Question about LG RUMOR Cellular Phone
Screen is not readable all glichy
The screen looks like someone took a coin or a knife to a painting that was wet an smuged it.
  • tigger12008 Oct 21, 2008
    I also can not text or see my texts because of this.
  • mechyyG Oct 22, 2008
    the screen turns white when i slide the keyboard out!
Take it to your local sprint store they are having problems with most of the black and the white rumors...the green ones came out after the first two so the green ones arent having this problem~
Posted on Oct 22, 2008
How do I get my screen fixed on my laptop?
You will need to replace your screen, so you can do it yourself by acquiring a new screen and replace it, take a look to this video
Dec 21, 2011 | HP Computers & Internet
The flat screen tv was sprayed with paint right across the screen we need to know if there a way to get it email address is
buy a solvent called paint thinner from paint selling shops .............. using this paint thinner easily paint on your tv screen can be removed without any damage to screen .......remove tv powercord from power socket ......take thinner in small cup ...... take a small piece of soft clothe ..... dip in that cup such that soft clothe becomes just wet ....then slowly clean that particular place where paint is there .....same time keep another soft dry clothe in your other hand ......while cleaning with thinner paint on screen becomes thin then immediately clean it with other clothe..........remember while cleaning thinner's drops should not fall down & go inside tv through edges of screen ....... since this thinner smells like a paint after cleaning tv screen will have paint like smell again you have to repeat above steps but this time you have use soap water or any ordinary cleaning solution ....................................... click below shown link for images of thinner.....,or.r_gc.r_pw.&biw=1024&bih=418&wrapid=tlif131594078475010&um=1&ie=UTF-8&tbm=isch&source=og&sa=N&tab=wi
Sep 13, 2011 | Samsung Televison & Video
How dom i remove shelves that were put up with wood glue without taking half the wall with it?
If wood glue is adhered to a painted surface, and the paint is adhered to sheetrock ... you are not facing good news.
I painted and did sheetrock for years.
Here's how I'd handle the problem.
Use sharp utility knife and cut through the sheetrock paper around object that is glued.
Once the paper is cut, you can tear off glued item and it will remove as little of the wall as possible.
Next, but some sheetrock mud.
But not your usual type.
Get the powered bag that you mix with water.
They make 15 minute set up, and 45 minute, etc.
Don't buy paper drywall tape for this job.
Buy the fiberglass tape that looks like a screen.
Clean up you wall so it's smooth.
Use knife to cut a taper edge around each broken area of sheetrok >>> this will keep the edges down so they're not sticking up
Mix up the drywall mud so its like toothpaste.
Apply mud into wall damage.
Here's the trick ... do not build it up so you have to sand it off.
Keep it low.
Put the mud on the wall.
Push the tape into the mud.
It won't be perfect.
Smooth as much as possible using your 6" drywall knife.
Do the project in stages.
Let it dry.
Take your 6" mud knife and use it like a spatula to scrape down the high points.
Keep it low so you're not sanding.
Mix more mud.
Apply a THIN coat over repair.
Let it dry.
Scrape it again with the mud knife.
Bring a table lamp over to where you're working.
Put the table lamp up close to the wall so the light casts across the repair.
The light will let you see the high and low points in the repair
Keep floating mud in very THIN coats until the wall is smooth
Put a coat of paint over repair.
Use the light again to look for dips and weaves in the surface.
Smooth it out with the mud
Paint the wall.
If you get stuck in the project, answer back and I'll give words of encouragement.
Oct 25, 2010 | Garden
I have a deep scratch in one of my doors on my Buick. I bought the touch up paint but I'm not exactly sure how to apply it. I have used touch up paint many other times with many cars and it always seemed...
if you are using a mere touch up kit ..i would recommend for about 15-30 cents buying a model paint brush the bristles are much smaller than what comes in the bottle and no you wont need to sand it at all after application it will look very dull but put it on and allow it to simply apply to the scratch only ....unless you know someone in the paint dept...and ask for a bit of clear to mix into the paint it will look dull upon finish
if you are good at airbrush i would suggest merely filling the scratch in just as i described earlier ...unless you are going to actually paint the entire area then your talking blending into either the adjacent areas or merely blending into the area around the scratch ...what ever way you look at it touch up paint will always look dull upon finish
Dec 11, 2009 | Buick Park Avenue Cars & Trucks
Grandchild scratched large tv screen with sereated knife
It is not repairable..A new tv will have to be bought.
Nov 09, 2008 | Sony Televison & Video
Coin is stuck inside
where is this machine? apartment complex? YOUR private machine?
Dec 27, 2007 | Maytag MAH2400A Front Load Washer
Red curved lines across screen
Dec 05, 2007 | Samsung HCM4215W 42" Rear Projection...
LG RUMOR Cellular Phone Logo
64 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
