Question about PC Chips MB PCCHIPS P25G V3.0 P4M800CE 478 Motherboard
Motherboard P4M800CE-8237 Pin connection
Dear friends
I need to know in which order I have to connect the cables of the panel
They have colours but I don´t understand the position of them.
Best regards
Orlando Santos
  • ohfs55 Oct 22, 2008
    Thanks for the tip
    Regards
    orlando santos
    President:
  • 2,351 Answers
Hi ohfs55, case's vary & so do the wire colors. The most common wire color for positive are colored wires. Blue, Green, & red. The most common color for negative is White & or black. I wasn't able to find your manual. If you have the manual for the motherboard there will be a page that will show where the positive & negative wire's connect for each jumper to the motherboard.
Without the manual I can not guide you through each connection. PW = power switch, RW =Reset switch, HD_LED = Hard drive LED ECT.
Mike
Posted on Oct 22, 2008
  • Mike Peluso
    Mike Peluso Oct 30, 2008
    Hi Orlando,
    Here is the order in which the all your front panel jumpers connect.
    HDD-Led, Pin 1 positive, pin 3 is negitive. Power led, Pin-2 is positive & pin-4 is negetive. Reset switch, Pin-5 is positive & pin-7 is negetive. Power switch, Pin-6 is positive & pin-8 is negitive. MSI has the front panel motherboard pins upside down from most standard motherboards.
    If you find this more helpful please adjust your vote.
    I was unable to download the manual at my last post.
    Mike
What are front panel connections on motherboard?
Font panel connections are the power and reset buttons and status led's.
front-panel-connections-motherboard-u2of3ikpdsr23qnsqxf3hbc3-2-0.jpg Ignore pin 9
The color order on the reset and power switch are not important but see that you insert the colored cable to the power led to pin 2 and the colored cable for the hdd led on pin 1
Oct 05, 2015 | NEC Galileo 845GL (N4-IBFGL) Motherboard
Bios update
If updates are available, you can always get them from the motherboard manufacturer's website.
Why do you think you need an update? If something goes wrong like a power cut, or computer problem, your motherboard will be scrap. Doing bios updates is very risky and should only be undertaken if absolutely neccessary.
Regards
sir andrew
Nov 25, 2009 | Computers & Internet
I need to download a sound driver for Motherboard Model: P4M800CE-8237
This page should have what you need:
http://www.via.com.tw/en/resources/download-center/
Jul 11, 2009 | PC Chips MB PCCHIPS P25G V3.0 P4M800CE 478...
I want audiodriver for p4m800ce-8237-6a7l6b097 audio driver.
Most drivers I get are on the web site driverguide.com but you need to register and it is free once installed reboot the computer
Jan 22, 2009 | PC Chips MB PCCHIPS P25G V3.0 P4M800CE 478...
Fpanel
Hi, the most common case colored wires used for negative - is white. The colors blue, red, green are usually positive +. The internal speaker though it uses a 4 pin connector only plugs onto the 2 end pins. Black is connected to negative - pin & Red is connected to + positive pin. Go to page 1-26 & zoom in. The case's connectors should be marked closely like the on-line manual. All these case LED's use 5volts DC. If you make a boo-boo (place the connector on back-wards, don't freak out). You can usually shut down the system & turn the connector 180 & re-connect it with out hurting the board. I know it’s a tight fit, so start with the power switch & test it once connected.
You should be just fine.
Good luck unreal_class!
Mike
Sep 09, 2008 | ASUS K8V-MX Motherboard
Via p4m800 CE - 8237
You set your BIOS to "SATA = Enabled" under that set it to
" IDE ". Most 160gig HDD's are only 1.5gig max read/write. Hope you left the jumoer pin on.
Dec 03, 2007 | PC Chips MB PCCHIPS P25G V3.0 P4M800CE 478...
Pin Connection
It attaches to your choice of one of the two open and available USB sockets as I've circled in this image. Each USB socket has two horizontal rows of pins. A row with 5 pins. (the 5th extra pin is not used) A row with 4 pins. The first pin (on your left) is power, the last pin (on your right) is ground. ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | Biostar P4M800-M7A Motherboard
Computers & Internet Logo
5,440 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
