Question about E-Machines Computers & Internet
The cakewalk pyro program will not write the tracks . its a new e machine . the program is 4 years old but worked perfectly in my old computer. can you help me ??
  • 749 Answers
Check the system requirenments of the old program- if made for an earlier version of windows do this:
uninstall it. then reinstall using the program compatability wizard found by hitting start-programs- accessories- program compatability wizrd- this will walk you throught the install and ask what operating system the program was originally intented for and aid you through and incompatability issues.
Posted on Oct 21, 2008
Cakewalk pyro 5.0 serial
Cakewalk Pyro 2005 Plus 1.1
S/N: cwpp171331246 MP3 Creation Activation Key: 90F2A7FF Video DVD Burning Activation Code:: FCF9A2F9
or
CWSP-5.00-834700-142248,
CWSP-5.00-834701-451782,
CWSP-5.00-834702-106549( 3 serials
hope it helps
May 16, 2012 | Cakewalk pyro 5 Full Version for PC
Cant'r run pyro5 on windows 7. is there a solution other than buying new pyro software?
Yes, but it may be more expensive then buying the new Cakewalk pyro Audio Creator 1.5 ($40). The cost will depend on your version of Windows 7 among other issues.
From the Cakewalk site: "pyro 5 and the other versions listed above will not launch properly under Windows 7. They will not function at all."
The work-around is to run the software such that it thinks you are using an older version of Windows. There are a two ways to do this with one computer: 1) run a dual boot system with Window 7 and an older version of windows, 2) run a virtual computer with an older version of Windows inside the Windows 7 system using Parallels, VMWare or Virtual PC.
In most cases for either option, you need a licensed version of the older Windows OS. If you have Windows 7 Pro or Ultimate, you can get the virtual computer with XP for free. Download Microsoft's Virtual PC and then the XP mode package. Install them in order and install your Cakewalk software to the XP computer as if that is the only computer. The only issues can come up is that peripherals (like printers) can't be installed on both the real and the virtual computer and sharing files has to be done by saving to optical or other external media.
I'm not sure how much of a learning curve would be involved but there is a free audio editor available. See http://audacity.sourceforge.net/ for more information - the Win7 version is still in beta but works.
I hope this helps.
(Virtual PC http://www.microsoft.com/downloads/en/details.aspx?FamilyID=04d26402-3199-48a3-afa2-2dc0b40a73b6; some updates are also available.)
Dec 30, 2010 | Cakewalk Pyro Audio Creator - Windows CD...
Pyro plus does not work on windows 7
If a program cannot be run under Windows 7 because of compatibility issues you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website: http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Dec 02, 2010 | Cakewalk pyro 5 Full Version for PC
I downloaded cakewalk studio instruments into computer i get
Check to make sure all your audio drives are configured. Sometimes the microphone jack isn't configured with the program. No audio comes through. Another suggestion is to, try Audacity. It is a free audio recording program, and it helps to master even some of the hardest studio production software programs.
Feb 04, 2009 | Cakewalk Studio Instruments ( Windows...
Hearing other tracks when recording
i want to know how can i download dreamweaver 4.0
Jan 29, 2009 | Cakewalk Guitar Tracks 2 (804526011836)
Does Cakewalk Pyro 5 work easily with a USB turntable
Yes, Cakewalk Pyro 5 works well with a USB turntable. It has specific support for USB turntables. One example of a turntable that works well with it is the Stanton T.90 USB Turntable.
Nov 14, 2008 | Cakewalk pyro 5 Full Version for PC
When recording live feed from various guitars I can't get the recordings to synchrinize
Sounds like you have a latency problem. This can be for a variety of reasons, something Cakewalk admits. The reason for that could be everything from processor limitations, not enough RAM, your soundcard, or simply that you need to change the latency configuration in the audio settings menu of the program. Considering that that is the cheapest fix, try changing settings first. Be sure to follor the help information in Cakewalk - they can be a little confusing for Cakewalk (I have no idea why they can't seem to explain their programs after all these years) but you will be able to figure out what settings are right for you.
My guess is that when you record, you are listening to the previously recorded track, and playing to it. Then when you play it all back as a mix, they are not in sync as when you were recording them.
If that is not the problem, plesae explain further. You are able to monitor your previously recorded tracks, right? Not just playing each track "blind" and trying to have them match? Hope not. That is rarely possible - if at all.
If you are monitoring your prerecorded tracks while recording on top of them and it sounds different when you play it back, it's definitely latency.
Mark
Oct 02, 2008 | Cakewalk SONAR 4 Producer Edition for PC
Slow Playback
Sounds to me that the computer is way out of date. Chances are the computer doesn't have enough processing power to support what you're trying to throw at it.
It might help stop/uninstall all other programs running at the same time to give Cakewalk the best chance of working.
Nov 15, 2017 | Cakewalk Guitar Tracks Pro 2 Classic
How do unlock the encoder.? For MP3. Do I have to buy Pyro. There is no Pyro included with my Sonar cakewalk product?
Most Cakewalk products include a trial version of MP3 encoding technology. For unlimited MP3 export in your product, you must purchase the Cakewalk MP3 activator
Aug 30, 2008 | Computers & Internet
Computers & Internet Logo
41 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
