Question about Panasonic PT-47WX53 47" Rear Projection HDTV
20" PANASONIC TV Model#CT-20G14A Chassis#DP326
  1. Picture does not fill the screen vertically,but does so if the TV COVER IS TAPPED, However it only remains filled for a short time and returns to the defective condition after a short time. Apart from this condition everything else seems ok with this TV.
sout
  • 10 Answers
SOURCE: Picture shows only about a 2-3" blue,green,or red vertical line down the middle
If your seeing vertical line across the screen you need to check the components in the vertical stage as well as the vertical IC could be bad, or the yoke could open.
Also check if any voltage reaching the vertical stage.
Good luck.
Was this help full.
Posted on Dec 29, 2007
  • 8 Answers
SOURCE: Panasonic CT-27624CA TV chassis AP 335
you have problems with Ic vertical la7848 you need resoldering or change
Posted on Sep 12, 2008
  • 14 Answers
SOURCE: Panasonic TV model CT 27D10B fried by lightning surge
Hi There,
I am unsure as to "where to start looking" means? Do you mean parts to fix it or new TV's?
If you are looking to fix it, you will end up spending a lot more than you prolly want. The surge could have blown a board, Power Supply, fuse, capacitor, transformer or a combination of them all. These TV's are only 27" and if you look on government websites you will see they start the bidding around $5 for the whole TV. If you are looking to upgrade I would suggest balancing a budget that works for you especially with the economic issues going on. 1080p is the latest being talked about, but that doesn't mean it will work for you. I went to Walmart and spend $600 on a Visio HDTV 1080i and I have not had a problem yet (knock on wood). I would not suggest buying a Panasonic HDTV but that is my personal opinion - the majority of issues I have resolved at my full time job came from Panasonic Projection TV's and HDTV. At the same time they were able to shoot out one of first 103" TV's but that just means some tech will have a bigger TV to fix in the future - LOL..
Hope this helps and feel free to rate me..
Happy Holidays..
Posted on Dec 24, 2008
freetek
  • 5568 Answers
SOURCE: Vertical lines across screen on my panasonic tv PT-61LCX65
Try setting a portable fan aimed toward the cooling vents on the back of the set. If this eliminates or reduces the occurance of the lines, this means a circuit that controls the off/on of individual pixels has developed a thermal problem. This circuit is ordinarily loacted on the main circuit board and is likely to degrade further. You might inquire at the Panasonic service center if they have an exchange program in place and they will probably be able to confirm my suspicions.
Posted on Aug 09, 2009
Horizontal lines across TV screen Pansonic CT 35g25
Check its vertical output section circuit for any component damage or loose soldering terminals. Check the solder terminals of the vertical output IC. Resolder all the suspected solder terminals by applying al little more fresh solder, without making any solder bridge short in between adjacent solder terminals.
If this do not help you, replace the vertical output IC. Lose of Vertical Scan is the problem of your TV.
Aug 04, 2012 | Panasonic CT-35G25 TV
How to go in service mode on panasonic ct-20g14a
Type in this link address, [without brackets] either to Google Search Box or into the Address Bar to your browser and press Enter. It has all the details about how to enter into the service mode to many brand TVs, and how to adjust data values.
electronicshelponline(.)blogspot(.)com
In name [Electro-Help]
Apr 16, 2012 | Panasonic CT-20G14 20" TV
Panasonic CT-27SL15 has scan lines on top 4 inches of screen, what is problem and how to fix?
Nov 2011 - Comment
Have similar problem on a Panasonic Tau model CT-27SL15.
It's a 27" CRT TV manufactured around 2005.
Other posts / solutions on this problem say possibly a capacitor going bad in the vertical circuitry / near the vertical IC / vertical blanking circuitry. Telephone call to a TV repair person mentioned something similar - "possibly a bad capacitor in the vertical circuitry".
Found a service manual online w/schematics and board layouts.
Panasonic Service Manual
http://dl.dropbox.com/u/35219914/PANASONIC%20CT27SL15.pdf
See pg 25 (of 42) - Deflection Schematic Diagram (Main PCB)
Shows: V Output IC - IC401
Finding the actual bad component(s) may not be so easy.
Anyway ... just wanted to add this comment.
Feb 11, 2010 | Panasonic CT-27SL15 27" TV
Picture on TV ''squeezed'' to center of screen horizontally
Check the horizontal trafo output voltage,the capacitors and the power supply voltage (135-155V dif.the tube diameter).
Aug 14, 2009 | Panasonic Televison & Video
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
PANASONIC CT-27D30B
Maybe the vertical IC output are damaged you need to replace him
Sep 19, 2008 | Panasonic CT-27G14 27" TV
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Insufficient vertical height
1 it is due to electrolytic capacitor defective in vrtical output stage. 2 loose contact in vertical. 3 fault due to feedback ckt in v/stage. as per schematic diagram is concern check www.serviceinfo.com
Sep 28, 2007 | Televison & Video
Sep 10, 2007 | Panasonic CT-27SL15 27" TV
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
137 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
