Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Model 795.77309600 French door refrig, with freezer on the bottom. Light stayed on, melted the plastic and now the controls are hanging from the top of the refrig. I need a part number and how to replace it. Also, on the bottom of one of the doors, a plastic ring type thing seems broke, may control the light coming on, not sure.
  • 1 more comment
  • sully252 Oct 22, 2008
    I have the same problem on Model 795.77562600. The light will stay on when the doors are closed. It is not the door switches though. If you power cycle the unit, the problem will clear for a short time. Then the interior lights will turn back on. I have removed the bulbs (also melted the cover) to insure we don't lose anymore food porduct on the upper shelf and so that there is not a fire.
  • woodyj Nov 10, 2008
    We had the same problem and ordered several replacement parts and it did not solve the problem, so now we just keep the light bulbs out and use a dark fridge. Also (another problem) now the panel on the front reads DR ER and it won't beep when the door is open too long. We have only had the fridge for over a year and I think it was a bad purchase. We should not have this many problems this soon.
  • TigerSueLoue Jan 05, 2009
    My problem is the refrigerator shuts down keep getting the ER and the door stopped beeping. The bottom freezer works good.
    I unplugged it and tried the reset stuff but only to shut down and get ER light again
Call a service tech from Sears, this is a fire hazard,light control is bad,apparently, modification includes thermal switch,to turn off lights in the event of failure.
Posted on Nov 08, 2008
Have a tube w/rubber end hanging down in ice maker. Also a molded styrofoam w/ plastic loose in ice bin on model#253.70313211 French door bottom freezer. Wher does this belong and how do I fix it.
It fell of the bottom of your ice maker put your model number into repairclinic.com and you can find a pic or video that shows you how to put it back together
Mar 02, 2014 | Kenmore Bottom Freezer French Door...
Tip
Reduce risk of overheating and plastic melting if lights stay on
Even though I have found a statement (I think it was in the LG2.gif troubleshooting2.gif FAQS on line) that the lights in the newer LFX25960 french door/bottom freezer refrigerator will shut off after a period of time to prevent overheating and melting the plastic housing, I have heard of this problem enough times to worry about it. So I replaced the two 60 watt bulbs in my refrigerator with 25 watt appliance bulbs just in case. They provide more than enough light and do not get as hot when on. It took a while to find them. They are made by Philips2.gif and were at Home Depot but not always in stock.
on Sep 18, 2009 | LG LFX25960ST Stainless Steel French Door...
I have an LG refrig french door model LFX 31925ST/00. Purchased less than 2 months ago. The top plastic freezer door continues to get an ice build up on the front of the drawer only. Is this normal? ...
It sounds like a loose or bad seal on the top area of the freezer door. Use the old dollar bill test to see how good the seal is. Hold a dollar bill up to the seal and close the door. there should be some resistance. compare the resistance between the top and bottom of the door.
Nov 06, 2017 | LG Refrigerators
LG refrig with freezer on bottom, french doors Model #LFC237605SW lights went out - is there a reset button?
There is no reset button. Make sure the light bulb has not burned out. It's possible that ice has frozen the light switch. Use a hair dryer to the ice switch to see if it will melt the ice and release the switch. Good luck
Jun 19, 2011 | LG Refrigerators
I have a Kenmore Elite stainless steel three door refrigeator I bought it oct 07 at sears. This am I got up opened the refrigerator door and it was hot inside I think maybe the door was ajar over nite can...
Do you recall if the door opened easier than normal that morning? its possible, but not likely, that the door was open, but its kind of hard to make those frech doors stay open even partially. you may have a bad light switch not shutting light off. is any of the plastic around the light bulb melted?
I have to think its something with the light bulb, since you say it was hot inside. thats a far cry from the not really cold i normally hear from my customers.
some french door fridges use a sort of finger mechanism located at the top outer corner of doors, if this breaks, the doors might not close easily by themselves, or worse, not stay open. without personal inspection, i cant give definitive answer
Mar 01, 2010 | Refrigerators
Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator. One month ago the water tap stopped working then I noticied that the top doors to refrigerator would not reliably close like they used to. Last...
The water could have been frozen in the door and melted when your fridge warmed up.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 13, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Roaring sound
I have had the same issues. I have owned my LFX25960 for 18 months. All the cooling, noise, and condensation problems are related to 2 fans. One for the freezer/refrigerator compartments and One for the Ice Maker. The fans, apparently, are not sufficient to move enough air through the coils located behind a plastic panel in the freezer compartment. The part numbers for my fans are 1. Ice Maker 4681JB1029E and Refrig/Freezer 4681JK1004E. It is not impossible, but fairly difficult to replace them yourself. You have to remove the large slide out freezer drawer and glides. Then work the back freezer panel loose from the bottom. Be careful not to break it. It is plastic.
Routine maintenance: Pull the refrig out from the wall and blow-out the coils and fan located on the lower right rear. You might find it easier to do this by removing the cover on the lower, back of the refrig.
Apr 17, 2009 | LG LFX25960ST Stainless Steel French Door...
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Fridge on top of freezer is not chilling
if you have a french door (also known as bottom mount, freezer on bottom) and your fridge sections(cold air blows from freezer to refrig) is not cooling try this
1. ensure you hear the fan running, its it not, thats it(most likely fan motor
IF fan is running check these things
1. ensure refrig section light shuts off by holding down the switch
2. ensure door shuts
3. clean conderser coils (usually accessed from front through base grille)
4. check for icing in vents, freezer section contain them at top or back, and for a bottom mount the refrig sections vents are under your BIG drawer. if iced try a hair dryer from distance. or empty food into another fridge unplug open doors, and plug back in two days later this should defrost all ice build up
May 02, 2008 | Refrigerators
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
315 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
