Question about Canon PIXMA iP1600 Printer
Ink absorber the ink absorber on my Canon iP1700 is almost full, how to I fix this?
  • karlh1040 Nov 20, 2008
    Ink absorber full. Will not print. How do I fix this problem?
  • epiphone8946 Feb 24, 2009
    ink absorber is full..how to fix?thanx..
Our office printer shown absorber full - cannot print
Posted on Nov 25, 2008
How to replace ink absorber
Maybe you can reset the absorber
Instructions
    • 1 Press the printer'sicon1.png "Resume/Cancel" button when the error message appears. This should clear the message temporarily and allow you to resume normal printing.
    • 2 Turn off the printer if Step 1 did not clear the message.
    • 3 Disconnect the printer from the computericon1.png, typically a USB cable.
    • 4 Unplug the printer from the wall electrical outlet for 10 minutes, then plug it back in. Reconnect the cable between the printer and the computer.
    • 5 Turn on the printer. Your sensor settings will reset, which should eliminate the error message.
Aug 21, 2014 | Canon PIXMA iP1700 InkJet Photo Printer
THE INK ABSORVER IS FULL
Resetter canon iP 1700 and iP1300
Step 1 : Reset Hardware
  1. Turn off Canon Pixma iP1700, iP1300 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the Canon Pixma iP1700, iP1300 Printers should turn off, if not, press the Power button once more.
  8. Your Canon Pixma iP1700, iP1300 Printers should respond as normal
Step 2 : Using software resetter
  1. Download Software Resetter for Canon Printers iP1300 dan iP1700 Software Resetter for Canon Pixma iP1300, iP1700
  2. Ekstrak/Unrar/Unzip the Software
  3. run GeneralTool.exe
  4. Select USB Port where the canon ip1300 or canon ip1700 installed.
  5. CLick Lock Release button
  6. Select EEPROM CLEAR
  7. Click Test Pattern 1 button
  8. Your Canon Pixma iP1700, iP1300 Printers should respond as normal.
Resetting Ink-Waste Ov
Nov 27, 2010 | Canon PIXMA iP1700 InkJet Photo Printer
Can I fix my full ink absorber myself? Canon iP1800
Only service centre can help you to replace the ABSORBER KIT.
May 25, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Canon Pixma Ip1700 will not print, because the Ink absorber is full.
Hi there
Please under-stand at some time you will need to clean out the waste inkpads that are inside your printer or it going to be a big mess of inks coming out.
Some times the IP tools will fix it Canon Pixma iP1200, iP1600, iP2200 Resetter
1. Download software for Canon iP1200, iP1600, 2200 Printers.DOWNLOAD Service Tool Software for Canon Pixma Printer iP1200, iP1600, iP2200
2. Unzip downloaded file by WinZip, 7Zip, Izarc, etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 15, 2010 | Canon PIXMA iP1700 InkJet Photo Printer
I HAVE AN IP2600 WITH INK ABSORBER ALMOST FULL. HOW DO I FIX OR CHANGE IT.
Hi there with most canon priters you can reset the waste ink but I myself have not seen one for yours.
I have put a website fr you to look at click on the link it will take you there.
http://www.tradebit.com/filedetail.php/4595501-canon-ip1200-ip1300-ip1600-ip1700-ip1800-ip2200
All the Best Pineworks
Feb 11, 2010 | Canon Pixma iP2600 Photo InkJet Printer
Canon 130 printer ink absorber is full. need advice to fix.
Hi, is it canon 130 or canon 1300, if it is canon 1300 you can try to fix it using a manual reset and software reset. You can visit my blog here for free reseter and tutorial:
http://feedproxy.google.com/~r/Inkq-mac/~3/eJkvGfLlL1U/how-to-reset-canon-pixma-ip-series.html
To know why "waste ink absorber is full" message appear, you can visit it here:
http://feedproxy.google.com/~r/Inkq-mac/~3/0DgDreiMUw8/waste-ink-absorber-is-full.html
If the reseter won't help you please let me know. Hope this help.
Dec 22, 2009 | Canon Office Equipment & Supplies
Ink absorbers almost full in Canon Pixma iP 1500 how can I fix it yourself
Hi ...
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Please vote if this helps ... Cheers :)
Jun 26, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Ink Absorber Warning
you need to dismantle the printer..in order to grab the ink absorber...
May 12, 2009 | Office Equipment & Supplies
The ink absorber is full and printer won't print.
Normally when you get the "ink absorber is full" message, you would take machine to a Canon service center. They will either clean the ink absorbers or more than likely they will replace the ink absorbers. After replacement, the ink absorber full message will have to be reset which is done in the service mode.
Inkworks
866-381-0541
Nov 21, 2008 | Canon PIXMA iP1600 Printer
What does ink absorber full mean on Canon Pixma 1700?
my Canon pixma keeps coming up ink absorber full cannot print
Oct 30, 2008 | Canon PIXMA iP1600 Printer
Canon PIXMA iP1600 Printer Logo
192 people viewed this question
old marine
old marine
