Question about Fuji FinePix S5700 Digital Camera
Card not initialized message after i'd used it this morning
Used camera 60 fotos go to use it again message card not initialized what do i do? Urgent need camera tommorrow
David Barron
Barrond716@tiscali.co.uk
  • 623 Answers
What size is the SD card?
Posted on Nov 04, 2008
I can`t take a foto with my camera
used memory card...or delete up to 50 photos.
Nov 15, 2013 | Samsung Omnia II I8000 Smartphone
When camera is turned on it reads "this card cannot be used" i have pictures on it about 60 it is a 4gb pny card. charged camera overnight and took one pic the following morning before message...
Because the same message appears when you insert the card into other cameras the most likely problems are that the card is full or defective.
Have you tried another card in your camera? If not then you should do so. If it works then it confirms your other card is full or defective.
Sep 17, 2011 | Cameras
I have a Fujifilm Finepix A600 and when I turn it on I get CARD ERROR Can you tell me how to fix it
You may have improver card fitted. Please remove and re fit the card. If problem persist , please try another good / new card. If you have no problem with new card, your existing/previous card is broken.
Regards,
Apr 19, 2011 | Fuji FinePix A600 Digital Camera
Turn power off and on again appears on the screen
Turn the Power Off and On again error message is displayed when the Lens in the Camera is stuck is affected by a malfunction. Try turning off the power and on again. If the issue persists, try performing a power reset.
To power reset the Camera; turn off the Camera and remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the Camera to remain without power for 60 seconds.
Then, reinsert the battery and check if it helps.
You may also try INITIALIZING the Camera.
To Initialize the Camera, press the On-Screen key.
Touch MENU-->SETUP-->SETUP 2-->INITIALIZE-->OK. Initializing the Camera will change all the settings back to factory reset.
If the issue persists, service may be required.
Thanks for using FixYa
KenSolutions
Dec 06, 2010 | Sony Cyber-shot DSC-N2 Digital Camera
WHEN I TURN ON THE CAMERA i AM GETTING A CARD NOT INITIALIZED ERROR AND NOW CANNOT RETRIEVE PHOTOS FUJIFINEPIX j50
If this is a new card, then the message means it needs to be formatted.
If it is a card you have used successfully before, then it sounds like it has become corrupted. You may be able to recover pics from it by connecting to a computer, perhaps using a card reader. If not, you will have to format the card to use it again, but will lose the pictures on it.
Oct 19, 2010 | Cameras
Canon Legria HF200 SDHC Initialization problem
This totally sucks. I have a similar issue with my Canon Vixia HF R20 and I'm using a Lexar Pro 64Gb 133x SDXC card. When trying to initialize the card, its fails and says "Process terminated with error." It also says "check the memory card" when I first put it in. Write-protect is off. My other SanDisk class 4 SDHC card seems to work ok.
I could have sworn it worked before and I was able to transfer videos to my Mac on 10.6, but I can't remember for sure if I was using the SDXC card or just the built-in memory. Very frustrating.
Apr 12, 2010 | Canon Legria HF200 Flash Media Camcorder
Card Not Initialized!! Fuji FinePix 2600 Zoom Digital
Are you using the camera to format the card ? I had a similar problem with a 3V 16MB card in my Fuji MX1200. I used the "Format" capability, oddly located in the "Trashcan"/erase mode, but it "initialized"/formatted the card with no problems or error messages after that. Hopefully you have a similar format function on your camera. The URL I'm referencing here is for the MX-1200, but you may find your camera elsewhere on this excellent site (not mine).
Aug 25, 2008 | Fuji FinePix 2600 Zoom Digital Camera
MEMORY STICK EMPTY BUT CAMERA THINKS IT'S FULL
If you have backed up your files/ fotos, then format the memory stick/ card.
Jun 24, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Fuji FinePix S5700 Digital Camera Logo
94 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
