Question about Philips FWC155 CD Shelf System
Fm reception going in and out also strange noises
I mistakenly hooked up the am loop antenna to the fm side. The FM radio will play briefly but after a few minutes it will start emitting strange noises out of the speakers. I have tried several antennas but nothing worked. Have I fried something?
    President:
  • 3,130 Answers
Hooking up the AM antenna loop should not have fried anything, as I know lots of peeps who have done that. The FM RF amp. sounds like it may be at fault. The only way to tell if its bad is by hooking up an RF generator and I would be surprosed if you had one of those laying around. Disconnect the unit and take it to a repair shop.. If its an older model Time to get a new one. Good Luck
Posted on Jul 23, 2006
SOURCE:
There is no electrial retailer in bendigo that has fm aerial to suit this is why i am asking you
Make your own.
  • How to Make an FM Antenna: 8 Steps (with Pictures) www.wikihow.com/Make-an-FM-Antenna
    • 832K VIEWS
    2016-01-11 · How to Make an FM Antenna. Improving the reception of commercial FM radio (88Mhz - 108Mhz) can be done by you at home, simply by replacing the antenna ...
  • Simple FM Radio Aerial - Robert Sewell www.robertsewell.ca/yahoo/fmaerial.html Simple FM Radio Aerial A simple FM radio aerial can be made using about 5 feet of old 300 ohm TV downlead, an alligator clip and some hook-up wire.
  • Or try Jim
  • Antenna Installation Bendigo
    May 23, 2016 | Audio Players & Recorders
    I have a old pioneer stereo double cassette deck reciever model # RX-Z15, i dont understand the bal/unbal fm antenna hook ups cant get reception , need to know where to hook up the antenna or what kin
    Buy a 300ohm FM Y antenna wire screw the spade ends into the balance hookup and fasten the Y section on your wall, "higher the better" this will improve reception. The antenna can be purchased at Radio Shack or Tv repair shop.
    Apr 20, 2012 | Pioneer Audio Players & Recorders
    I can't get the AM radio to find a signal. All other components work fine.
    Hello
    If you get FM radio stations, and only AM reception is immpossible, check whether AM loop antenna has connected to the respective poles at the back side. If it is connected, and still you do not get the Amplitude Modulation [AM] signals, check the input settings of the device is correct to recive AM. There will be a slelection option, for AM & FM. OK.
    Jan 22, 2012 | Audio Players & Recorders
    Sanyo dcx686 am/fm amp receiver no fm reception
    you should be able to hook up any am/fm antenna, like the new ones that come in a square and hook it up to the two left-most spots for a radio antenna, thats how i have mine. as for the manual, you can order them off of a site(if you can find a reputable one) if you search SanyoDCX686 on google. hope thats somewhat helpful =]
    Dec 14, 2011 | GPS
    Am fm reception bad
    FM reception is weak
    What to do
    • Extend the power cord as much as possible. The FM antenna is in the power cord.
    • Move the power cord to adjust the FM antenna
    • If you still have problems with FM reception, you may need an external antenna.
    * Call Bose®Customer Service to request one.
    The external antenna on your radio is a coax (round) design It needs an adaptor and an antenna which are cheap.
    Easy to make, radio shack "F" connector 90 degrees or straight, to 300 ohm wire connections. Attatch a 300 ohm flat ribbon antenna cable to those two screws and plug into radio and see how your reception is. You will need to position the antenna wires to get best reception. I have hid them in back of paintings and so on.
    Cheapest solution next to putting an extension cord on radio power cord.
    Jan 03, 2011 | Bose Wave Radio
    Am/fm radio stations not clear... I have the AM antenna attached... but there is no attachment for FM
    First of all check for any nearby source of interference.....Move your unit away from all computers, fluorescent lights, neon lights, microwaves, cell phones, and cell phonemag-glass_10x10.gif chargers. These devises tend to produce noise in the medium frequency band, where AM radio is broadcast.
    If the unit plugs into the wall with a nonpolarized plug (where both prongs are the same size), try reversing the plug inmag-glass_10x10.gif the outlet. Moving the plug to another outlet might help, too.
    check for fault in the antenna lead, (common) or bad earth on the antenna to body
    If you don't have an antenna connected to your FM receiver,With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 2 If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
  • Step 3 If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
  • Step 4 If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
  • Step 5 Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
  • Read more: How to Strengthen FM Radio Reception | eHow.com http://www.ehow.com/how_114024_strengthen-fm-radio.html#ixzz0u9nhGXAL
    If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters. Make sure to Switch from stereo to mono.
  • Step 4 With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 5 Alternatively, upgrade to a third-party passive or powered antenna.
  • Step 6 Install a rotatable roof antenna for the best possible reception. Connect your unit to an existing televisionmag-glass_10x10.gif roof antenna for the next-best alternative.
  • Read more: How to Improve FM Reception | eHow.com http://www.ehow.com/how_5554_improve-fm-reception.html#ixzz0u9oTaz4Y
    Jul 19, 2010 | RCA RT2760 System
    FM reception for Sony ICF-CD513?
    The electrical cord acts as an antennae for this radio. Uncoiling the cord will give the best reception for FM. Rotating the radio (and built in ferrite bar antennae) will give the best reception for AM listening.
    Jan 31, 2010 | Sony ICF-CD513 Clock Radio
    JVC detachable face with auxillary input
    You may have a bad antenna or antenna cable.
    FM signals are measured in microvolts and are easily influenced by poor antennas or a mashed antenna cable.
    Aug 12, 2008 | JVC AM FM CD DET FACE CAR STEREO
    Better fm reception
    Is it just a single wire?
    If so, purchase a cheap FM antena. It looks like a "T" when spread out (4' to 5'). That should help.
    You can purchase an "amplified" antenna, but if your area reception is really bad (such as in a valley) the antenna would just amplify the noise as well. Look for web based radio in this case or if you have cable there are stations on it.
    Jeff
    Jan 11, 2008 | GPX HM3817DT Shelf System
    Philips FWC155 CD Shelf System Logo
    139 people viewed this question
    Top Philips Audio Players & Recorders Experts
    Gyula Lacz
     Grubhead
    Grubhead
    Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
