Canon MF8170C Error E000 - Office Equipment & Supplies
  • 76 Answers
This is due to the Fuser Unit, could be fuser sitting out of line or connectors, if not then it could be the fuser unit it self such as thermistor. I would remove it and resit it and then see what happens, if not replace Fuser,
As worse it could be down to the lower voltage power supply but as yet i have never had that problem!
hope this helps
Posted on Oct 21, 2008
Canon D340 Copier System Error E000
Your printer show Error code E000 suggests the problem history has recognized all of these of the following error codes four moments: Error code E001;Code E002;Error E003. Printer Canon E000 error will be removed in the service mode.
Please try reset factory your canon printer..but if it still show error code E000 again ,you can try with a genuine fuser unit (reseting fuser unit). Good luck
Solution 3: Try this, atempt will clear canon E000 code in Service mode:
1.Press ADDITIONAL FUNCTIONS, #
2.Go to #7 Printer and Press OK
3.Go to #4 Printer Reset and Press OK
4.Yes = ( * )
Sep 09, 2010 | Canon PC-D340 All-In-One Laser Printer
I am getting an error message - E071 on the MF8170C. I have no idea what it is.
I also had this error message. Cleaning contacts and restarting made me able to copy/print.
Aug 18, 2010 | Canon imageCLASS MF8170C All-In-One Laser...
System error E000
A E000 coeds means the error history has detected any one of the following error codes 4 times :E001;E002;E003.
The error can be cleared in the service mode.
Contact Canon Consumer Products 800-828-4040
Mar 24, 2010 | Canon imageRUNNER 2010F Copier
System Error E000
This is a fuser error, you can try unplugging the machine and plugging it back in and this might reset the error, however if you try this and the error code pops up again, it could be one of the following which would require having the machine serviced and repaired by a professional. The fuser thermistor could be open or the heater lamp could be open or the thermal fuse that prevents the fuser from overheating could be open.
Sep 03, 2009 | Canon imageCLASS MF8170C All-In-One Laser...
CANON NP 6220 ERROR "E000"
replace the fuser lamp or the thermofuse.
E000 fuser problem.
Dec 12, 2008 | Canon NP 6050 Copier
How to reset error code E000 on IR2000
E000: Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000.
Jul 11, 2008 | Canon Office Equipment & Supplies
System error
Go to this link: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=239&modelid=10561 In the "please enter your question" (gray bar area) type in E000. It will give you three options for resetting the machine. If these don't solve it, you'll need to replace the fuser (fixing) assembly.
Jul 29, 2007 | Canon imageCLASS MF8170C All-In-One Laser...
165 people viewed this question
jasbo
jasbo
