Question about HP PSC 2355 All-In-One InkJet Printer
Printer problem When I turn on our all in one printer it immediately says "scanner failure". How do I clear it and what is the problem? Is it necessary to be connected to a computer? Our printer is not currently connected to the computer and worked okay for a couple of months.
    Novelist:
    Scholar:
  • 167 Answers
There is some problem with your integraed scanner in office all in one. But your printer should work fine.
But you may not be able to sned or receive faxes as it needs the scanner to be functional.
If you can lubricate the rails of the scanner assembly, it become moving again.
Otherwise get it serviced.
Posted on Oct 19, 2007
Scanner failure 30,0146 hp 6040
"I know I'm a biot late to the party here but I just worked on an M3027 with that same error. It turned out to be the scanner head lock was in the locked state. Tried unlocking with the machine still on which didn't clear the error but after a power-cycle with the head unlocked the error was cleared. Nice simple and free solution!" Read more here: error 30 01 34 scanner failure
Mar 27, 2016 | HP Office Equipment & Supplies
Canon scanner why does the green light flash after diagnostics?
SOLVED] Canon FS2710 failure on Windows XP pro - Tech Support Forum
www.techsupportforum.com > ... > Hardware Support > Printer Support
Jan 6, 2010 - 6 posts - ‎1 author When I looked into getting a negative scanner I looked specifically for one ... Well as it turns out my Canon Canoscan FS 2710 is not compatible ...
Jul 26, 2015 | Canon CanoScan FS2710 Film Scanner
How do I solve the "scanner failure power off and on again" message for an h.p. 6110 officjet all-in-one printer/scanner/fax?
Hi Paul,
Scanner Failure usually results in Hardware Failure. However there is one step you can try. Try connecting the printer directly to wall outlet or any other power outlet and the issue should be resolved.
Regards,
Sean
Apr 19, 2013 | HP OfficeJet 6110 All-In-One InkJet...
Lexmark T642 When printing, LCD displays
this error is a scanner lost lock error and can be caused by the scanner or the logic board. if this error comes up immediately on power up the scanner motor is not initializing by percentages of failure the scanner is approximately 85% the logic board 15% i would change the scanner
Nov 23, 2009 | Lexmark T642 Laser Printer
Lexmark x2500
There 3 light on the printer that able to indicate to user when problem occur. Find your printer error accordingly as below and may solve your printer problem.
1st button light blink rapidly = the printer may be out of paper, so load more paper and press the 1st button itself to continue. Or may be paper jam is occur, so clear the paper jam and press the 1st button light itself to continue.
If 1st button light blink slowly = mean the cartridge carriers are stuck, so raise the scanner unit and remove any object blocking the path of the cartridge carrier, make sure the cartridge are closed and installed properly, then lift the scanner unit, gently push the scanner support towards the cartridge carriers, and carefully lower the scanner unit until it is completely closed. After that press the 1st button itself to continue.
If 2nd LED light blinking = the color cartridge need to be replaced soon.
If 2nd LED light is ON = the color cartridge need to be replaced immediately.
If 3rd LED light blinking = the black cartridge need to be replaced soon.
If 3rd LED light is ON = the black cartridge need to be replaced immediately.
Hope this help.
YBC (/\)
Feb 05, 2009 | Lexmark X2500 All-In-One Printer
Scanner failure
After turning on the printer, I am getting a message stating "scanner failure" turn off printer. Can't do anything else.
Aug 14, 2008 | HP OfficeJet D135 All-In-One InkJet...
Scanner Falure Issue
Clean Scaner Unit Properly its not easy to done
other wise all engineer
May 26, 2008 | HP LaserJet 2840 All-In-One Printer
HP photosmart c7180 scanner failure
you can run a reset on the printer and clear the scanner failure yourself. You can find the instructions at: http://www.inkbank.com.au/webcontent21.htm
good luck...
L.C.
Apr 04, 2008 | HP Photosmart C7180 All-In-One InkJet...
Scanner failure
scanner failure, turn unit off and back on, does not help
Oct 01, 2007 | HP OfficeJet d145 InkJet Printer
HP PSC 2355 All-In-One InkJet Printer Logo
117 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
