Question about Sony Cyber-Shot DSC-P73 Digital Camera
Shutter stuck. The zoom lens comes out OK, but the shutter stays shut. Not been dropped, but lasy used in a severe rain and thunderstorm.
    Problem Solver:
  • 57 Answers
Hellow shutter stuck there is a flex moving circuit in the lens.by using long it get damaged it self.shutter assy depends on it to work n if is deffective,replacement required so no one help u by net.so u need a camera repairer.try near u.... thanks....
Posted on Jul 25, 2006
Shutter appears to be stuck closed.
Theirs oil on the shutter blades causing it to stay closed, Thats why you can't see though the lens or the viewfinder also, This comes from the grease from the zoom assy, It's a major job to fix it, Has to be fixed by a repair shop
Jun 04, 2010 | Canon PowerShot S3 IS Digital Camera
Can't fully see thru the lens
Look in the back where the film goes in. Are all the shutter blades flat and in place, or are they wrinkled or is one or two blades bent or out of place preventing the shutter from functioning fully? Put the camera in M focus and M exposure at about 15th, Fire the camera several times. If the shutter looks and works ok then take the lens off and look at the mirror. Fire the camera a few times. Doe the mirror go all the way up to the top and come back down, all the way? If so then the shutter would appear to work fine and the lens may e the problem. If the shutter or mirror box do not work correctly they will have to be repaired by a qualified technician.
Nov 19, 2009 | Minolta Maxxum 400si 35mm SLR Camera
LCD monitor is black
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Sep 07, 2009 | Canon PowerShot SD890 IS Digital Camera
Canon powershot s2 15 shutter won't open
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
May 10, 2009 | Canon PowerShot S2 IS Digital Camera
IR-300 Olympus
I had what sounds like the same problem. The camera was dropped and the shutter was stuck open. Just kept showing error message.
As I felt I had nothing to lose I began tapping it on a soft book and the shutter started to appear. I then shut it just using the end of my finger. When I then turned the camera on again it opened and shut when turned off. It has worked fine ever since.
Seems a rather poor design.
Hope this helps. Very best regards Peat.
Jun 05, 2008 | Olympus i:robe IR-300 Digital Camera
Lens cover stays open
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Oct 30, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Frozen lens and shutter
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 06, 2007 | Canon PowerShot A510 Digital Camera
Error-C1
Dirt /dust in the lens and lens gear box ( this drives zooming only ) preventing optimum functioning. Lens cannot properly come on line ( shutter and diaphragh mechanism then do not come on line ) and the camera switches off. Solution : is ether replace lens unit or dismantle lens to clean out ( from gear box and the helicoil of the lens ).
Sep 03, 2007 | Kyocera Finecam S4 Digital Camera
Zoom and shutter not functioning
that is a symptom of being dropped and stuck in a mode.
it requires total dissemble of the camera to fix or replace the lens. your lucky it takes pictures at all. most cameras refuse if the lens is stuck.
Jul 28, 2006 | Panasonic Lumix DMC-LC33 Digital Camera
Sony Cyber-Shot DSC-P73 Digital Camera Logo
110 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
