Question about Bosch HBN 430560B / 430520B Single Oven
Bosch HBN430551B Single Built In Oven
Trying to install the above oven. Need to know how to connect the electrical cables to the oven - do you wrap the electrical cables around the screws? There are three wires - yellow and green, brown and blue. How do I connect the wires to the screws?
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: bosch hba34b520
Yes, it is o/k to have a single oven connected to a 13 amp power supply supplied with a 2.5mm cable.
A lot of single ovens already come with a 13 amp plug fitted, so you can plug it straight into a 13 amp socket.
If there is no covenient socket nearby, then you can wire the 2.5mm cable srtaight into the oven terminal block.
I must stress that this only applys to a single oven and not a double one.
Plz rate my solution.
Thanks.
Posted on Jan 14, 2009
Bosch built in oven
ok try there maybe a recall list as there is with there dishwashers try the list see if ure model number is on the list then if it is either send it for repair or rtn it most people still are using recall listed units
Apr 25, 2013 | Bosch HBL5450UC Electric Single Oven
Do i need to hard wire a single oven
Welcome to FixYa.
You don't HAVE to hard wire, you can install a regular oven plug and receptacle outlet, but this is the recommendation of Bosch.
**Before installing the oven have a qualified electrician verify that your home is provided with adequate electrical service and that the addition of the oven will not overload the branch circuit on which it is to be installed. A separate three-wire or four-wire single phase, 240 Volt, 60 Hz., or a 208 Volt, 60 Hz. branch circuit is required.**
I'm not sure how clear this will come out when I post it, so if it is not acceptable let me know. I can send you the complete installation guide "pdf" via email if you post an email address.
I'll watch for your reply, good luck. Thank you for choosing FixYa today for your inquiry.
Regards,
Macmarkus :)
Jan 09, 2011 | Bosch HBL 442 / HBL 446 Electric Single...
Hi i have a Stainless Steel AE6BSS Single Built In Electric Oven from argos, everytime i put oven on above 120 it trips all electric down stairs does anyone know what this problem could be thankyou
It will most likely be a faulty oven heating element causing an earth fault which trips the breaker.
You will need to have a replacement element fitted.
Dec 11, 2010 | Ovens
Just had delivered Boch HBM13B221B Double oven. There is no cable. How do I attach it to the electrics in the house
Hi.
You need to wire it up with 6mm twin and earth cable.
You must connect it to a seperate 30amp double pole cooker box, and nothing else.
Do not onder any circumstances connect it to a 13 amp socket outlet,
Unless you have a good knowledge of electrics, then I would recommend you get a qualified electrician to wire it in for you.
Please rate my solution.
Thankyou.
Jan 14, 2010 | Bosch HBL 442 / HBL 446 Electric Single...
Bosch hba34b520
Thanks.
Jan 13, 2009 | Bosch HBL 442 / HBL 446 Electric Single...
Installing oven wrap and back insulation
Normally all you need to do, is just simply wrap the new insulation round the outer oven compartment, and it holds itself in place, would not recommend useing adhesive, if you can't get it hold in place, then twist some thin wire round to hold it in position.
Thanks.
Jan 07, 2009 | Bosch HBL 442 / HBL 446 Electric Single...
Can't locate the electric ;ead from the oven
Hi
Some ovens do not come with lead, so it is uo to you to provide one and connect it up.
Nov 14, 2008 | Bosch HBN 560570B / 560550B Electric...
Installing a Zanussi ZBF260 oven
I've got the same issue, looking at them it's either the blue or yellow ones you want, the manual states that it should be installed with 2.5mm flex cable if going to a plug and 2.5mm twin and earth cable if your going to an electrical outlet.
Mar 07, 2008 | Zanussi ZBF260 Electric Single Oven
Bosch built under oven
you can try high-temp gasket maker from an auto supply store.
Jun 04, 2007 | Bosch HBL 745 Stainless Steel Electric...
Bosch HBN 430560B / 430520B Single Oven Logo
88 people viewed this question
Top Bosch Ovens Experts
ashburton
reliableservice
Are you a Bosch Oven Expert? Answer questions, earn points and help others
