Hoover washing machine
Hello...my washing machine was just doing its final spin,rather noisily as its not built in and only had a half load in so not heavy...i heard a bang and the washer had stopped,the lights were off and part of the house electrics had fused...turned the washer to off,tripped the electrics back on and bobs your unc the washer is dead,i have replaced the fuse in the plug but there are still no signs of life....what do you think is wrong with it?
  • mavismary Oct 21, 2008
    oh thankyou i will,but what am i looking for?i mean what will be wrong or right? and then what do i do with it?
    thankyou
    President:
  • 1,462 Answers
Take top off and check the suppressor capacitor - the round thing the incoming mains is connected to
Posted on Oct 21, 2008
  • douglas smith Oct 22, 2008
    take top off. suppressor capacitor will be where the mains is connected. usually there are 5 wires connected to it - 2 are incoming mains, 2 are mains going into the machine and the 5th is earth. if it is faulty, often the damage is obvious - a bulge in it or sometimes completely disintegrated.the capacitor is round, about 11/2 to 2 inces diameter and a few inches long.
    a way of testing it is to bypass it altogether ie connect incoming mains to outgoing mains and see if machine starts. of course disconnect when you do this or you will get a shock
Washing machine leaking underneath
might simply be a small hole in the outlet drainage hose, this would explain why your machine leaks during the final spin, there is more pressure from the water inside the hose during the final spin than when the machine is draining. hope this helps.
Nov 11, 2013 | Hoover Washing Machines
Hi i was wondering if you help.my hoover hd vision
my hover washer dryer 1200 spin will not spin water comes into the drum and will not spin
May 12, 2010 | Hoover H160E Front Load Washer
Hoover Washing Machine Model A63470 Does not spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jan 09, 2010 | Hoover HTC243 Top Load Washer
We have a Hoover select 1500 washing machine. It still washes and rinses ok, but doesn't then move onto the spin cycle. But I can manually set the dial to spin and restart it. It then spins fine. I assume...
Could be but also could be rinse water valve not operating due to faulty solonoid. it does a final rinse / softner before spinning if valve faulty then no spin advance....
Nov 11, 2009 | Washing Machines
Hoover washing machine wont spin
heatman101
Nov 01, 2009 | Hoover UltraCare HC6 160E Front Load...
Hoover 600MB Top Loader, Won't Spin
I have the same problem. Just started missing the spin cycles and now I need to find which part to replace.
So far I think it could be: Aged contacts in the Timer, a faulty spin/no spin switch, or something to do with the brake/release mechanisms etc. ..I do know that the problem is electrical because everytime the motor starts the spin works fine; therefore eliminating in my opinion, the mechanical gearbox bits as a cause.
Jun 22, 2009 | Hoover HTC243 Top Load Washer
Hoover 1300 washing machine
hi there this is a common fault you will need to replace the control module and selector switch/timer
Dec 01, 2007 | Hoover H130E Front Load Washer
My old Hoover top loader Washer is noisy & doesn't spin out properly - how can I fix it?
Sounds like the switch which cuts the machine off when the load is unbalanced. My guess is that: This switch is being triggered too easily The springs holding the bowl up are either stretched or one is broken; The machine may not be level.
Mar 30, 2007 | Hoover HTC243 Top Load Washer
Hoover H110m help needed
hello sounds like the drum is stuck probebly the pole is cloged with hair and stuff if you have the skill open the machine and clean all while your at it look for the belt from the motor check her condition - bad? - install a new 1 there is a stretching unit for the belt 1) relese the bolt of this unit and change the belts 2) pull and stretch the new belt and then close the bolt good luck
Mar 20, 2006 | Hoover H120M Front Load Washer / Dryer
Washing Machines Logo
111 people viewed this question
Top Washing Machines Experts
