Question about Philips FS3262A TV
How many lines of resolution does this tv have? is it HD ready?
All I am asking about is lines of resolution. how many does a FS 3262A magnavox have ?
3 Suggested Answers
  • 4234 Answers
SOURCE: HD tv changes
The changes that you mention will only effect you if you use either rabbit ears or a rooftop antenna. The over-air broadcast signals are being changed from analog to digital. If you have cable or satelite service, there will be no change.
Dan
Posted on Nov 13, 2008
  • 11 Answers
SOURCE: magnavox 37MF331D/37 keep asking for software upgrade
Your set either has a bad SSB (small signal board) or needs a software upgrade. Try the upgrade first by going to http://www.m4c.magnavox.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=FLAT_TV_CA&sct=LCD_LARGE_30_40_SU&grp=TV_GR&session=20090830171041_4.131.87.247&ctn=37MF331D/37&mid=Link_Software&hlt=Link_Software
Download the latest software release for your set then follow install instructions that are contained in the user manual for your set.
Posted on Aug 30, 2009
Records & dubs but very poor resolution
You've got a Dish Network's HD DVR and a Toshiba 720P HDTV - so this part of the mix will maintain the HD pictures and high quality digital audio that you're used to seeing.
The trouble begins when you introduced the Magnavox VCR / DVD device. The highest quality video content that this device can record is the 480 type, regardless of the input or source quality - which in your case would be 720P via HDMI cables. 480 is considered "SD" or "standard definition". This is the weakest link in your setup and is responsible for your unsatisfactory results.
The Magnavox will "upconvert" to 1080 lines of resolution. The key here is the term "upconvert" True HD recordings are taken of a scene and capturing either 720 or 1080 lines of resolution in the image or video (such as a camera taking a photo or video); or recording the playback of a previously recorded 720 or 1080 lines of resolution source. Recording a 480 lines of resolution source with a an 720 or 1080 lines of resolution device will not make the image HD. The recording can not possibly be better than the original. In fact, due to losses, each generation of copy becomes worse and worse. Upconverting simply "fills in" the missing parts between the 480 source and 720 or 1080 output with what it "thinks" is missing data. The results are what you see on the screen. The original capture did not save more info that 480 lines of resolution so it is really impossible to improve it.
The recording can not ever exceed the quality of the original (the Dish Network DVR at 720 or more) and will only be as good as the weakest link (the Magnavox DVD / VCR at 480). Additionally, the moment you change from digital to analog, you lose quality instantly. Digital signals - both video and audio will always be faithfully reproduced do to error correcting technology, etc. that simply isn't available in the analog world.
You need to use a digital recorder capable of capturing and playing back of 720 or 1080 lines of resolution video and AC3 audio for optimum video and audio on a Blu Ray recorder or other device with hard drives or memory such as MP3 recorder. Otherwise you'll have to accept reduced quality of standard L & R analog audio and 480 lines of resolution of SD video. You can not expect HD audio and video if you try to save to equipment designed for SD / analog.
Dec 19, 2013 | Magnavox ZV427MG9 DVD Recorder VCR
Is this a HD ready tv if not what would help?
Based on the specs for the TV, the DS31520 is not an HD-ready display. It is at best an SD display with an NTSC (analog tuner). (Picture resolution: 330 lines, video input 660 lines) OTA ATSC signals are 480i (SD), 720p or 1080i (HD) where those are the number of horizontal lines of pixels. The manual is available here: http://www.sanyotv.com/DS31520%20%28ESF%29%203178--.pdf .
This is a fine TV for analog cable or OTA TV with a standard digital to analog converter box (which only give SD output). The TV has composite video and S-video inputs (again limited to SD).
For HD, you will need a new TV screen that can display more rows of data.
I wish that I had better news for you.
Dec 18, 2011 | Sanyo DS31520 31" TV
Trying to use ps3, even after using hdmi cable on input 6 or 7, it says check your device output and i see green lines on my screen?
hi
There maybe some problem with your TVs resolution. ps3 outputs full hd high resolution video(1080p) through its HDMI. May be your TV is not supporting that resolution. Connect ps3's component video out to your TV's component video input and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution your TV will not support. Your tv is hd ready one, not full hd. ps3 's HDMI out is full hd (1080p).
or try this
Connect your ps3 to any full hd tv and then goto video setup of ps3. change resolution to 1080i (down scaling ). then connect to your TV via HDMI. surly u will get the video.
ok
Jun 09, 2011 | Sony Grand WEGA KDF55E2000 55" Projection...
Ps3 hdmi is saying format not supported on my 32"
hi
there maybe some problem with ur tvs resolution. ps3 outputs full hd high resolution video(1080p) through its hdmi. may be your tv is not supporting that resolution. connect ps3's component video out to ur tv and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution ur tv will not support. ur tv is hd ready one, not full hd. ps3 's hdmi out is full hd (1080p).
or try this
connect ur ps3 to any full hd tv and then goto video setup of ur ps3. change resolution to 1080i (down scaling ). then connect to ur tv via hdmi. surly u will get the video.
ok
Dec 14, 2010 | Emerson LC320EM9 32 in. LCD HDTV
How does it help to have a Full HD LCD TV?
Hi - welcome to Fixya,
There is no advantage in buying a Full HD (1080p) TV if you are only using it for watching TV. Currently, there are no Full HD television broadcasts and there are no plans to introduce any. All UK HD channels currently broadcast in 720p resolution whether they are on Sky, Freeview, or Freesat. Therefore, any TV that is described as 'HD ready' rather than 'Full HD' will display all HD channels at maximum quality or resolution.
The advantage of Full HD is when using them with Blu-ray DVD players, gaming systems, e.g. Sony Playstation, or for playback of media files from your PC. These systems output at 1080p / Full HD (but only when connected with an HDMi cable) and you would need a full HD TV in order to get the best quality / resolution from these systems. However, you don't need a Full HD TV to connect these devices as they can all display their output on a 720p HD Ready TV.
The main disadvantage of any HDTV (1080 or 720) is when watching standard definition (SD) broadcasts. Full HD TVs have 1080 horizontal display lines, but SD broadcasts only have 540 horizontal lines. When watching SD channels on an HD TV, the other 540 lines, i,e half of the picture, are being created by software within the TV - known as 'Upscaling'. Upscaling requires processing by the TV which takes time and fast motion can seem blurred or blocky/pixellated as a result. Higher end TVs have faster response times (0.5ms or less) which minimises the pixellation so this specification is important when selecting an HD TV for purchase.
Hope this helps.
Regards,
BElectric
Nov 18, 2010 | Samsung Televison & Video
Sansui tv dtv2784
No this TV is not HD ready. However it is digital (ATSC) ready meaning now that most of the analog brodcasts have stopped it will receive the digital broadcasts so you don't need a converter box. Since it can only display 480i resolution it is not HD ready. You would need a TV that can display 720p or better to be considered HD ready.
Jan 04, 2009 | Sansui 27" TV
36A50 Digital ready?
Hi duce1500,
Unfortunately, the 36A50 is not HDTV-ready. That means you will need a converter box. Here is a link to the model's specs, which includes this information:
http://www.amazon.com/Toshiba-36A50-36-TV/dp/tech-data/B00004YMBV/ref=de_a_smtd
I should mention, however, that if it's connected to cable (or certain satellite services), you won't need a converter to watch the TV - you'll receive the digital signal (although you won't have the 1080-pixel HD resolution - the 36A50 only has 850 lines of resolution).
I hope this helps. Please let me know if I can be of any further assistance.
H2H
Dec 13, 2008 | Toshiba 36A50 36" TV
Hitachi 53SDX89BA HD settings
Problem more than likely with the xbox, as the output stream of data from the game platform is not always consistent...accordianman
Dec 29, 2007 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 53SDX89BA
I also have a Hitachi 53SDX89BA and I bought it with the same assumption as you: that it's HD ready. The specs in the manual states the following: "Full 1080i HDTV Capatable with Set-Top Box". I beleive this means that it does not include an HD tuner, but that it is capable of handling up to 1080i resolution. Normal (non-HD) resolution on this TV is 480i.
So here's my problem: Until recently, I wasn't using the HD settings on this TV because I don't have a set top box, nor do I subscribe to any HD content from my cable provider. However, I just purchased an XBox 360 along with an XBox 360 HD-DVD player (it's an XBox peripheral that works with the game console). The Xbox asks you to choose the resolution output (480i, 720i or 1080i) to match your TV's HD capabilities. When I select 1080i output and change my TV's settings to receive an HD signal, the picture quality is amazing. However, the video signal seems to get lost ocassionally (i.e. TV picture gets scrambled) but then it comes right back. This does not happen when I select a 480i output on the Xbox...but of course, the picture isn't as crisp and clear as a 1080i picture.
I don't know if this is a problem with the TV or with the Xbox. Has anybody else had this problem??
Dec 06, 2007 | Hitachi 50UX57B 50" Rear Projection...
Hd ready?
On any High Def TV, the reciever you need for this set, which does not have a HD receiver in it, is half the equation. Most HD channels have some HD content mixed with SD content on the same channel. SD content on HD signal from cable or satellite tends to be slightly blocky due to the native signal resolution and the resolution of HD (1080i/p or 720i/p).
Apr 30, 2007 | Akai PTH5498 54" Rear Projection...
Televison & Video Logo
57 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
