Question about Recoton Advent Advent Q2035A 20" TV
Advent Flat Screen with TV/AV Button Clicking & Lighting Intermittenly NO PICTURE
I always leave my TV on all day and I came one day to find the TV/AV button (that is also slight lit up purple) clicking and blinking about every 2 or 3 seconds. The power button does not work at all, none of the features: channels, volume, etc. work and I have NO picture. If the set is plugged in the TV/AV is clicking and the only way to stop it is by unplugging the TV. Any ideas from anyone? I do have a replacement universal remote for the set, but did not touch it after I left the set on the day it started doing this. I have also tried pressing about every button on the remote in case I did accidently change something. We have had some thunder & lighting storms lately, does this sound like it could have been hit by lightning? Any help or advise would be appreciated. Thank you very much.
  • Mary Kangas Jul 24, 2006
    Thanks to both of you for writing to me. Where do I check for that capacitor? Is it internal to the TV? Let me tell you... this TV is so huge and heavy I don't see how I can take it IN anywhere. I have only had it a little over 2 years, so am really frustrated that it is this way. What would make it just "die" this way when it was simply turned on? I suppose this capacitor thingy could just have blown or something, huh? Thanks again.
  • tonyj222 Feb 19, 2008
    the tv/av button just keeps on clicking
    New Friend:
  • 163 Answers
Check for the power supply capacitor usualy a 220/450vdc is ok to use a largest capacity but remember to use no less than the sugest voltage...good luck...
Posted on Jul 24, 2006
    President:
  • 3,130 Answers
The fact that its clicking on and off tells me that theres probably a short in the horizontal sweep/output circuit of the set. You see when the set starts up the power supply detects a large current surge and shuts down. Some sets will try three times if this happens and then stop till the power is pressed again. It sounds like this set dosent have that way of operation. Its going to need a technician to look and troubleshoot the problem Good Luck
Posted on Jul 23, 2006
Why does my Sony FWD-42PV1 intermittenly black out?
if the tv blacks out and the light in front stays on its the backlight going out...my first vizio did it within 3 mos of purchase had to send in and they ended up sending whole new tv
Sep 11, 2012 | Sony FWD-42PV1 42 in. HD-Ready Plasma...
Settin TV to AV
Look at your remote for a button called "input options" and press that button while watching your screen to see the various choices available. Everytime you press that button, you should see a change on the screen from one choice of input method to the other. It should says things like "AUX, video 1, video 2, hdmi, AV - ect. Keep pressing that button until you see a picture of find the AV input method you want to keep and that should solve your problem.
Apr 15, 2012 | Sony Televison & Video
I can only get channels 600 through 900 which I have never see before.I cannot get regular channels or cable channels.It is not a flat panel t.v.Q1435A is the model number
Hi -
If you have a cable TV line connected directly to the TV, an antenna or a cable box connected by coaxial cable, I would suggest running the automatic channel scan (AUTO-PROGRAM) again:
1. Press the AV key on the Advent remote control repeatedly until TV is displayed in one corner of the TV screen. If you don't have the Advent remote, use the TV/AV button on the front of the TV.
2. Press the MENU key on the advent remote or the front of the TV to open the on-screen menus.
3. Use the CH+/- keys on the remote or on the front of the TV to highlight PRESET then press VOL+ to select.
4. Use the CH+/- keys on the remote or on the front of the TV to highlight ANTENNA then use the VOL+ key to select either AIR (for antenna) or CABLE.
5. Use the CH+/- keys on the remote or on the front of the TV to highlight AUTO-PROGRAM then press the VOL+ key to start the automatic channel scan.
Once the channel scan is complete, the TV should automatically return to viewing the first channel found during the scan. Do not press the MENU key during the scan or the scan will not complete.
If you are using a cable/satellite receiver and it is connected to the TV by any means other than a coaxial cable, you do not need to run the channel scan. You should simply select the correct AV input using the AV key on the remote or the TV/AV key on the front of the TV (see step 1 above).
If you have done all of the above and you are still unable to get the channels on your TV, please post back for further assistance. You can reply to me by clicking on "Add a Comment" below your question. Please let me know whether you are using a direct cable line, antenna or cable box, etc.
Regards,
BElectric
Mar 26, 2011 | Televison & Video
How do you turn on the Backlight on the screen?
If the screen backlight is not on, first try adjusting the brightness.
Press TV/AV button on remote to select TV mode. Press the MENU button on the remote. Using the arrow keys (navigation buttons), choose picture mode and adjust the brightness and contrast.
If your TV screen is still not lighting up in a dim room, then the backlight is broken.
You have 90 days labor and 1 year parts from date of purchase.
Oct 19, 2010 | Haier HLT71 7 in. Portable TV
The screen is all brown with no picture
preciso mudar o sistema de cor ntsc para pal m
Dec 31, 2009 | Recoton Advent Advent Q1435A TV
The lower half of the screen is a black box on one channel
Check your closed-captioning settings. You probably have it set for "text". Make sure you turn captioning off and the problem should clear up.
Feb 12, 2009 | Recoton Advent Advent Q2035A 20" TV
Screen is dark
AV/TV Button
Press ¡° AV/TV¡± button,the will be some word show on the right top
of the screen, press ¡° PROG+/-¡± to select the AV source, and then
press ¡° VOL+/-¡±to enter AV mode.
TV
PC
SCART
http://www.denver-electronics.com/UploadetFiles/154/25/DFT-1504_Black_English.pdf
The Tv is starting or going into PC mode Or scart mode set to TV mode. Hope this helps Please rate me. The link is to all of the setting for the TV. Blue light is pc led.
Dec 21, 2008 | Hisense LCD1504 15 in. Television
Advent 32" tv flat screen
It's likely one of two things. There are drive transistors on the CRT board which control the output to the guns, the one that controls the red gun may be open, also check this board for burned resistors. It could also be a bad picture tube although this is less likely. If it is the tube, replacements if available are fairly expensive.
Oct 17, 2008 | Recoton Advent Advent Q2035A 20" TV
AV Out Keeps Turning Off
Okay well you have to eject the tape and leave the eject open. There is an auto timer that always turns off the picture. If you open up the tape eject and leave it open the camera will always stay on.
Mar 06, 2008 | Sony Handycam DCR-TRV140 Digital Camcorder
Recoton Advent Advent Q2035A 20" TV Logo
Top Recoton Advent Televison & Video Experts
Jaime Hernandez
Sheldon Dedek
Are you a Recoton Advent Televison and Video Expert? Answer questions, earn points and help others
