Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Saeco vienna "machine ready" light (second light) blinking--not allowing to dispense coffee.
seaco vienna , same problem like above, but cold water coming out. My guess is heating element. Am I right ?
Posted on Nov 06, 2008
  • 515 Answers
Try to open the steam knob and make a cup of water(Tea).
Best regards
/Mirran
Posted on Oct 26, 2008
I own a saeco Vienna 'limited edition'. When making coffee, the cycle stops when the water pump starts. Coffee light blinks and the red light turns on. It started when i tried to use the steam...
Hi. Sounds like a blocked or jammed brew unit. Remove brew unit and clean. To properly do this, you need to disassemble the brew unit. Canbe quite hard to do. The brew units are usually held together with plastic tabs, and may have to remove some screws to allow these tabs to release units assembly. Dazza REPAIRER
Sep 24, 2011 | Saeco Vienna SuperAutomatica Coffee...
My Saeco Vienna Black Automatica Espresso maker will grind coffee only about one-fourth of the time. Other times, it makes whirring sound and then shuts off and red "coffee bean" light comes on.
Your grind is to fine. Turn the big knob in the bean hopper up 4 clicks and try again. It could be oily beans which would require the same solution.
Nov 02, 2010 | Saeco Vienna Espresso Machine
Saeco Vienna coffee when the machine starts the coffee dispensing
Is it leaking only when brewing coffee ?
If not I would check the seal under the water tank (Part #NM05.006)
If so, I would check the following:
1- The water input port on the back of the brew unit (looks like a smoke pipe) might be clogged
2- The o-ring of the water tubes coming in and out of the boiler.
Jul 30, 2010 | Saeco Vienna SuperAutomatica Coffee...
Brew light blinking
It is telling you that the temp on the machine is too low. It is possible that one of the thermostats on the boiler is damaged.
Sep 13, 2009 | Saeco Vienna Espresso Machine
Saeco Vienna Coffeemaker won't heat/reach 'ready' state
May be time for a new machine.
Its either the electronics or the boiler, or worse. Both.
Vienna's have a typical life expectancy of about 4 to 7 years. 10 years is very commendable.
If the electronics and boiler are both bad it will end up costing almost as much as purchasing a new machine.
Aug 08, 2009 | Saeco Vienna De Luxe Espresso Machine
No Coffee dispenses
That is exactly what I would've suggested, the brew unit is clogged. remove brew unit and try to blow through the top, if you get through then check the bottom. One of the chambers must be clogged. Another question is the coffee extract wet or dry grounds?
If wet then the block is on the top, if dry it ids on the bottom.
Feb 28, 2009 | Saeco Vienna De Luxe Espresso Machine
Coffee dispenses extremely slow
try to change the grinder to little more coars, if it not help then i think it can be something with the printed circuit card.
Best regards
/Mirran
Sep 21, 2008 | Saeco Vienna Espresso Machine
SAECO TREVI NO HOT WATER
It would be cheaper to check the thermostat and heating element first and the wiring continuity, although I am not sure if you can find the replacement parts. If you can't, then it looks like you have no choice but to replace the entire assembly.
May 19, 2008 | Saeco Vienna De Luxe Espresso Machine
2nd light will not stop blinking and allow us to make coffee
Try to open the steam knob and make a cup of water, you have to fill upp the boiler with water.
Oct 31, 2007 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
232 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
