Question about Neumann M-149 Professional Microphone
I have problems with my m149 neumann
In one moment it loos the contact and is makeing a distortion
  • 1,512 Answers
Hi wirus
This mic is worth more than $4,500 to purchase. I strongly recommend that you refer it to a Neumann service agent(with power supply) to have it checked out. There are no user serviceable parts inside the mic, and cleaning should only be serviced by qualified and trained personnal. I expect that you have already checked leads and so on.
Go to this site, for a service agency in your part of the world. Good luck with sorting out the drama. Hope you get back to recording real soon :)
regards
robotek
Posted on Oct 31, 2008
Neumann TLM mic is inoperative when connected to PA with same cable that worked with Shure SM 58 mic
The Shure SM58 is a dynamic microphone instead of the electret one Neumann TLM 103. This means that Shure does not need a phantom power supply voltage, instead of Neumann TLM 103; this one needs 48Volts. Here are the specifications for each one of the microphones: Shure SM 58 - Neumann TLM 103. In case you use a pre-amplifier or an audio console try to locate a switch marked as "Phantom Power" and turn it on. Typically there is no problem supplying a phantom power at the SM58. In case you have no phantom power switch available, either post back the mixer brand / model to check it for you, or post me a question to suggest you one. Details about the usage and the mixer you are already using will help me to clarify the total audio situation.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Jan 27, 2011 | Neumann TLM 103 Professional Microphone
Dear All, We use a 12-years old Neumann U87Ai for male voiceovers, with no problems. Recently we experience some slight but annoying distortion, especially when recording loud male voice with lots of...
Usually the distortion is from over gain on the preamp or the spl of the actual voice on the diaphragm have him step back a few steps and try again.
Good Luck, Cody J.
Dec 16, 2010 | Neumann U87 AI-SET Microphone
MY NEUMANN TLM193 IS CUTTING OUT. WHAT IS THE PROBLEM?
I would advise you not to try repairing this yourself, but to locate the person in your area who specializes in repairing these mics. It may not be cheap, but I presume you bought this mic based on its performance. No other service person can restore this mic to its original condition. Bite the bullet and do it. Otherwise, it will sit on the shelf and be useless to you.
Oct 06, 2010 | Neumann TLM193 Professional Microphone
What resistor do I replace when changing transistors on u-87? Mic has low output now. I replaced the old SK 103 transistor for a 2n3819 transistor from neumann and it came w/ a resistor for matching but no...
Try contacting them through this link and ask to speak to a tech. Write or email them if you have to:http://www.neumann.com/?id=service_servicepoints&lang=en
Oct 19, 2009 | Neumann U87 Professional Microphone
Frequency responce for km130
http://www.neumann.com/?lang=en&id=current_microphones&cid=km100_publications
Jan 21, 2009 | Neumann KM130 Professional Microphone
Neumann U87 is distorting and cutting out
As condenser microphones 'mature' they may accumulate contaminants on their diaphragms, which in turn provide a relatively low impedance bypass for the bias voltage. To check if your microphone may suffer from this effect, hold it close to your mouth and breathe (heavily) a few times on the head. The moisture from your breath will condense , and if there the capsule is compromised by contaminants, or if it has developed other flaws, you will hear an increase in frying sound and/or complete loss of output.
Sometimes the capsule can be cleaned, thus extending its useful lifespan. At the risk of causing irreparable harm to the heart and soul of the microphone, this procedure should not be attempted by an inexperienced specialist! If in doubt, sens the microphone to the Neumann Service Department in Old Lyme, CT or another qualified specialist.
Uwe Sattler,
Technical Director - SEC
May 25, 2008 | Audio Players & Recorders
Buzzing
I suggest you start taking care of more isles than just isle four and maybe then someone will want to help you out.
Sep 12, 2007 | Neumann TLM193 Professional Microphone
Neumann M-149 Professional Microphone Logo
181 people viewed this question
Top Neumann Audio Players & Recorders Experts
Michial Gueffroy
Don Hart
drivealot
Are you a Neumann Audio Player and Recorder Expert? Answer questions, earn points and help others
