Hi, I have a sony vaio laptop whose screen has got damaged. As a result, i have bought a LG monitor/TV 19" flatron widescreen. It's model no is M198WA. The problem is that when i switched on the monitor, 2 very bold black lines were coming on top and bottom of the display screen. Also when i pressed the menu button, instead of seeing the options as text i could see those in colored boxes. But fiddling with the remote control for sometime, it came back to the right display. I faced this problem again when i switched it on. This problem is quiet inconsistent as it sometimes comes normally and sometimes with the problem mentioned above. Can you please suggest me any remedy for it. Thanks in advance.
  • 749 Answers
Being both a monitor and hdtv it is set up to take different inputs. i use a 26"lcdtv to do the same thing here. a couple questions.... Does the tv have a "PC" input like the one on your computer for the monitor or are you using a dmi or hd cable for the connection.
I know my tv will try to use the HD format on ALL pictures if i connect it to anything but the PC connection. I got around this by installing the monitor correctly in the comuter.
On the remote , you should be able to hit the "format" button to change the bars at top & bottom, these are shown when you are in a mode other than one native to your tv.
Posted on Oct 21, 2008
My Hyundai tv 74 cm The color it not show good
Nice big screen but CRTs are getting old So, if you can't set correct colors with your Hyundai it might have some serious issue with tube. Probably replacement might cost you more then a new new 27" Flat Panel. See some tutorial and info about bad color of CRT
Fix your own CRT Television Color Problem
How To Diagnose Bad CRT or LCD Monitor
http://www.electronicrepairguide.com/monitor-color-problem.html
LG M2762D 27 Inch Widescreen 1080p LCD TV Monitor Black
LG Electronics LG M2762D 27 FLATRON LCD TV widescreen 1080p FullHD HDTV...
RCA F27440 27 CRT TV
Samsung TXN 2798HF 27 Tantus CRT TV 1080i
Aug 02, 2015 | Televison & Video
My ps3 wont display on my LG monitor using hdmi cable?
check for 720p setting if 1080 p may be to high and will blank out screen
Mar 23, 2013 | Hannspree 22" widescreen LCD Flat Panel HD...
Flatron W1942TQ monitor has "OSD Locked" message
Press and hold menu button for a few seconds, pressing and holding, acts as a toggle. So if OSD LOCKED still appears, pressing again UNLOCKS.
Mar 25, 2011 | LG Flatron L1951S 19" LCD Flat Panel...
How do I adjust my website to new widescreen monitor?
Your LG flatron resolution is 1366x768.. just change the settings on display properties at 1366x768, if there no available resolution, uninstall your display driver and reinstall your video driver, the process of driver installation detect your monitor resolution automatic <_>
Jul 11, 2010 | LG W1934S-BN 19" Monitor
Hi, I have an LG Flatron TV which I bought 6 years ago. Good picture, no problems until now. I put the set on standby via the remote. Later, when I put it on via the remote all I got was sound and no...
Since the screen keeps turning off and sound only remains have a look at the inverter board for any buldging capacitors which look like blue cans, there is most probably a short in the inverter and the powersupply is sensing this thus turning it back into standby to prevent damage to the tv.
jonno
Nov 04, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
What is the best method for cleanig a flatron
Take a clean cloth and spray some windex on the cloth and then wipe down the screen and it should come nice and clean. Never spray it directly on the screen cause if the liquid goes down inside of the screen then it could damage it.
Mar 01, 2009 | LG 22" FLATRON LCD Monitor
LG FLATRON E700SH is not displaying RED color
there is ovbiously a fault with the monitor and w ould be best if you bought a new up to date monitor then if any faults consist with that one you could just take it back
Dec 06, 2008 | LG Flatron Ez T910BU 19" CRT Monitor
Cant get 1280x1024 when connected to laptop
the only way you may get it to work is if you use the monitor a secondary device and also use the notebook monitor as well. But the problem may also be the vga connector converting the signal, as you may have to have a DVI connection on your monitor to obtain widescreen resolutions.
May 28, 2007 | LG Flatron L1710B 17" LCD Monitor
Computers & Internet Logo
83 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
