Question about Dewalt D25830K 12 lb. sds max demolition hammer
Broken chisel I have half of a sds max chisel that has snapped stuck inside the chuck, how do I get it out!
  • rawson73 Oct 26, 2008
    Sorted, thanks very much!
    Novelist:
  • 99 Answers
The rubber end cap should just pry of the toll holder. Behind this ther is normally a snap ring or ciclip. Remove that and the chuck parts should all come off. Remember which order they were in. There is normall end cap, clip/ring, thick washer, dished washer and ball. Once all these parts are removes you can try and punch the bit out from the hole the ball sits in. If it doesn't come out like that then you would probably have to take the gearbox of and remove the striker from the tool holder and punch it out from behind.
Posted on Oct 25, 2008
I have an SDS bit that will not release from my Hilti...any idea how to get it out?
by disassemble the chuck parts to get the ball out and all blocking parts , when the drive guiding the bilt lock is worn it will be happens again in a short time or you have used a wrong chisel ? the where safety glasses after the dissassembling and place the chisel with tool complete on it in a big bench vice and make the dissassembled bitholder hot carefully with a burner and beat the machine from the chisel only if all blocking parts are disassembled or totally removed replace the
chuck parts but also the entire shaft guide if it is simply worn out by wrong chisel not.
Jun 25, 2015 | Drills
Sds bit snapped in my makita bhr200 chuck.on taking the drill apart,the chuck is on a gear rod,and wont allow me to push the chuck down
You have to remove the striker bolt from inside the spindle first. to do this remove the internal circlip (not always easy) then you can tap the striker bolt out and then press the broken bit out.
Mar 15, 2013 | Makita Drills
Cordless sds leaving grease on sds bits
There is supposed to be grease on the chuck end of SDS+ and SDS Max bits. Actually, you should put a little lightweight grease on the end of the bit every time you put one in your drill. If you, or noone who has ever used the drill, have ever done this, it is possible internal grease is leaking out of the drill and it should not. There are seals to prevent internal grease from getting out of the transmission and striker mechanisms. If you are loosing internal grease, these seals should be checked.
Feb 14, 2013 | Dewalt DW005K Rotary Hammer
Hilti te 56 combi hammer not working
The gears inside that engage the chisel points to move back and forth are either not alligned properly or are stripped. You'll have to open up the hammer to see what, exactly, is the problem.
Sep 20, 2012 | Dewalt D25330K 2KG Sds Plus Demolition...
How do I repair stuck chuck
Sometimes it just needs some lubrication inside where the ball holds onto the bit. If that doesn't work, you need to replace the chuck pieces. Often times they come in a kit. The plastic sleeve may need to be cut or broken off.
Apr 07, 2012 | Drills
Do all sds drills have chisel function?
The SDS designation relates more to the type of chuck on the tool for the bits than to the tool/drill itself. There are both chisels and drill bits with SDS-Plus and SDS-Max shanks, SDS-Max being the the larger of the two. As far as the tools go: Demolition hammers will only hammer and can only use pointed chisels, scaling chisels, scrapers, etc, not anything like a drill bit that requires spinning to work. Rotary hammers can hammer and rotate the bits. Rotary hammers have a selector switch with two or three positions; one for hammer only for the above demolition bits, one for rotary hammer for use with carbite tipped drill bits, and some have a position for rotation only. The rotary hammer is a more versitile tool but more expensive because of extra workings inside.
Feb 17, 2011 | Garden
My drill bit has stuck in the chuck of my dewalt sds chuck ,have tried wd40 but still stuck
I had the same problem. I put the drill onto Hammer/Chisel action and it helped release the bit.
May 16, 2010 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
How do I remove an SDS bit stuck in a B&D SDS
the rubber cap in the sds chuck nose is only snap tight try to remove and dismantle the retractable locking pins.
Nov 26, 2009 | Drills
Sds drill stuck in chuck
tap it lightly with a ball pin hammer, if that dosnt shake it out try opening it and useing something to push it through
May 04, 2009 | Drills
Dewalt D25830K 12 lb. sds max demolition hammer Logo
674 people viewed this question
Top Dewalt Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
richie46
Are you a Dewalt Hammering Expert? Answer questions, earn points and help others
