Question about Kenwood KR-X1000
Receiver only works in Stereo Mode and won't allow use of subwoofer
When selecting Dolby or THX modes the signal turns to garbage within a short period. I will get correct signal to two speakers in stereo mode. Can't use the subwoofer for long before the signal goes bad for it even in stereo mode. Sounds like a main signal processing chip gone bad or something. I'm reasonably handy but not much of an electronics repair person. I'd appreciate any tips on how to repair. Thanks
    President:
  • 3,130 Answers
That sounds about right, about the audio processor IC most likly being the culprit. To repair this, a test tone should be inserted into the unit, and using an ocilliscope to trace the audio waveform through the circuit, and see where it craps out. There could also be a regulator componet from the power supply that is going out after start up and becoming intermittant. Sorry to say in this case there is no wasyy fix unless you have a schematic and the proper equipment. Time to take the unit into the reciver repair Place. Good Luck
Posted on Jul 23, 2006
Our denon 1708 only play on stereo mode,no sound when it select on 7 channel.. crackling on dolby. what is the problem on that receiver? please help
The surround sound outputs outputs ic's in the remainder of the system have opened, or there is a short in the speaker wiring, check to make sure that is not the case, if okay! you will need a repairman to assess the situation.
Mar 31, 2012 | Denon AVR-1708 Receiver
I hooked up my system and only the front 2 speakers and the SW work. How do I get the others to work?
You're in Stereo mode.
Try three things:
1) See if your receiver is in Stereo mode.
2) You can change your audio preferences from within your DVD menu from Stereo to surround.
3) Change receiver and dvd audio menu options to Dolby ProLogic surround.
Nov 18, 2010 | RCA RT2770 Theater System
Kenwood 107VR rec and No vol from Sub Output w/ menu Opt On
In the setup menu are the speakers set to large or small? On some receivers if you have it set to large all the bass is directed to the right-left fronts.
On my pioneer receiver if the speakers are set to large the sub-pre-out only works if the receiver is in a surround mode, if its in stereo mode and the speakers are set to large the sub-pre-out is dead. If the speakers are set to small the sub-pre-out works all the time.
Also, some receivers won't send a signal to the sub-pre-out if there is no LFE discreet signal info from the dolby digital or dts bitstreem.
For example I have several older dvd's that light up the L C R SL SR icons on my receiver, but don't light up the LFE icon. I have other older dvd's that just light up the L and R icons meaning they are only recorded in stereo like a vhs tape recorded in dolby surround.
In my basement I also have a kenwood dolby digital receiver.
I've noticed that when a dvd only lights up the left and right icons the pioneer will automatically switch to dolby pro logic surround. The kenwood will only send the signal to the left and right fronts (stereo). If I manually switch it (kenwood) to dolby pro logic I'll get sound from all the speakers just like the pioneer, but it does'nt do it by itself.
Most receivers that have a tape monitor won't work in surround mode with the tape monitor on. The pioneer will let me use the tape monitor with dolby pro-logic but won't pass through a dolby digital signal with the monitor on.
Hope this helps.
Apr 18, 2010 | Kenwood 107VR
Denon receiver AVR-3300: Unstable source selection
Go over here: http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_alp.php?p_sid=1NlVrsDj
I have some Denon components myself and had some problems. Ask them here, and within a day you should have solution for this problem.
Probably you have to reset the device to factory settings.
Jul 22, 2009 | Denon AVR-3300 Receiver
My Panassonic SA-XR50 Receiver is not producing surround sound from either of the Optical imputs from the TV or DVDR Both outputs are stereo L and R + subwoofer How do I rectify this What settings should I...
First enable the surround sound mode for the selected input and verify that the media playing is recorded in some mode of surround sound.
You can however, acheive surround sound from 2 channel sources with dolby prologic or prologicII sound processing, or other proprietary modes that your receiver might have from the manufacturer.
Jun 12, 2009 | Panasonic SA-XR50 Receiver
Its working only in direct & stereo mode
maybe you need to replace a fuse?
is it hooked up correctly
Apr 23, 2009 | Denon AVR-1508 Receiver
NAD 775 will not play surround sound from XBOX
try to calibrate the speakers from audessy rom menu,i did it and it lokes like it just needed to register all the channels,hope it helps.
Jan 29, 2009 | NAD T753 Receiver
Panasonic SC-PT660 digital in doesn't work
Select to suit the type of audio from the OPTICAL IN terminal on the main unit.
1 While in “D-IN” mode
Press and hold [—SETUP] to select “MAIN/SAP”, “DRC” or
“PCM FIX”.
2 While the selected mode is displayed
Press [up, down] to make the setting.
MAIN/SAP mode (Only works with Dolby Dual Mono)
MAIN, SAP§, MAIN+SAP§ (stereo audio)
§ “SAP” = Secondary Audio Program
Dynamic Range Compression
DRC ON: Adjust for clarity even when the volume is low by compressing
the range of the lowest sound level and the highest sound level.
Convenient for late night viewing. (Only works with Dolby
Digital)
DRC OFF
PCM FIX mode
PCM ON: Select when receiving only PCM signals.
PCM OFF: Select when receiving Dolby Digital and PCM signals.
[Note]
Audio that is input through the OPTICAL IN terminal cannot be output
through the HDMI terminal.
Nov 29, 2008 | Panasonic Home Theater System System
RCA RT2280 surround sound mode button wont select 5.1 dolby digital mode.
I had the same problem and this is what I did to fix it. Assuming that all of your equipment is powered on, (tv, blu-ray/dvd, rca receiver) you'll need to go into your dvd players audio menu and select the dolby digital audio.
Once you do this, the digital signal is sent to your receiver from the dvd. The receiver should automatically set itself to the dolby digital preset. If it doesn't, press the surround button until you reach it. I found part of this information here. And the rest was personal experience.
Also, it depends on if the disc format is in dolby 5.1. I hope this helps you.
Dec 18, 2007 | RCA RT2280 System
Dolby Digital Has Stopped Working
i sthe thx dobly digtal button on off or on auto ?
Nov 14, 2007 | Kenwood VR-505 Receiver
Kenwood KR-X1000 Logo
176 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
rigger094
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
