SOURCE: rca rt2360
Possible short in output amplifier darlington transistors. Check cable connections first, but if that doesn't help, it is likely a amplifier problem
SOURCE: rca rt2600 OVERLOAD PROBLEM
Your receiver has blown out you need to buy a NEW Receiver and sub-woofer (the sub isnt compatable with better receivers)
SOURCE: RCA RTD258 Not working
I had a similar problem with my unit. It Worked fine for about 4-6 months with a slight problem of a loud hum of the cooling fan during the first 5 initial minutes upon turning it on.
However yesterday it all of sudden stopped working, it remained on, because you could hear the fan, but nothing else. I could not even turn it off, unless completely unplugging. I finally decided to open the unit up and unscrewed the top part. Apperantly some of the fuzes' covers (plastic) had starting melting down due to the heat, or improper ventilation, and that black molten plastic goop got in the way of the connections. I cleaned up as much as I could, and after that it seemed to be working fine...
This is not a bad unit, and has a great potential, too bad that the interior was so cheaply designed that its durability is obsviously meant to be of a short life span...
SOURCE: rca rt2600 no sound, if you switch on the power
One of the audio output amplifier ics are toast the faulty one will need to be desoldered from the board and replaced, they run at about $10 each normaly. The faulty one will generaly be quite burnt.
SOURCE: I have an RCA RT2500 audio-video surround sound
Hold down the power button and unplug the unit. Now release the power button. Plug the unit back into the wall. Now press the button. The system should power up.
