Question about Canon ImageRUNNER 1670F Copier
Replacement drum for a fax image model 1670F.
Machine states it needs a new drum. Got the drum but have no idea how to install it. Where is it located on the fax machine. Found the cartridge-but no drum.
  • 92 Answers
Hello
did you take the cartridge out?
if so you must separate the two things drum and toner.
Posted on Oct 21, 2008
How to remove konica minolta bizhub 184 error code m2 ?
Replace the drum and developer then run the F8, BUT first ensure the drum and developer counters are cleared first, The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Oct 14, 2015 | Konica Minolta Office Equipment & Supplies
M2 how to remove from konica minolta bizhub 184
How can i fix code error c2557
Have you had the developer and drum replaced or does the screen say Replace PC Drum? Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST. IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum. YOUR Code deals with the sensor located at the bottom of the image unit. Which monitors the Toner and developer mixture
Nov 14, 2014 | Genuine Konica Minolta Konica Bizhub...
Correcting please wait
model number would help, but i degress,
Sir/Mam,
Have you had the developer and drum replaced recently, or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum or next to it depending on the series. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure/Developer Charge, and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Jul 18, 2014 | Konica Minolta bizhub Office Equipment &...
Reset drum counter 130f
Do not reset drum counter unless the drum has been replaced.. IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Apr 17, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
How to reset drum counter on bizhub 200
Utility counter, details stop00 stop01. Counters. Has the drum been replaced? if not you reset the counter the machine will assume that a new drum is install and select the proper voltages for a new drum since the drum is not new? it might code and get poor image quality issues. Replace the developer with the drum. Machine uses the counters to determine setting in the machine, developer also has a counter. Does the front panel say replace PC drum? If so replace developer and drum and cleaning blade at the same time. You clear counters before pulling out the image unit. and you don't exit all the way out of service mode after clearing the counters you hit exit once the turn off main power, Rear left side. Once new drum and developer installed. RUN F8. Do not allow copies Prints or fax until F8 is run. Or start all over again.
Jan 03, 2014 | Minolta bizhub 200 All-In-One Printer
Waste toner full prepare new drum on canon iR1570F
The waste toner is part of the drum unit. You need to replaced the drum unit with a new one.
May 24, 2010 | Canon ImageRUNNER 1670F Copier
Cannon copier image runner 1670f
the machine have toner,can you print a document.replace toner
Nov 04, 2008 | Canon ImageRUNNER 1670F Copier
Canon Image runner 1670F will NOT receive faxes
scroll through menu and look for powersave options using keypad and display
Jan 15, 2008 | Canon ImageRUNNER 1670F Copier
I have a Canon Image Runner 1670F
That is a fuser problem,lamp,or thermister.
Jan 10, 2008 | Canon ImageRUNNER 1670F Copier
Canon ImageRUNNER 1670F Copier Logo
169 people viewed this question
old marine
old marine
