Question about Whirlpool MH7140XF Microwave Oven
Gh5184xp no power
While boiling water, on the stove top, with the exhaust fan on the unit went dead. Power to the unit is good. Also can not find service manual on-line. Please help.
  • Whirlpool Master
  • 9,098 Answers
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our site, we have a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
The fuse and magnetron thermostat can be checked without pulling the oven form the wall.
But if you need to check the cavity thermostat, the oven will need to be removed from the wall, and it helps if you still have the installation instructions.
Whirlpool customer service is here and you can also enter your model number on that page to download your owner's manual, installation instructions, etc..
Posted on Oct 24, 2008
My fan for the stove reduces power once the microwave is turned on
you must understand that any manufacturer has the proper design engineering from to save electricity, etc. And they using the new concept of reingeenering.
If the microwaves do not HEAT and working, do not worry.
Mar 06, 2013 | Microwave Ovens
My Kenmore Elite electric stove top will turn on fine, but it will randomly cut off. Then none of the burners will heat up, but lights are on like all is fine. If I turn off the power for 5 minutes it...
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
An overheating magnetron can be :
  • operating oven without cover(s) in place
  • wrong magnetron installed in oven
  • an old or otherwise failing magnetron
  • cracked magnetron magnet
  • improper power line voltage (US homes should be 110-125VAC)
  • foods low in moisture (popcorn & bacon, e.g. - add 1/2 cup of water in rear oven)
  • failed or inoperable cooling fan or hood vent exhaust fan
  • deteriorating foam weatherstripping seals in air ducts or on outside cover
  • blocked air vents (dust, animal nest debris, insufficient free air space behind & around oven, etc.)
  • clogged or greasy charcoal filter or grease filter
  • blocked duct in hood vent exhaust
I suspect a failure or the fan, clogged filter or bad magnetron.
I appreciate your thoughtful rating of my answer.
Feb 07, 2011 | Microwave Ovens
We had sevseral boiling pots going underneath the over the range microwave without the exhaust fan on while also cooking in the microwave, we saw sparks in the microwave and it went dead. now nothing...
The main power fuse inside the MW may have been blown from the steam shorting out the circuitry. If so this fuse probably can be replaced. Lowes has replacement fuses.
Jun 13, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
I have an over the stove kitchenaid microwave w exhaust hood. About 1/2 hour after boiling water on my stove, my microwave comes on. I have unplugged the microwave-----any ideas?
The issue is probably your exhaust fan on your microwave comes on automatically when it detects a certain temperature. Mine does this as well but will turn off automatically after temperature goes down.
Feb 25, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
The built-in microwave went dead as I attempted to screw in a new light. It arc'ed, then there was zero power to the unit. Is there an in-line fuse or circuit-breakers?
was cooking on the stove below the microwave and had the fan on. the nicrowave went out all together and will not come back on. it did not blow a fuse in the breaker box. is there a reset button or something to turn back on
Aug 05, 2008 | Microwave Ovens
Microwave turned off
I always suggest that the hood / exhaust fan be on whenever you're cooking on the stove top. This helps keep grease and steam out of the controls.
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Otherwise, you may have a bad controller, which we may be able to repair for you.
Jun 29, 2008 | GE JVM2070 Microwave Oven
Microwave oven won't work
If the internal fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven or veen on the floor of the oven chassis.
Hopefully the vent fan was on strong enough to keep the steam out the of controls. That steam could scramble or damage the circuit board or keypad.
You should unplug it from the power line for a few minutes, plug it back in, then try again.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya:
Nov 15, 2007 | GE JVM1650 1000 Watts Microwave Oven
Microwave Oven completely dead
Check if there's a fuse on the front panel.i'f had it on other makes.replace fuse and it should be ok.
Feb 22, 2007 | Kenmore 62702 Microwave Oven
Whirlpool MH7140XF Microwave Oven Logo
193 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
