Question about Panasonic Lumix DMC-FX10 Digital Camera
Camera turns on, but can't use menu
This is a 1 yr old camera that turns on, but won't operate. Settings are frozen and no button will operate. Help
  • 6 more comments
  • mcsstaff Oct 21, 2008
    i can use the wheel but can't get to the menu, zoom does not work, but lense will extend when camera is turned on. Camera worked fine until plugged into the computer for the first time, when I unplugged it it was frozen.
    nothing has worked to this point do you have any other ideas?
    Any new ideas/ nothing has worked yet.
    no reset button because i can't get to the menu
    still not working
    this did not work, this was a money back guarantee how do I get my money back?
    how do I do this?
    lumix DMC- FX10 Digital
  • Panasonic Master
  • 19,396 Answers
I start quoting from you :
"i can use the wheel but can't get to the menu, "
Probably control switch faulty or disconnected from camera main pcb.
"zoom does not work, but lense will extend when camera is turned on."
No lens error , lens extend, more facts in favour of a bad control, or pcb problem.
"Camera worked fine until plugged into the computer for the first time, when I unplugged it it was frozen."
The only thing that may have caused a fault from the computer side is a short on USB connector, or more likely the camera had a fault concerning the switch selector, and now it is stuck in PC mode, as the selector is not working anymore.
Try the following simple reset:
Remove memory card and battery.
Keep holding camera start button pressed while putting back the batteries. Hold down the button for ten seconds.
If this and all the procedure already suggested do not work, that means you have an hardware problem.
The camera in this case must be taken apart to replace the selector switch that is defective (probably shorted).
This was the solution, Try reset, if that does not work, the camera has a faulty selector switch, and that must be replaced, that is a diagnosys from an electronic engineer, and the truth, like it or not.
If you want to ask a refund in any case then write to premium.support@fixya.com or to support@fixya.com.
Note that giving bad vote to experts regardlessly to what they post is ininfluent for getting a refund, that is just irritating and rude to the experts present here that were doing a great job.
Posted on Oct 22, 2008
    Scholar:
  • 84 Answers
First tell me what camera are you using
Posted on Oct 21, 2008
  • Panasonic Master
  • 13,433 Answers
I have reviewed your problem and there is no firmware to update, and it would be difficult as in most cameras the camera atleast needs to actually work. You need to send this to repair service, either
panasonic preferably if its under warranty or you can get a free repair estimate from www.advancecamera.com/repair for example.
Let me know if theres anything you need.
  • Ekse Oct 21, 2008
    please use the add a comment function, so I can reply back to you.
    Thanks,
    Ekse
  • Ekse Oct 21, 2008
    if you wish a refund heres the refund policy part from the terms of service you will find the information you need to request a refund here
    Refund Policy
    FixYa's Premium Expert services (i.e. Premium Assistance Plan and Live Assistance Chat Sessions) allow you to consult a professional group of experts in order to find a solution for your tech support problem. Our experts will provide guidance and advice to help you understand what is wrong with your product, and what is needed to fix it. We are committed to providing professional advice, but we can't guarantee that our advice will always fix your product. In some cases in-person diagnostic, repair or other services are needed, which we can't and don't provide. In some cases our advice may not solve the problem. Refunds of service fees are provided only if we agree (in our reasonable discretion) that you did not receive professional-level advice and guidance on your product. If you believe that you are entitled to a refund, please send a description of your case to premium.support@fixya.com. We will respond as quickly as we can.
    Sergeant:
  • 154 Answers
My first suggestion is to update the firmware of the camera.
this is due to corrupted firmware.
and this can be corrected by a updated fimware
  • santha ram
    santha ram Oct 21, 2008
    can you please mention as to which comment your reply is aimed at?
    did the firmware update solution didnt work?
    can you explain me the procedure you followed to update the firmware? and where did you get stuck up and failed?
    Genius:
  • 2,035 Answers
Remove the batteries and memory card for 20 min and then power it on if it does operate properly then try with new battery even if it fails then ..it requires servicing ...
Good luck...
  • 749 Answers
Battery and power source
1: The camera cannot be operated even
when it is turned on.
• Is the battery inserted correctly?
– Check the direction of the battery.
(P13)
• Is the battery sufficiently charged?
– Use a battery that has been
sufficiently charged.
2: The LCD monitor turns off while the
• Is power save mode (P18) or economy
mode (P19) activated?
– Press the shutter button halfway to
cancel these modes.
• Is the battery exhausted?
3: The camera turns off immediately
after it is turned on.
• Is the battery charge insufficient to
operate the camera?
– If you leave the camera on, the
battery will be exhausted. Turn the
camera off frequently by using power
save mode (P18) etc.
here ius the link to your manual online....
http://service.us.panasonic.com/OPERMANPDF/DMCFX12.PDF
    Sergeant:
    Champion:
  • 331 Answers
I dont know may be ur connection with the computer damaged the camera.....
do u have a reset button on ur camera if yes try resseting the camera ...
hope this will bring it to a natural state
    Brigadier General:
  • 6,966 Answers
Basically, three possibilities:
  • firmware glitch, reset, remove batteries or flash (inshop service);
  • hardware fault, again, inshop service;
  • low power (even with new, freshly charge batteries). Try cleaning the battery terminals/contacts. They may have to be scraped to remove corrosion. In some instances, they may even have to be bended/stretched so as to propvide more pressure/contact when the batteries are installed.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • 3,037 Answers
I think you may have a loose cable inside the camera. First try removing the batteries and reinserting them and see if it will work, if not, then open it up and look for a loose cable. Does the lens extend still when you turn it on?
  • Benjamin Patri
    Benjamin Patri Oct 21, 2008
    ok, with the extra information, then you should try removing the batteries and see if it will reset itself, let me know what happens
  • Benjamin Patri
    you have tried resetting it by removing the batteries correct?
    you should also try reconnecting it to your computer and then downloading the newest Firmware from the panasonic website onto the camera
Camera completely frozen. Lens protector open. Won' start with battery or AC power. Performed hard reste, no change.
have you tried removing battery and putting it back in? also what does "frozen" mean specifically? is it frozen in the menu with buttons not working or not powering up at all?
Aug 03, 2010 | HP Photosmart R827 Digital Camera
Touch screen frozen
the best solution to fix this problem is to get it repaired or replace if it is still under warranty.
I'll let you know if there is any other solution to fix this.
Apr 12, 2008 | Sony Cyber-shot DSC-N2 Digital Camera
How do I reset. I have pressed a button and I now have a grid, which I dont want. I only use the tulip sign and the x1 Help. Many thanks.
Issue: How do I reset the camera to its default settings?
Solution: Procedure for resetting the camera to its default settings PowerShot SD960 IS.
Resetting Settings to Their Default Values - PowerShot SD960 IS. 1. Turn on the camera and press the <MENU> button to open the menu. 2. Using the arrowrightbutton.gifbutton, highlight the yellow setup_icon.gif(Set up) tab. sd960menupress.jpg 3. Using the arrowdownbutton.gifbutton, select [Reset All..] and press funcseticon.gif. sd970reset.jpg 4. Select [OK] and press funcseticon.gif. sd970resetall.jpg
  • Settings cannot be reset when the camera is connected to a computer or to a printer.
  • The following cannot be reset:
    • Shooting mode
    • The [Date/Time], [Language], [Video System], and [Time Zone] options in the setup_icon.gif(Set up) menu
    • White balance data recorded with the custom white balance function
    • Colors specified in the [Color Accent] or [Color Swap] modes of My Colors
    • The image registered as [Start-up Image]
Aug 02, 2010 | Canon IXUS 960 IS Digital Camera
The off and on button seems to have quit operating. It needed new batteries. We installed them and then we are unable to turn the camera on.
As a first step towards resolving your issue, we recommend you restore
the camera's default settings. You can reset all of the menu and button
operation settings to default except for Date/Time, Language, and Video
System. To reset these settings, please follow these steps:
1. Take the memory card and battery out of the camera for 20 minutes.
2. Please use a clean pencil eraser to rub the contacts on the battery.
Please do not store the batteries in the camera for travel. The
batteries will discharge even if the camera is not powered on.
3. Place a fresh (or fully recharged) battery in the camera.
4. Turn the camera on.
5. Put the camera in picture taking mode. Ensure the display is on.
Jul 20, 2010 | Canon PowerShot A630 Digital Camera
How can I restore my camera's original settings? I've misplaced the manual & 7 yr. old played with settings.
Holding down the menu button for 5 to 10 seconds usually brings up the reset menu. But if that doesn't help, here's your user manual direct and free from Canon. By the way, just out of curiosity what symptoms is your camera experiencing?
Jul 10, 2010 | Canon PowerShot A95 Digital Camera
Date and time mode
How to reset a Cyber-shot® digital still camera back to original factory settings. Solution
sp.gif sp.gif Cyber-shot cameras nowadays have a built-in rechargeable battery for retaining time, date, and other settings. Since the built-in rechargeable battery is not removable, current Cyber-shot camera models can only be returned to the original factory settings by pressing a small RESET button on the camera or by using an Initialize option in the menu.
Older-model Cyber-shot cameras (prior to the year 2000) do not have a built-in rechargeable battery and do not have a RESETbutton or Initialize option in the menu. These cameras require a manual power reset.
IMPORTANT: To determine whether or not your camera has a RESET button or Initialize option, or for other model-specific information to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
Follow the appropriate procedure below for your camera.
Using an Initialize option in the menu
Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
Using a RESET button
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
Performing a manual power reset
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
If your camera is experiencing an issue and the issue is not resolved by performing the appropriate reset procedure above, then service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Sep 01, 2009 | Sony Cyber-Shot DSC-P73 Digital Camera
When i turn on my camera the lens goes in and out but it wont let
Hello!
First, check if the Battery inserted in the Camera is fully charged. If not then charge the Battery to its fullest then insert it in the Camera to check its operation.
Next, remove the Battery from the Camera then press and hold the Power button for 30 seconds. Then, reinsert the Battery pack in the Camera and turn it ON and check its operation.
Finally, please check if the menu screen is accessible by pressing the menu button directly or while reviewing the captured images. If the menu screen is accessible then reset the Camera to the original factory settings.
Perform the steps given below to reset the Camera to the original factory settings:
(a) Please press the menu button directly or while reviewing the images to access the menu screen.
(b) Then, press the right arrow on the control button to select Setup option.
(c) Next, use left/right/up/down arrow on the control button to select "Setup 1" option.
(d) Then, select the "Initialize" and OK.
(e) Finally, follow the on-screen instructions to set the clock on the Camera.
performing all the above steps will reset the Camera to the original factory settings.
If, even after performing all the above steps, the issue persists then the issue is related to hardware malfunctioning and service will be required.
Please feel free to contact for further information or any clarification.
Aug 21, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
New camera that doesn't respond...
I am assuming you are talking about a Polaroid 8MP I830 camera.
http://www.polaroid.com/service/userguides/digital/cameras/i830_ug_en.pdf
Link for manual
Factory reset
Resetting to Default Settings
You can easily change all the settings you made back to the camera default setting by the following steps.
Please refer to "Camera Default Settings" on page 103 for more details.
1. Access the setup menu.
2. Press or to select (RESET ALL).
3. Press the or button.
4. Press or to select "YES".
5. Press the button.
Setup Menu 3/3SelectExitBattery Type AlkalineReset All NoSetup Menu 3/3SelectOKBattery TypeReset AllYesNo
NOTE:
The following settings do not change with this procedure:
• Date & Time setting
• Language setting
• TV out setting
Contact Information
Phone: 1-877-388-3779
Email: Click Here
Customer Support Hours:
(Mon - Fri:) 10:00am - 7:00pm EST
(Sat:) 10:00am - 4:00pm EST
Warranty on Cameras 1year parts and labor
There is no response from the camera while pressing any buttons.
The LCD screen is frozen or the camera is hanged.
Remove and re-install the battery or batteries to reset the camera. Your valuable data stored in the camera will not be lost.
I hope some of this helps, if not above is the contact number for Polaroid tech support. You camera seems to be still covered under warranty.
Good Luck
Mar 28, 2008 | Cameras
Camera Frozen
I tried Option No.1 successfully when my Panasonic DMC-FZ7K froze once:
Option No1:
1. Try turning the camera on with the battery inserted.
2. Now remove the battery while the camera is on.
3. Flip the switch on the camera to off, then insert a fully charged battery. (Make sure that the battery's orientation is correct. Also make sure that the battery being used is not damaged).
4. Now flip the camera's switch to ON again.
Option No. 2:
If you can open the Setup menu then the camera can be reset which might help:
Turn on the camera.
1. Press MENU SET.
2. Press the left arrow button.
3. Press the down arrow button.
4. Press the right arrow button.
5. Now, press the up arrow button several times until the menu item named RESET is highlighted. Push the right arrow button and then select and set YES when the camera asks to be reset.
Oct 18, 2007 | Panasonic DMC-FX07 Digital Camera
Camera is "frozen"
Use a card reader, in case you cannot connect the camera to the PC, and download all card contents into the PC. Use a known good card on the camera, see if there's any difference. You can also format your old card, just make sure you don't do it in a different format that will later cause you more trouble. When the camera was stored for 6 months, did it have batteries in it? Check for corrosion on the contacts, and try cleaning if there is any. you can use a pencil eraser, just make sure to clean all the pieces. Hope you work it out
Jun 17, 2006 | Olympus Camedia C-4000 Zoom Digital Camera
Panasonic Lumix DMC-FX10 Digital Camera Logo
174 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
