Question about Garden
I need a replacement gas cap
Greene Machine by John Deere 4600 bp
  • rstroven Oct 21, 2008
    need a gas cap
  • Anonymous Dec 03, 2008
    i need a gas cap for john deere leaf blower
  • 163 Answers
Try www,jackssmallengines.com
Posted on Nov 30, 2008
My lt 133 john deere mower has gas in oil and back fires. runs 5 min and stops.
It's going to need a carb kit to fix the problem. Make sure your gas cap is venting ok, because gas expands in the summer and can force gas to pass thru carburetor and flood the cylinder then passing down into the oil. Depending on the age of your mower, the carburetor may have a gas shutoff solenoid on the bottom and this may have malfunctioned. Another is a bad float or needle valve which a carburetor kit would fix. A needle kit with bowl gasket may be all it will need. Hope this will help.
Jul 19, 2014 | John Deere Garden
John Deere Gator
check your gas tank screw on cap......if there is a breather hose coming out of the cap....make sure the hose is not kinked thus causing a vapor lock in the tank
Jul 07, 2014 | John Deere ATVs
John Deere L120 runs for 15 minutes, bogs down and dies. A few minutes later starts right up, runs for a few minutes and dies again. I have changed the fuel filter, all fuel lines, air filter, cleaned the...
Is this an older machine ? If so try finding the points its usualy on the front lower part of the engine behind the cover, if you see that then it needs its condensor replaced, lookes like a round battery.
If this is newer or you can also try changing the spark plug sometimes they heat up and fail.
Sep 17, 2012 | John Deere Garden
John deere lt155 lawn tractor shuts off when it gets hot while mowing, could this be electrical?
I had a similar problem lasy year.
Try this:
As soon as the machine seems to be stalling, loosen the gas cap.
If the engine continues to run, clean the gas cap vent hole(s).
Gary
Jun 26, 2011 | John Deere Garden
My john deere L111 riding lawnmower starts fine but after running for 20 minutes, it just shuts down. Will not restart until it cools down. Any suggestion where to look.
I had this same problem with my John Deere LA140. I suspected that it was some sort of fuel delivery problem. Long story short, it turned out to be the gas cap was not venting properly, creating a vacuum in the fuel tank. The temporary fix was to loosen the cap when it starts to die. This relieves the vacuum and allows the gas to flow again. Installing a new cap on the tank fixed the problem.
May 05, 2011 | John Deere 22HP VTwin 48" Riding Mower
I have a John deere L-130 lawn tractor that creates a vacum in that gas tank. It stalla ater 20 min. of use. The cap has no vent. Is there another line/filter?
GY20473 gas tank from deere had a cap with a vent. GY21102 tank had a vent hose and was the later version. My guess is that you have the early version of the tank with the newest fuel cap. I recommend a new cap with a vent or drill a 1/32 hole in the top of the cap.
Problem solved
Thanks
Joe
www.arcolawn.com
Feb 10, 2011 | John Deere Garden
Our new to us john deere 345 tractor won't keep running
You may try blowing backwards from behind the fuel filter into the gas line. Not to much air pressure though. Make sure the gas cap is off.
Mar 13, 2010 | John Deere A,b,g Tractor Carburetor Float...
John Deere 3300 PSi pressure washer shutting off while in use.Everything appears fine Oil level,Gal level,Air cleaner ok etc.. May run 2 minutes or 12 minutes then spudders a bit then Bang "Off" as if i...
John Deere will replace the cap for free; they acknowledge the vendor who supplied Briggs & Stratton gas caps provided faulty caps. Call 1-888-228-3068 then 1 (English), 2, 1 and a technician will ask you for model number and Serial Number (which they need to replace the cap). Don't drill a hole in your cap: debris will find a way into the gas tank and end up possibly fouling the engine. Bob from NJ
Nov 03, 2009 | Dewalt 3800 PSI Pressure Washer
3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Jul 04, 2009 | John Deere 3010,3020 Tractor Basic...
Garden Logo
397 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
