Question about Sharp AR-M350N Copier
AR-M350N Sharp Copier
Can you scan a colored picture and send it as an e-mail and will it be in color? I swear we did this when we first got the copier but I can't now...
SVC
  • 94 Answers
Yes, it is possible. You need to use the software for your Sharp copier to scan the colored picture. Once you have scan it, you may use or send it to any email address.
Posted on Oct 21, 2008
Code erreur E7 03 SHARP AR-M350N
E7-03 means that the machines hard drive has gone bad. It can be backed up and replaced by a trained copier technician.
May 22, 2011 | Sharp AR-M350N Copier
Code U2-91 on Sharp AR-M350N
Try to reset this by #*C* and press 16 press start, if this not resolves your problem theEEPROM is defective , Replace EEPROM on the MCU PWB.
Apr 13, 2011 | Sharp AR-M350N Copier
Cannot scan in color. can only scan in gray.
That is because it is a Black or White copier. It will not scan in color, it is not designed too
Jul 31, 2010 | Sharp AR-M205 Copier
Cannot scan from sharp color copier
Did you unlock the scanning feature with the product key.?
Jun 15, 2010 | Sharp AR-BC260 Color Copier
Copies get stucked in sharp ar-m350n fuser
check the fuser roller gears ,the impression between the two roller and the paper seperators one of these is not in good shape.
Feb 21, 2010 | Sharp AR-M350N Copier
Sharp AR-BC260 shows the network error CE-02
You need the Sharpdesk Software CD and you will have to install it in order for the scanning function to work.
Feb 03, 2010 | Sharp AR-BC260 Color Copier
Sharp AR-M350N memory?
AR-M350N may be have 16 Mbyte of internal memory.
You could expand it until 256 Megabyte.
I attacched to this post an image that describe compatible expand memory.
Nov 03, 2009 | Sharp AR-5320 Black and White Copier
Code: H4-00, H4-0Q
H4-0 The fusing unit doesn't heat up.
You have to reset fuser errors with simulation 14.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Jan 25, 2009 | Sharp AR-M350N Copier
SHARP AR C250 Digital Color COPIER HAS SERVICE CODE H4 00
Press P-interrupt-C-interrupt and enter test command 14 and Execute to clear your error. Let your machine reboot. If it comes back you have a problem with your fuser. Most likely it's dirt or toner caked on your tempature sensors and they need to be scraped off.
Mar 17, 2008 | Sharp AR C250A Color Copier
Sharp AR-M350N Copier Logo
142 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
