Question about HP DeskJet 3940 InkJet Photo Printer
Printer need to start pinter spooler
    An expert whose answer gotĀ voted for 100 times.
  • 201 Answers
1) Click the Star>Run, type in "Services.msc" in the Run dialog box.
2) A services window popup, find the service name "Print Spooler", double it and change the Service Status to "Start".
Now u can use your printer now.
YBC (/\)
Posted on Nov 12, 2009
My printer just worked 2 days ago.I keep getting a messageof of a paper jam.There is not one,. Also get message that the cartridge is stalled/
Posted on Jan 09, 2009
Where i could see the printer spooler?
I open the run command you can type: net start spooler
(You will get a message that says the print spooler service has started)
If you still have issues open the run command and type: services.msc
it will display a list, where you can find print spooler.
From there you can right-click on it and set it so it is started and runs automatically.
If you need any technical help on printer then you can reach at
Jan 25, 2013 | Canon PIXMA MP287 ALL-IN-ONE INKJET...
Print spooler not working
If your OS is windows 7, Click start, on the search bar type services, Pick the services and scroll down to Pinter spooler. Confirm that the spooler is started. if it is not right click the printer spooler service and start it. Else reinstall the printer driver.
Nov 23, 2011 | Dell Dimension E520 PC Desktop
Pinter ink symbols had question mark. Did spooler stop and start. Question marks gone but still not printing.
First remove both cartridges clean the gold plated area and the area where the ink goes out as well as the area where you plug it in ...And then turn it off first and then it turn it back on the open the cover wait for the cartridge carrier to go to the cetner and then install the cartridges make sure its properly plug in after plugging it in . lock the lever of carrier and close the cover .. Try to check if it will print print a test page . If nothing happens uninstall and reinstall the drivers
May 15, 2011 | Lexmark X4650 InkJet Printer
Trying to print which it won't. It says that the printer spooler is not running and that i need to restart the spooler or the machine...i have no idea what the spooler is but i have unpluggd the printer...
From the Start menu, select Control Panel. Then follow this path:
Administrative Tools > Services > Print Spooler
Once at the Print Spooler, right click on it. Select Stop. Leave this window open. Turn off your printer.
At the open Print Spooler window, right click on the Print Spooler, and select Start.
Go to the Start menu, and select Printers & Faxes. Find the printer you are having problems with and double click on it. From the menu, select Printer, then select Cancel All Documents. The documents should clear.
Turn on your printer. You sould now be able to print.
Jul 11, 2010 | Computers & Internet
Pinter Mamory full
Hi there
You can try see if this may do it.
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 21, 2010 | Epson STYLUS R230 InkJet Photo Printer
HP laserjet 2600N print job stuck in the printer queue server 2003
  1. Hit start on your Windows and click 'run'. Type in cmd this will open the old version of what many call MS-DOS or C prompt.
  2. At the C command type: net spooler stop
    You will get a message when the spooler has stopped. Now you need to clean out the queue.
  3. Go back to start menu and click on run again. This time type:
    %SYSTEMROOT%\system32\spool\PRINTERS This will bring up the folder. Delete every file in there. (It's okay this will not harm anything.) Now you need to start the spooler again.
  4. Go back to your c prompt screen and type:
    net start spooler
    This will start the spooler for you again.
  5. Go check your printer queue. Sometimes you may need to f5 to refresh the screen. You did it. Your stuck files in your printer queue are all gone. You can begin printing again.
Sep 24, 2009 | HP Color LaserJet 2600n Printer
Printer is not working.
Hi Surenderpdsi
It sounds as if the printer spooler needs re-starting.
This is the path to the printer spooler service,
Windows XP Path (category view)
Start – Control Panel – Performance and maintenance – Administrative tools – Services.
Windows Vista Path (category view)
Start – Control Panel – System and Maintenance – Administrative tool – Services.
Once in Services both XP and Vista are the same.
Look down the list till you find Printer Spooler.
Once found, right click your mouse on Print Spooler and select Properties.
In the properties box that open the service status should read “Started” if not click on start.
If it says the spooler is started click stop, wait till the spooler has stopped then click start.
This will re-start the spooler and should fix your problem.
Hope this helps,
MK Support.
Mar 15, 2009 | HP DeskJet 3745 Printer
Print spooler
To prevent the spooler from stopping, which is usually caused by invalid printer drivers left on a computer.
Go into "Printers and Faxes" delete all printers which no longer exist by right click --> delete
To restart the spooler :-
click start --> run
type net spooler start click ok
click start --> run --> services.msc --> click ok
scroll down to print spooler --> right click on it and select start
Jan 30, 2009 | HP xw6600 Workstation with 650W 80 PLUS...
"Error 1068 Could not start the Printer Spooler on local Computer"
I appreciate the opportunity to help you. Try the following:
Check dependency services on Print Spooler
1.Click "Start", input "services.msc" (without quotation marks) to Start Search bar and press "Enter".
2.Double click the “Print Spooler” service.
3.Choose “Dependencies” Tab and remember the services name.
4.In the service list window, find the dependency services and try to start them.
5.Please try to start the “Print Spooler” service again.
See if this helps. If it does, please fill in the rating of my service to you. Thanks for using
Jan 27, 2009 | Office Equipment & Supplies
Printer Spooler service!
click on start ..RUN.....type cmd......type sc config spooler depend= on start ..RUN......type services.msc.......look for ptrint will be started if not then double click on print spooler and click on start.
Now try installing the printer.
May 31, 2008 | Lexmark X4270 All-In-One InkJet Printer
HP DeskJet 3940 InkJet Photo Printer Logo
76 people viewed this question
Ben Johnson
