Question about HP Office Equipment & Supplies
HP OFFICEJET PRO K5400 - COMMISSIONED FRIDAY OCTOBER 17 1) TODAY OCT 21 PRINTING PDF DOCS TEXT WITH COLOUR PICS, PRINTED SEVERAL COPIES OK, PRINTER STOPPED PRINTING THE PICTURES. AFTER SEVERAL ATTEMPTS TO PRINT WE UNINSTALLED SOFTWARE & REINSTALLED. PROBLEM OVERCOME. WE THEN PROCEEDED TO PRINT SOME WINDOW DOCS WITH TEXT & PICTURES.ALL DOCS IN THE SERIES HAVE 2 PICS, ALL PRINTED OK WITH THE EXCEPTION OF 2 DOCS WHICH ONLY 1 PER DOC PRINTED. ANY SUGGESTIONS. INCIDENTLY WE HAVE NO PROBLEM WITH OUR HP DESKJET 595CXI.
  • HP Master
  • 4,173 Answers
Try this !
in the software application you are printing from
Open the document that you want to print.
2. On the File menu, click Print, and then click Setup, Properties, or Preferences.
Look for a Best Mode Setting
this printer has several modes one being draft mode, another one best mode
in best mode the printer uses memory to render the photo you are trying to print.
Note that in this mode, printing takes
longer and more memory is required from your computer.
from page 17 of the hp k5400 user manual
Also you may have to increase the virtual memory of the windows pc to allow the computers hard drive to allocate more hard drive memory to the memory swap file if the computer's ram is not enough to print the photo.
It is a setting in the control panel under system - performance.
Posted on May 12, 2017
JMuskovitz
  • 135 Answers
SOURCE: printing black squares in word.doc
It sounds like this is an HP driver issue. HP drivers have built-in "optimizations" (that unfortunately have bugs) for things like printing photos. Different programs (word, for example) try to take advantage of these optimizations in different ways. When they work, they give superior photo printing (faster, with more accurate color). When they don't, you get black squares. This is why "converting" it to PDF worked for you -- Word printed it through the PDF driver instead of the HP printer driver, then when you printed the PDF file, that program avoided those optimizations when it sent the images to the printer. Unfortunately, the translation caused quality loss. If your goal was to print out something like a "proof-sheet" of photos, you might try the free photo organizer at www.preclick.com. It will print these for you, captions and everything, and should be able to avoid the driver issues.
Posted on Apr 11, 2007
cjake8
  • 6 Answers
SOURCE: hp 7660 photosmart printer
I have an HP 4215 and I get the same printing response. It takes 30 minutes to print 1 page. How do I clear the memory or speed up the printing?
Posted on Mar 20, 2008
  • 160 Answers
SOURCE: problems with HP deskjet f380. Will not print... scans and copies
the system for vista and xp is near to similar. so just click the following links 1 by 1 and go through the instructions as you r missing any minor step to be followed in loading your printer How to load a printer on a pc step by step instructions
http://freepctech.com/pc/xp/xp00168.shtml
http://kb.iu.edu/data/aksl.html
Installing a printer on a Windows 95/98 network
INSTALL THE PRINTER on a PC
ENABLE PRINTER SHARING
MARK the NEW PRINTER as a "Sharable" Printer
INSTALL THE PRINTER ON THE OTHER PCs
Troubleshooting Windows 95/98 networking problems
http://www.mcgill.ca/ncs/products/soho/networking/printer/
How to install a printer driver locally for a remote printer in Windows XP/ Windows 2000-
http://support.microsoft.com/kb/282842
Posted on Jan 06, 2009
  • 909 Answers
SOURCE: hp officejet, pro k5400 printer,when printing i
That is ink or dirt on the rollers, you need to clean them by lifting the lid, as if you were putting new ink in, and wipeing the rollers that the paper runs through.
Posted on Jun 09, 2009
SOURCE: Hi - I have a HP Officejet Pro K5400 printer. That
Please follow the steps in the order below and check.
1. Make sure the product is on, and then disconnect the power cord from the product.
2. Disconnect the USB cable from the product, and then disconnect it from the computer.
3. Reconnect the USB cable to the computer, and then reconnect it securely to the product.
4. Disconnect the power cord from the wall outlet, and then reconnect it to the wall outlet.
5. Reconnect the power cord to the product.
6. Press the Power button to turn on the product.
Now perform these steps on the computer...
(1) Click "Start" > "Run".
(2) Type "services.msc".
(3) Click "OK".
(A window will pop-up with so many services listed)
(4) Locate and Right-click "Print Spooler" entry and Select "Restart" from the drop down menu.
(5) Now please restart the computer.
now please print and check
Posted on May 20, 2010
Black ink not printing properly on HP Officejet Pro K5400. It's a new cartridge, have tried another cartridge too but same problem.
The print head may be blocked.
Run the cleaning cycle a few times on the machine.
This can be done through the software drivers loaded on your computer.
If this does not help, you will need to replace the black print head.
Feb 14, 2011 | HP Officejet Pro K5400 All-In-One InkJet...
Why is my HP printer not printing Black in black.
may be the ink cartridge is empty/not working. remove and return then restart the printer. if empty u can buy a new one. if u are a risk taker buy the black ink then a seridge and a niddle then refill it.
Jun 22, 2010 | HP Officejet Pro K5400 All-In-One InkJet...
Ink cartidges are all installed and registering ok. New balck ink installed but will only print in colour and not black print what can I do as I need docs printed urgently?
Does it take (pull up the paper) in the paper? If so, Try to print only images and check if it works or not. It'll be much easier if you let us know the program from which you are printing. Also try to print only in text using Ms Word, wordpad or notepad. If possible update your driver. Good luck.
May 26, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
I want to print using only the black cartidge with my HP officejet k5400
go to control panel> deices and printers> right click you printer>printer properties> preferences> grayscale printing
Apr 06, 2010 | HP Officejet Pro K5400 All-In-One InkJet...
Officejet pro K5400 won't print pdf files
If these are web-based PDF's this may well be your problem. There are code anomalies printing directly from a web page if it's a PDF-based file (on many HP models).
If this is directly from an Adobe PDF (non-web based) then you may need to update or reinstall the print drivers. Also, Adobe Acrobat versions vary on how well they will send print commands to various devices. Try to make sure you have a higher version of Adobe than 6.
Aug 10, 2009 | HP Officejet Pro K5400dtn Printer
I have an HP Officejet Pro 7580. When printing in
I think ur catridge must be empty plz fill ur catridge and then check
May 26, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Press "set up" button until number 6
Number 6 is "tools"
press OK
press forward arrow (to right of ok button)
No.2 is clean printhead
No.3 is align printer
No.4 is calibrate line feed
Mar 25, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP K5400 - print pausing
print as image tick it than it will work
Jan 19, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
78 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
