Question about Olympus Camedia C-60 Zoom Digital Camera
Menu will not display
Camera will take pictures and LCD screen is working, put arrow pad is not working. The menus will not display, therefore you can not do anything! I can not download my pictures to computer because you need to use the menu pad. The camera has not been dropped or damaged recently (it was damaged by water 9 months ago, but repaired by Olympus and has worked fine since then). The xd card did have a virus on it just before this happened (Brontok) but was removed with anti-virus program as soon as it was discovered. Is is possible for a virus to infect the internal workings of the camera? This has just occurred this past week. I can not be positive it wasn't doing this before the virus, but I don't think so. Thank you.
    Problem Solver:
  • 57 Answers
Hi, as you said, you got your camera repaired in olympus.If your camera is in guarantee period, istrongly suggest to go to olympus again.I also think as per our experience that virus can't affect the menu pad or arrow keys. I think the delicate circuit attached with mode sw ond arrow keys will be damaged. so go to olympus now. good luck...
Posted on Jul 27, 2006
SOURCE:
LCD Screen
Your camera is working exactly as SLRs have worked for the first half-century since their invention. You frame the picture through the viewfinder then take the shot. The display is for menu settings and reviewing pictures after they've been taken. Newer DSLRs will let you use the display for picture-taking (and take videos) but the A200 belongs to the previous generation.
Mar 26, 2014 | Sony Alpha DSLR-A300 Digital Camera
Takes pictures but you cannot see image in lcd screen
This model only lets you see the image in certain modes. Test if it is properly working by changing the image mode to "P" and pressing the "Set" button (its in the middle of the arrow keys if you're having difficulty finding it. That should display the image on the LCD screen.
If that doesn't display an image, press "Menu" (upper left hand corner) and press the right arrow 4 times to get to the wrench with two dots menu (says "LCD brightness" on the first line. Press down 5 times and select Live view function settings and press "Set". Make sure the first line is set to enable. This should resolve the issue.
Please leave feedback if this was helpful, thanks.
Apr 18, 2011 | Canon EOS Rebel XSi Digital Camera
Outdoor pictures give white display on screen
Go to the menus and reset to default or factory settings. Make sure that the white setting in the picture adjustments in the menus are set to zero or you may have to adjust + or - to get the normal effect again.
Test the camera by taking pictures and saving to a sd card. Then put the card in a card reader/writer which is connected to the computer. Copy the pictures or files to the computer and view them to see if they are in good shape or if there is some problem with exposure or the way it looks.
If the computer pictures show that they are good, and they are not showing good on the camera LCD, then the LCD has a problem, and is possibly either cracked or has some other display problem.
These LCD screens are not that hard to change if you are good at working with small items and screws. If you do this, make sure you have a way to remember where you got each screw, as they can vary in size and kind.
Apr 15, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
When looking through the display screen the picture has a pink tinge. When reviewing the pictures they're definately pink in colour, especially the blues.
Try taking pictures and download them to a computer. Check the colors and evaluate the quality compared to what you have seen in the LCD display.
If the pictures are good and the colors seem to appear good on the computer, then some thing is either not adjusted correctly for the LCD or you may have a menu setting which is incorrect. Check all setting in the menus.
Test the camera again, and see what the colors look like in the LCD display.
If both the LCD display and the pictures on the computer are the same, then some problem exists in the camera, and may need fixing, or sell on a site such as Ebay for parts or repair as is.
Oct 25, 2009 | Sony Cyber-Shot DSC-T33 Digital Camera
Black screen
Try cycling through the Display button until you're able to view photo to be taken.
May 06, 2009 | Sanyo VPC-S500 Digital Camera
Olympus Stylus 1030SW. The LCD monitor is pixelated. The pictures that are taken with the camera are crisp and perfect. When reviewed on the camera, they are very pixelated. When searching through...
You can try to reset the camera to factory defaults to see if this improves the monitor. You go to Menu and then left arrow to Reset and press Ok. Up arrow to Yes and Press ok this will put the camera back in factory default settings. If the screen still shows as pixelated, you might try to do a function of the camera called Pixel Mapping. Go to Menu and then right arrow to Setup then down arrow to Pixel Mapping - right arrow to Start and then the camera will try to repair the CCD processing chip inside the camera. If after this completes if the screen is still pixelated, then you want to send it to an Olympus service center for repair.
Aug 30, 2008 | Olympus Cameras
Nikon D40
While viewing the picture press the up arrow on the arrow pad. It will scroll through the index (the one you are stuck on), highlight, histogram and then back to normal view.
Jun 08, 2008 | Nikon D40x Digital Camera
Coolpix s6
You should be able to turn the screen on while taking pictures so that you can see what is going on a little easier. Here is a link to the manual where you can find where in the menu to turn the LCD on. I tried to get the manual for myself so that I could give you page numbers and such, but it requires that i give a serial number number off the camera, so be sure to have your camera handy when you do this.
Aug 27, 2007 | Nikon COOLPIX S6 Digital Camera
Redeye
Red-eye is actually caused by the light from the flash bouncing off the back of the retina and picking up the color red from the blood vessels. To correct this effect, follow these steps: Turn the mode dial to PlayBack Mode (green arrow) and display the image with redeye. Press OK\Menu button. Using the arrow pad, navigate to MODE MENU>EDIT>REDEYE FIX. Press the right arrow key, START will display. Press OK\Menu After {BUSY} bar displays, a screen will display with an option to cancel or save the image. ? If the option [Go] is displayed, press the OK\Menu button. This saves a corrected version of the image. ? If the option CANCEL is displayed, than the camera was unable to correct the image. Press the left arrow key to exit. This correction may not work on all pictures. If you import the original image into Olympus Master software you can also apply the Red-Eye fix located in the Edit menu. This lets you precisely pinpoint the eye area and remove the red. It even lets you remove green or blue, which can occur with animals.
Sep 04, 2005 | Olympus C-7000 Zoom Digital Camera
Redeye
Sep 04, 2005 | Olympus Camedia C-5500/C-55 Sports Zoom...
Olympus Camedia C-60 Zoom Digital Camera Logo
62 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
