Question about Whirlpool Microwave Ovens
Hi. I have a 1996 Built-in Whirlpool Microwave (#MH7115XBB-5) Once I set a time and power setting, this built-in microwave will start. After one (1) second there are sparking sounds and then a real strong electrical burning smell. I do not believe there is any 'arching'. I have replaced the thermal fuse over a year ago. Let me know if you need more details. Thanks, Rick
  • 1 more comment
  • Sparty899 Oct 24, 2008
    I will try that, but can you direct me towards the waveguide cover?
    Thanks
    Thanks. I will do those things this weekend.
  • William Miller
    William Miller May 11, 2010
    Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
    Did you check that?
    You can usually find helpful exploded view diagrams here.
    Whirlpool customer service is here and you can also enter your model number on that page to download your owner's manual, installation instructions, etc.
    Let us know what you find out, and if it seems like you have electrical problems, we can take it from there.
  • Whirlpool Master
  • 9,086 Answers
Thewaveguide cover (also called a spatter shield) is usually about thesize of a playing card and often held in place by a plastic rivet.
In some models it is a larger stirrer cover type made of thicker plastic in the ceiling of the oven.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
Posted on Oct 24, 2008
How do I turn on the microwave and set the clock
well setting the clock comes first if my memory is right
Jan 14, 2016 | Microwave Ovens
Whirlpool GH5184XPS-7 microwave oven dead, no power.
The problem is in the magnetron or the inverter board.
May 27, 2012 | Whirlpool Microwave Ovens
Whirlpool microwave
    • 1 Press the "Clock Set/Start" or "Clock" button on the control panel.
    • 2 Enter the time of day using the number pad, or use the "+" and "-" buttons to scroll to the correct time.
    • 3 Press the "Clock Set/Start" or "Clock" button once again to save the time.
Apr 11, 2012 | Microwave Ovens
Not heating
Hello
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
Repair
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
Oct 05, 2011 | Sanyo Microwave Ovens
Whirlpool Microwave Oven Model MH7115XBB-2 but does not heat food.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
u
Jun 11, 2010 | Whirlpool MH7140XF Microwave Oven
Microwave started making slightly louder noise now will not heat
either the h.v. diode or the h.v. capacitor are open and replaced they build the hi voltage needed by the magnetron tube assembly
Oct 07, 2009 | Whirlpool MH7140XF Microwave Oven
Does a microwave lose cooking power over time? having a problem cooking popcorn. whirlpool built in unit 18 yrs old. takes 4-5 min on high and cant cook most of it. more time just burs popcorn. i believe...
Yes. As the magnetron (The microwave generator) ages with use it becomes less efficient. As such it produces less powerful microwaves and loses penetrating power:::Spiceweasel.au
Apr 04, 2008 | Microwave Ovens
Panasonic Microwave Dimension 4 convection (11 yrs old)
You need to press clock 3 times, then start 3 times and then clear/reset 3 times. Then you can reset the clock by pressing clock 1 change the time and press clock again.
Mar 11, 2007 | Panasonic NN-T888S Convection/Microwave...
Microwave Ovens Logo
136 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
