Question about Electrolux 24 in. EDW5505EPS Stainless Steel Built-in Dishwasher
Electrolux "CF" code
I have a 3year old Electrolux dishwasher, i have the "clean filter" code coming up more often... and the filter is clean... what else can it be and how can i fix it?, thanks Bill
  • jjgarris Jan 17, 2009
    I too have a flashing CF on the dishwasher. The filter is clean. I did find some eggshell and a seed under the filter but no other obstructions. Dishwasher just won't run.
SOURCE: electrolux dishlex dishwasher
Here is the full story.......
Sale of fire-risk dishwashers banned 5:00AM Thursday July 24, 2008
New South Wales last night banned the sale of dishwasher brands fromAustralia's largest whitegoods supplier after the faulty machines werelinked to a string of home fires.
More than 26,000 Electrolux,Electrolux Dishlex and Westinghouse dishwashers sold in Australia andNew Zealand since April last year have a potential wiring fault.
TheNSW Fair Trading Minister, Linda Burney, said her department had beenalerted to 73 incidents involving the appliances, resulting inexcessive heat and kitchen fires.
Electrolux identified a fault with the dishwashers last year and has issued three appeals to consumers.
"Despitethis, Fair Trading has received reports that fires or incidentscontinue to occur," Ms Burney said. Up to 5000 of the dishwashersremain in households unchecked.
The minister said a wire connector within the appliances could cause plastic components to melt in the control panel.
The largest number of faulty washers are in NSW.
The state Commissioner of Fair Trading has moved to ban NSW retailers from selling their remaining stock of the appliances.
"The prohibition will ensure that any dishwashers not alreadyquarantined by Electrolux, which may be in retail outlets and not inthe possession of Electrolux, are not sold," Ms Burney said.
Theban and the recalls cover Electrolux, Electrolux Dishlex andWestinghouse washers with serial numbers ranging from 70700000 to72400000.
The NSW Government said consumers with one of thesemodels should stop using the machines immediately and contactElectrolux to arrange for a technician to fix the problem.
- AAP
This story was found at: http://www.nzherald.co.nz/section/1/story.cfm?c_id=1&objectid=10523214
Posted on Aug 11, 2008
SOURCE: error code 01 on elecrolux dishwasher EIDW6305GSI
Usually the error code 01 means you backed up water in the unit. First be sure that the drain is clear.  Run the garbage disposal and be sure your sinks are draining.
I got lucky on a EIDW6105 unit by trying this.
All the lights are flashing and it shows error code 01.
Push down on two of the buttons and hold (I pushed on the Favorite and Heavy buttons), until the flashing stops (about 8 seconds).
The machine now showed and error code 08.  Then hit the start button.  My washer then cleared and runs normally.
Hope this helps, better than a sevice call to clear the code.
Posted on Dec 28, 2008
SOURCE: Electrolux DX302 Dishwasher power button wont stay on
I rang Electrolux and have ordered a new switch....
Posted on Jan 14, 2009
appldoctom
  • 311 Answers
SOURCE: electrolux Dishwasher 24 " not
if i was at your home as a repairman this is what i would do.if your water pressure was good at the kitchen sink,i would turn water off to dishwasher undo water connection at the fill valve,and place water line in a bucket and turn on water.if ok and still not getting water then prob with fill valve.soooo you have a new valve,did you check the water pressure to the valve? if yes good because then you also flushed out that in coming water line.because[and i have done this a few times]if not flushed their could have been minerals setting in that supply line so when you turn the water back on it pushes that stuff into the new water valve screen and blocks it up also.if your getting water then its trying to do its job,it just cant get enough water and the timer times out so no more voltage to the water valve.thats a lot said but there no mystery to it.the timer allows for lets say a 70 sec fill at 40 lbs water presure ,seventy seconds up that's it .the float only stops it from flooding,too much water.it dose not tell the machine that there is not enough! so because its letting in some water that tells me the float switch is closed[and it should be]leting the voltage to the water valve.the water valve has to let in enough water then.i know i mixed up words a bit but i hope this helps you understand whats happening.God bless ,if you need more advice you can email thru FixYa tom
Posted on Jan 24, 2009
SOURCE: error code on electrolux dishwasher,
electrolux wave touch dishwasher giving error code 1?
Posted on Oct 20, 2009
Why does my Electrolux commercial dishwasher come up with error code A1?
Check Water supply (valve, filter, pressure)
Check that the overflow pipe is inserted
Jul 12, 2016 | Electrolux commercial undercounter...
Removal of large filter on electrolux model ewdw6505gb0
Electrolux Dishwasher Screen Filter 154624901 this one?
If they are hard water deposits, there is probably other parts coated with lime as well... try running a cycle with this in it- Ice Machine cleaner, it is safe on the plastic parts of an icemaker and meant to clean things that folks eat off of, so it rinses clean. I would use two bottles and then let it fill the rest on it's own...
Jul 09, 2016 | Electrolux Dishwashers
What is the meaning of a flashing cf code?
Electrolux support site doesn't show a "CF" code. "PF" is Power interruption.
http://www.electrolux.com.au/support/troubleshooter/
Jun 03, 2015 | Electrolux 24 in. EDW5505EPS Stainless...
Electrolux 24 in. Diswasher
Hello Darlene, thank you for allowing me to assist you!
The "ER" code that keeps appearing on your Electrolux dishwasher stands for a Membrane Switch Failure. Normally that means that your control board has detected a stuck key or key pressed for more than a minute. That could possibly be an issue with your keypad or main control board. I would recommend having a technician come out to your home to properly diagnose and repair your dishwasher. I hope this is helpful. -Matt
Aug 02, 2014 | Electrolux EIDW5905JS Dishwasher
No water entering dishwasher electrolux 602
First is water coming into the location and is the valve to the dishwasher open? Next check if the intake hose is bent or squashed. Release the kink blocking water flow.
There is a filter in the intake hose that can get blocked by debris. Turn off the water (at the supply valve) then disconnect the intake hose. Clean the filter. Reconnect the hose and turn the water back on. Check for leaks.
The manual for the unit is available here: http://kitchen.manualsonline.com/manuals/mfg/electrolux/esi_602.html .
I hope this helps.
Feb 21, 2011 | Electrolux 23 in. ESI602 Free-standing...
Electrolux EWF 1087 error code E60
My Electrolux washer always come up with an error code of E60, Why? can any one help
Mar 07, 2008 | Electrolux EW1200i Front Load Washer /...
Electrolux 24 in. EDW5505EPS Stainless Steel Built-in Dishwasher Logo
307 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
