Question about Vtech EV2653 Cordless Phone (73507800685)
Add'l Phones Can I add additional phones? I'm having some problems with the base unit and was going to be a new set, which would include 2 more phones.
SOURCE: i want to add an additional handset to my vtech phone...the new handset is "searching for base" and requests a 15-digit number which is suppose to be on the base--there is no 15-digit number to input.
The 15 digit number shoudl be on a sticker on the bottom of the base unit.
Posted on May 19, 2009
0 characters
1 Points
Are thee any Binatone handsets compatable as extra handset to add to Binatone symphony 3325 unable to get new handsets but main answering machine and handset are still working
with cordless phones the problem is that the hand sets have to be recognized by the base station ( paired) and unless you have the exact hand piece make and model this pairing and recognition will not happen
if you can get 2nd hand units for the 3325 base then the base will accept them ( any number of additions ) but if the hand piece is different it will not work
you you need extra hand pieces then it may be best to consider a new system where you can buy extra phones and chargers
Jul 13, 2016 | Binatone Phones
How do I turn off the ringer on my Panasonic Telephone base?
It would help if you add a comment with the model number of your phone. For the KX-TG6572R, to set the ringer to off on the base, press and hold the Down button on the base until the phone beeps when the phone is in standby mode. Note: if the phone has an intercom mode, the ringer for the intercom is never silenced.
I hope this helps. If this procedure doesn't work for your phone, please add a comment with your phone's model number. Then, I will try to find additional information about the ringer volume control for you. (I know some phones have a physical switch on the base for the ringer volume.)
Jul 08, 2015 | Panasonic Phones
How can I add a 4th handset to my Motorola L603M?
I think you all totally missed the question. The phone set comes with the base and 2 extensions. He is wanting to BUY a 3rd extension for this unit, if I am reading this correctly. I have the same phone set and I have not found anywhere that sells additional handsets. Sorry.
Nov 22, 2012 | Uniden Cordless Phone
I have Uniden DECT1480-3. I purchased two expandable handsets, but I cannot figure out how to get the new handsets to register with the base unit.
Up to 6 handsets can be registered with the DECT 1480 phones. I have the 5 phone unit and needed to add the 6th phone. All I got was "Searching" in the display and the battery wouldn't even charge!
So here's what you have to do to get additional phones (up to 6 units) to work with the base. If you can get past step 1, it's a snap...
Step 1: Place a charged battery in the handset. This could be a problem if all your handsets are not registered, since unregistered phones don't charge (who thought of that design?). What I did was SWAP the battery from an already registered and charged phone with the new unregistered phone.
Step 2: Here's where the magic happens. Press the 'END' and '#' keys simultaneously... hold them down until a System Reset menu appears. Select "Deregister HS" and press Menu.
Step 3: Now, do the same thing again (hold down END and #), but this time select Base Unavailable and press Menu. You will see Base Unavailable Yes/No... Select Yes. Then place the handset in the base, wait a few seconds, and Voila!. it's registered. You can even change handset numbers using this menu if you play around with it.
Thank you, helpful employee at Costco for supplying the magic code. And hey there, UNIDEN... including this in the operation manual would have saved many customers much grief with de-registered phones!
May 14, 2011 | Uniden DECT 6.0 Cordless Telephone...
How do we add additional handsets to a vtech 6.0 phone?
search through the menu's for the base unit - and you should come across register handset - choose yes or accept ?
on the new handset you should also see register handset do the same select yes and the 2 should see eachother and link to one another
May 08, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
I bought 2 sets of the uniden DECT 1480-3. I want 6 handsets to work with one base. How do I add 3 handsets to a base that already has 3 handsets?
The only logical way is to get the additional handsets to communicate with the base. And to do that you must set them to the frequency of the base. You Use guide will tell you how to set the frequency n the handsets to talk to the base. They way you set the original ones.
BUT, I doubt if this will work. Why? Because if that was the case if you and I had the same company phones, then I would stand outside your home and set the same frequency on my handset and misuse your phone. A great security risk in today's world. But there is no harm trying it out. Just set the same frequency on the additional ones as the base. If it works, then you will have that many more intercoms too. And do let me know if it works.
Apr 11, 2011 | Uniden Additional Handsets - DCT640 Phone
It said base no power
Remove then replace the batteries from the hand set. You should now get dial tojo.
Oct 25, 2010 | Panasonic KX-TGA101S Cordless Handset
Sync a new handset to kx-tg5632 phone
This works on MY panasonic; May work on yours too!
Registering a handset
The included handset and base unit are
preregistered. If for some reason the
handset is not registered to the base
unit, register the handset.
1 Handset:
{MENU} i {0}{0}{1}
2 Base unit:
Press and hold {LOCATOR/
INTERCOM} until the IN USE
indicator flashes.
LAfter the IN USE indicator starts
flashing, the rest of the procedure
must be completed within 1
3 Handset:
Press {OK}, then wait until a beep
4 {OFF}
Registering an additional handset
See page 5 for information on the
available model.
Start from step 2.
Dec 29, 2008 | Panasonic KX-TG5632 Phone
No, you cannot add a set to this phone. But if you are going to up grade then buy one that says expandable. KXTG5433M has only 3. Some Expandaables can have up to 10 or 12.
Feb 07, 2008 | Panasonic GigaRange KX-TG5432 Cordless...
Vtech EV2653 Cordless Phone (73507800685) Logo
37 people viewed this question
Top Vtech Phones Experts
Are you a Vtech Phone Expert? Answer questions, earn points and help others
