Question about Durabrand PDV-709
RECHARGABLE BATYERY DOESN´T CHARGE
What can I do, my rechargable battery doesn´t charge!
  • 1 more comment
  • pro_grace Oct 22, 2008
    Thank you for your support, I´ll find a local supplier to buy another one.
    Regards.
    JC Garza
  • Anonymous Oct 22, 2008
    My battery doesn't charge, where can I buy a new battery???
  • born 7 Nov 14, 2008
    bettery will not stay charge , and the number on the back of the product does not work when I try to call. Customers spen hard earned money on the products and expect them to work this is not even One year old and is not used as much as a cell phone but cell phone batteries last for years. Called store store cant find phone number for me to call to resolve this problem. or to order a new battery which cost probely as much as a new dvd player .
You probably will have to go and buy a whole new one. theses kind of batteries only last about 1 year.
Posted on Oct 21, 2008
I have a pair that takes batteries an a charger base charger how does this work
They are often fitted with rechargable AAA cells. These can be charged by putting the phone on the charger base. Obviously the base must be plugged into power. You could alternatively take the rechargable cells out and charge them in a standard charger. The radios will also work with non-rechargable batteries but don't try and charge them or use the charging base.
Oct 29, 2013 | Radio Communications
Battery doesn't hold charge for more than a week
All batteries will eventually fail to hold a charge. The battery chemistry and how you charge it can change how long the battery will last. The DMC-FS4 has a Lithium-ion battery so it shouldn't have as much of the memory issue of older rechargeable batteries. (This is the "you routinely recharge the battery when it's at 50% then it always stops working at 50% charge" problem.)
How old is your battery? Eventually you will need a new battery but the time to replacement will depend on the number of recharge cycles. With a Li-ion battery, I'd expect several thousand recharges before failure. Temperature and usage will effect this. The battery does lose charge even when not used.
Be careful, some versions of the firmware look for Panasonic's specific batteries or a "that match the Panasonic rigorous specs".
I've seen a few devices where the charger failed before the battery. If a new battery doesn't seem to be charging, replace the charger. I hope this helps.
Oct 18, 2012 | Panasonic Lumix DMC-FS4 Digital Camera
MTG 900 SAYING "CHARGE" AND I'VE BEEN PUTTING
I am assuming you are reading the battery charge correctly. If so you need a new rechargable battery. Special battery so it is a little expensive. Make sure the person knows it is a "rechargable battery" you want. A regular battery will not work properly or recharge.
Nov 02, 2011 | Casio Atomic-Solar MTG900 Watch
How to charge kodak c142? is the data cable which is used for copy the pictures to the PC also charge batteries?
I don't believe these batteries with this camera are rechargable. the spec sheet calls for alkaline batteries. Do the batteries in the camera say rechargable on them. There is a Kodak battery charger with batteries , but that is a multipurpose charger for many cameras, and all it does is charg batteries like any other batter charger.
Nov 27, 2010 | Kodak EasyShare C142 Digital Camera
Won't use rechargeable batteries
It could be due to the fact that some rechargeable batteries are slightly different shapes and the nobbly bit on the + end doesn't reach far enough in, as it is the case with Maplin AA batteries.
In my case I placed a small drop of solder with a soldering iron on the + nipple and now they reach into any device.
Nov 26, 2009 | Kodak EasyShare C633 Digital Camera
How 2 charge a kodak with rechargable batteries!!!
get a charger for the rechargable batteries. Charge the batteries and then put them into the camera. You cant really chare the camera..
May 02, 2009 | Kodak EasyShare C613 Digital Camera
How can I charge my centon 4gb mp3 player?
I have the same player. You can use a rechargable battery. But you cannot charge the battery by connecting it to the USB. You must charge the battery with a AAA battery charger - they sell them at walmart for like $15. The rechargable battery really works excellent in this player - I listen to my player all day long and rechargeable batteries are the only way to go for me! Make sure you have four batteries though so you can always have a backup charged as the charger takes 8 hours to charge the batteries.
Jan 04, 2009 | Centon Electronics 001 MP3 Player
Microtalks won't charge
I have the Cobra Microtalk 4100 FRS radios with charging base. After changing the batteries with new nimh rechargables the charge light would not illuminate and the unit would not charge. I noticed the original batteries had a metal band around one end. This band makes a small connection inside the battery compartment on the first battery. Seems to be a cheap way to ensure you dont try to recharge the unit with non-rechargable batteries installed. I rapped a small piece of tinfoil around one end of the first battery in the new set then popped it back in and now they will charge correctly again. Dont try this with non-rechargable batteries! I would recomend buying original replacement batteries.
Nov 28, 2008 | Cobra Microtalk 100 FRS Walkie Talkie...
Kodak easy share c 340
try taking out the batteries, and clean the connectors that the batteries touch, and the ends of the batteries (if recharagable). Sometimes a dirty connector can make the batteries seem that they are dead even if they are rechargable. If the camera works with new disposable batteries but not with the rechargable ones, then you may need to purchase some new rechargable ones.
Oct 23, 2008 | Kodak EasyShare C340 Digital Camera
"Battery Empty" sign with camera shut off
You may try to set in setup the kind of batteries you are using. Many digital cameras allow you to set the kind of batteries being used. Whether or not this will solve the problem, is yet to be seen.
Dec 09, 2007 | Olympus FE-130 Digital Camera
Durabrand PDV-709 Logo
95 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
