York HVAC unit fan is making a lot of noise. Hot air down come out, and in the summer coll air did come out, but the fan is loud. Thanks
  • 1bargainfind Oct 21, 2008
    We are tomorrow FH Furr HVAC folks in Woodbrige - just hope it's not tooooo much!!!
    Thanks again
    Cindy
    Guru:
  • 588 Answers
If your fan is making noise the blade or blower wheel is either hitting something or the bearings in the motor are bad and the motor needs to be replaced.
Posted on Apr 23, 2009
  • 1,420 Answers
Have you checked the air filter? You could also have a loose blower wheel. I do suggest you have someone really look at it.
Posted on Oct 21, 2008
The compressor is extremely loud. How do I fix this? Also, sometimes it does not warm up like usual, what can be causing this?
with loud noises and underperformance a complaint , me id be looking more at the fan part of this machine , wall units get a lot more dirt and stuff inside them then other types ,especially if there low on the wall . so its entirely possible that items could be wedged down inside that has effected the balance of the fan blades , and this is cause for lots of noise complaints , plus if items are large enough then yes they will effect the speed of fan as well
Feb 12, 2016 | Amana DigiSmart PTC153B35AM...
Ac only blows hot air
Have you check your remote control. Make sure you choose the cooling mode.
Aug 02, 2014 | Heating & Cooling
My 2006 chevy cobalt is making a loud buzz when in park and ac is on
Anytime the a/c is turned on the cooling fan will come on so that the engine does'nt over heat.It will not turn off until the ebgine has colled down.
Nov 02, 2012 | 2006 Chevrolet Cobalt
We have a Rheem air conditioner that is 9 years old Model number RAKA 037-JAZ and have been having some issue with it. Last summer the condenser wasn't coming on so we have a friend who is a HVAC guy and...
It sounds like he got you a Hard Start Kit/Capacitor, that might explain
the five minute delay. When the fan is not operating the compressor will
make a loud noise..
Check to make sure insulated suction line is cold, that mgiht tell you that the compressor is working.
Check to make sure hot air is discharging out of the condensor.
If neither of these to things are happening and you think the compressor is on, it is possible that you are low on refrigerant.
Check to make sure your indoor blower is working, the filter is clean and check to see if you have condensation dripping from the indoor unit
Jul 11, 2010 | Heating & Cooling
My computer is becoming really hot and noisy. After turning on the computer, everything is good (no noise). Once around 15 minutes passes by or I open up a lot of programs together, my computer starts...
Sounds like the fan is wearing out, as it heats up the fan needs to spin faster and if the bearings are wearing out it will start getting louder and it will also get hotter because the fan cannot keep up the heat being produced. You can replace the fan, most computer shops will carry replacements, also get a can of compressed air and give the inside of the computer a good cleaning. This will help keep things cooler as well. Also make sure that the air vents on the outside of the case are clear as well.
Jan 07, 2010 | Vantec Fan Vibration Dampener Noise...
Compressor of the Ruud A/C outside unit is making unusal loud continuous noise. I open the case, its not the fan or fan motor, loud noise is coming from the compressor, and it is also heating up a lot....
OK, you will need to replace this compressor. the internal seals have ruptured, causing the loud noises. the heat is from the metal to metal friction. the compressor can be rebuilt but, it will be more costly than just replacing it with a new compressor.
May 27, 2009 | Ruud Handle Air Conditioner
Air conditioning fan makes loud noise the faster you ru it.
Concerning your broken vent -- this can be caused by a broken linkage or a malfunctioning servo motor as well. these vent have air ducts the sway back and forth to adjust the dual air flow function. if the servo o linkages are malfunctioning or not connected for some reason, it will not allow total control of the air flow and temperature range. Now, if you have a combination of a flow error and temperature error as well, thai can be caused by a combination of the two.
In this case, you will need to inspect the linkages as well as the servo motor function as well. in addition, i would test the air temp sensors for there operational value. they control the temp when you adjust the coll or hot function.
Concerning the Loud noise coming from the blower fan---
This issue can be caused by a misalignment within the blower housing or, it can also be caused by some minor damage within the motor itself, causing it to rotate in a erratic manner, in return, forcing it to rub against the housing itself. the best solution here is to extract this blower fan housing and inspect for lose fan propeller and motor stability. replace parts accordingly.
PLease rate and have a great day:)
Apr 22, 2009 | 2004 Chevrolet Tahoe
AC make loud noise on power off.
Is this a wndow unit or central air system? if this is a window unit , your problem is it only needs cleanning (dirt dbber nest-- trash around the back blades-- or the unt is twisted and rubbing the fan shroud. Last but not least, the slinger ring around the back blades (a ring around the end of the blades thats picks up water in the bottom of the unit and sling it on the coils to help cool the hot gases....Thank-you Thank you Thank you very much!
Jun 02, 2008 | Heating & Cooling
Heating & Cooling Logo
402 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
