Wont start sometimes. sluggish or hard start when it does strong fuel odor and p0118 code
The engine coolant temperature (ECT) sensor is a thermistor screwed into a coolant passage in the cylinder head. Sensor resistance is high when coolant temperature is low and resistance drops when coolant temperature increases. The powertrain control module (PCM) provides a 5 volt reference and a ground to the sensor. The PCM monitors voltage drop to determine coolant temperature. If the ECT reads less than freezing temp. when engine has been running for more than a few minutes, the PCM determines a circuit fault and sets this code. Or if the PCM determines the sensor resistance is out of specs, this code is set.
Potential Symptoms
Symptoms of a P0118 could include:
A code P0118 may mean that one or more of the following has happened:
THATS GONNA BE MY NEXT THING AFTER REPLACING THE DISTRIBUTOR CAP. BOTH ARE FAIRLY SIMPLE AND INEXPENSIVE SO WE WILL SEE HOW THAT WORKS. THANKS A MILLION FOR UR REPLY JOHN. IF YA THINK OF ANYTHING ELSE HELPFUL I'M ALL EARS.
