connected equipment no longer works. Now it is time for you to start using a separate card reader.
May 17, 2010 | Canon IXUS 80 IS Digital Camera
Camera beeps and turns off and lens won't retract
Lens error / Battery expire.
1. Use a new battery will fully charged and then use it. Hope you get good result.
2. Some time lens zooming gear getting damaged by dust. if that gear is scrached by dust then your lens can't work and it will stucked. Your camera automatically turn off.
Of those 2 85% chance of poor/ long time used Battery & 15% chance of lens zooming gear damaged.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | Cameras
My camera has a message saying 'zoom error' when I press the on button- what should I do?
Well, my camera said the same thing and when i tried to zoom in or out it would zoom out but then it would zoom out all on its own and beep. So i zoomed in but grabbed the lens so it could not zoom back out on its own. Now my camera is fine. Actually believe it or not I literally fixed my camera 2 minutes ago and I found your question because I was trying to find an answer to mine. So, it worked for me haha
Jul 12, 2009 | Fuji FinePix A900 Digital Camera
Won't take pictures when zoom
Most common problem in al the digital camera's. Slide motor start malfunction and the massage appears"Turn off the power and on again". In this situation you have to replace slide motor or lens block assembly, And your camera work fine again.
Thanks for using fixya.
Jun 27, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
My camera sony smart zoom dsc-p43. everytime i
Hi there
First of all check to make sure the cards write protect is off, take the card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg .
Pop it back in the camera and try to format the card again, if you get the same error message again there could be a chance the card is damaged.
Good luck and thanks for choosing FixYa!!
Jun 08, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Lens keeps getting stuck/needs a good tug to zoom past 25 HELP!
Hi Rachael_amor, If the lens will not zoom on the camera will it off the camera? If not then it has some grit, dirt, and the like in the lens. You could attempt to vacuum around the zoom however, I suspect it will need to go in to Nikon. That lens is not well weather sealed, it is a inexpensive consumer lens.
Jun 02, 2009 | Nikon D80 Digital Camera with 18-55mm Lens
Zoom Error
i have a duji f20 le zoom lens partly out when turn on says zoom error can you solve this please
Feb 22, 2008 | Fuji FinePix F20 Digital Camera
Zoom error message on fujifilm a350 digital camera
whilst reading out loud instruction to fix the 'zoom error' my wife turned and twisted the zoom lens clockwise and shake th camera gently - all of a certain it worked again as per normal - try it - hope it works for you too!
Feb 17, 2008 | Fuji FinePix A350 Digital Camera
System error
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Listed Fix #4 might work for you. Place the camera on its back, and hold the shutter button down while powering on the camera.
Dec 21, 2007 | Nikon Coolpix 3200 Digital Camera
Fuji FinePix Z3 Digital Camera Logo
48 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
