Question about Philips Magnavox 9P6034C 60" Rear Projection Television
PICTURE PROBLEM I NEED TO GET A COMPLETE MANUAL FOR THIS TV, ANY IDEA WHERE I CAN PURCHASE SUCH MANUAL....JIM
  • Philips Master
  • 5,568 Answers
It isn't likely that you will find this as a free download since they can be quite complex.
The link below will give you the chance to download the service manual for $11.99:
Magnavox manual
Happy hunting -
Posted on Oct 31, 2008
Need to purchase complete wiring diagrams for 1980 Alfa Romeo Spider Veloce 2.0L
this site worth a try
you click on the section of repair manual you need and it will download
you have to join the free forum to ask questions
BerlinaSportivo Alfa Romeo 155 Q4 and Sports Saloons on the net
Jul 07, 2016 | Alfa Romeo Cars & Trucks
Need to know how to change and setup for use of antenna
Purchase your UHF/VHF antenna. The antenna can also be purchased at most electronic and retail stores. Consult your list from Step 1 and see how powerfulicon1.png the over-the-air signals are for your specific address. Purchase your antenna based on the broadcasting power you need to receive a clear picture on your TV. You might be able to get away with an indoor antenna if your signal strength is strong enough. If not, you'll need to purchase an outdoor antenna.
  • 4 Install your antenna (or have it done professionally) according to the building codes of your area. If you must use an outdoor antenna, it is a good ideaicon1.png to have the antenna professionally installed. This ensures that it is properly grounded on your roof, not too close to electrical wiring and stable during inclement weather.
  • 5 Hook the converter box up to your television using the cable that came with it (F Cable). Hook your antenna up to the converter Box. Turn on your TV and converter box. Tune your TV to channel 3 and press "Scan" on the digital convert box. Allow the box to scan for your available channels.
  • 6 View your picture and adjust your antenna accordingly for the clearest over-the-air feed. You should only need to make adjustments once. If you are having a difficult time getting a clear picture, use a signal strength indicator to see where you receive the most powerful signal.
  • Read more: How to Replace Cable TV or Dish TV With Antenna TV ' eHow.com http://www.ehow.com/how_5228282_replace-dish-tv-antenna-tv.html#ixzz2RrACTyTI
    Mar 29, 2013 | Sansui 19 in. LCD TV
    Distorted picture
    Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
    The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
    http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
    They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
    Jan 16, 2010 | Samsung HCN4226W 42" Rear Projection...
    Picture no sound
    hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
    thank u!!!
    rate me
    Jul 18, 2009 | Sharp LC-C4655U 46 in. LCD TV
    No Picture
    Backlight Bulb is out.
    You cannot purchase these as a spare part, you must purchase the complete backlight.
    Backlight cost is more than or equal to a new TV
    You may sell this TV on Ebay (list your exact symptom). Start at 100 you will get about 250. Take this money and buy a new TV.
    LCD backlights don't fail often but when they do there are no part available to repair them so you get stuck buying the complete assembly part. This is more expensive than a new TV since LCD prices have dropped so much in recent years.
    Apr 19, 2009 | JVC LT-32E478 TV
    42px5d got sound but no picture
    You need the Y sustain and y drive boards. No idea where to purchase in australia, but you may be able to order them from LG.
    Jun 26, 2008 | LG 42PX5D 42 in. Plasma HDTV
    Lines no user guide
    that manual is no longer available through mitsubishi or retreveo.com/ you may be able to purchase one through manualsinpdf.com
    Apr 14, 2008 | Mitsubishi WS-55907 55" Rear Projection...
    Panasonic PT-51G44A TV
    Need new board, Letter D - Item Number afteer you take out the 10 or more screws.
    TNPAO609
    The part thats dont work any more would be C518 on the TNPAO609
    Mar 21, 2008 | Televison & Video
    Picture surges
    forget anything you ever told about this product if you unsolder the convergence ics stk pack and the tv stays on then just the beginning of your problems the vast majority of these tvs have burned fluid in the picture tubes and restoring the elctronics to working is time not well spent the panel for the deflection circuit ( in the middle)? would have to replaced if the tv does not power on
    Dec 08, 2006 | Philips 9P5034C 50" Rear Projection...
    Philips Magnavox 9P6034C 60" Rear Projection Television Logo
    52 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
