Question about Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Viewing PC on Sharp Aquos LCD TV
I am unable to view my PC on my Sharp Aquos LCD TV. Blue screen only. Changed dimension on pc output to match LCD options but still nothing. I tested output on another screen and it shows right up. Any ideas? The "PC" input is selected. The TV inputs work fine. It is just the RGB/PC input that shows nothing. It did work at one point. I haven't used it as a PC monitor in about a year and now it stopped working. It is actually a Sharp Aquos LC-20B6U-S serial number 406319139
SOURCE: Audio Problems with Sharp Aquos T. V.
I called Cox Communications and the technician told me to disconnect every cable or connection and turn the DVR and T.V. off. Cox ran a diagnostic check to make sure my DVR was reading proper info from their center. It was, and then I reconnected everyhing, cables, HDMI plugs, and finally turned the DVR on. It read Boot, and then, I waited for the time to show. When it did, I turn the T.V. on. It has worked great since then. No problems with sound or picture. Hope this helps someone.
Posted on Nov 22, 2007
SOURCE: LC-37D62U Sharp Aquos HDTV Settings
lost sound on Sharp Aquos 37LCD62U
Posted on Jan 25, 2008
satavlad
  • 405 Answers
SOURCE: Sharp Aquos LC-3237U keeps turning off what could
Check if the power menegment is enabled. Go menu> power control ind see if NO OPERATION OFF is enabled.
Posted on Nov 06, 2009
  • 8457 Answers
SOURCE: sharp aquos no sound through hdmi
Reset all audio factory setting.Tries unplug,replug it well work,if ur backlight video board it still good.
Posted on Dec 17, 2009
Testimonial: "worked like a charm thank you so much, i was about to throw in the towel and get a new tv, now i don't have to thanks again"
SOURCE: Can I use the AVC system of a Sharp LC 30HV4U on a LC 37HV4U TV
i have the sharp lc-30hv4u but i dont have tha avc box i need buy the box if do you have i can buy call me 702 3280184 thanks
Posted on Dec 18, 2009
How do I display PC screen onto Sharp TV LC26SB24? I've lost TV user manual
Depending on your OS on most computers you need to either add a second monitor output or change the settings to tell the PC to redirect the video output to and external device instead of the PC's screen. Check your OS settings.
Jan 01, 2015 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-40C32U: Black screen, various vetical colored lines for extended period after turning tv on (volume button changes appearance of vertical lines)
Sounds like panel fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Screen-shots do defective LCD panel are given. You can see and compare it to that of your TV's.
Apr 21, 2014 | Sharp Aquos LC-32D40U Television
How to replace the burned led light in my Sharp Aquos LC52LE810UN?
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 09, 2014 | Sharp LC60LE810UN 60 in. LCD TV
Have sharp quos 52" screen went pink. Can still
Hi, My guess is your daughter messed it up. Go to menu and color and reset to default should fix it.
You may have to adjust color for your best viewing. Good luck.
Sep 27, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
When i go to pc mode on my aquos 42 inch the background and screen is blue not the blue screen of death the set is 2 yrs old
That sounds like a resolution problem. If you have a PC attached to the TV, unplug the monitor cable, and plug a computer monitor to the computer. Change the resolution down to 1024x768, then try plugging back into the TV
Jan 12, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Dark lines on Sharp Aquos 42" screen.
if the unit is stll under warrenty it would be best to take it back, it does sound like that it is the lcd that is faulty, or contact Sharp to see if the can repair it for you
Thanks
Oct 19, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos 40lcd will not play bluray
You need to change the resolution on the Blu-ray to 720P to match the Tv native resolution.
Jun 26, 2009 | Televison & Video
Screen shuts off. Power lite blinks. Aquos 42"
Hope you have the correct resolution selected:
HD View Modes: When viewing an HD program you can select the following 4 viewing modes.
  • Stretch: suitable for viewing 1.78:1 DVDs. When viewing 1.85:1 DVDs, this mode will show thin black bands at top and bottom of the screen.
  • Dot by Dot (1080i/p only): detects the resolution of the signal and displays an image with the same number of pixels on the screen. When a 720p signal is being input, the image will be delivered in full screen.
  • Smart Stretch: suitable for stretching 4:3 programs to fill the screen.
  • Zoom: suitable for viewing wide-screen 2.35:1 aspect-ratio programs in full screen.
PC View Modes: You can connect the TV to your PC through the HDMI inputs to use the TV as a monitor. The following view modes are available in PC mode.
  • 4:3 Input Signal: You can select between Normal, Zoom, Stretch, or Dot by Dot.
  • 16:9 Input Signal: You can select between Stretch or Dot by Dot.
Also verify if you have set auto timer to 30 mins or so thats why the TV shuts down after a particular time.
Thanks
May 07, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-30HV4U 30 in. LCD HDTV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
