Question about Sakar Adrenaline ComfortZone(78033) Headset
Does this headset have a shielded cord?
Anyone know how long the cord is on this headset and if it's shielded?I've looked everywhere on the internet but cannot find a thing about it.To people who own this headset,if it doesn't say on the box how long it is,could somebody measure it to see how many feet long?Thank you
0 characters
1 Points
I have a telex airmen 850. I tried calling to see if it was still under warranty- with no help. It's $200 flat rate fee to ship it there... Is there somewhere else I can send it to be fixed? It was working...
Don't know why answers for different type of headsets shown up on a question about the Telex 850. Probably there is an issue with the cord. The cord has two shielded "double" wires on each pair. The ones for the mic are "white" and "light blue". May be one is cut preventing the mic to work. Look around for a local avionics shop, they should be able to fix it. Hope this helps ;)
Apr 19, 2011 | Telex Headsets
Dont know how to hook it up to phone...have S10A and S11 model plantronics corded headsets
Turn over the S11 base and insert the headset slot. This is at the top of the base. Remove the handset cord from your telephone base and plug into the handset jack (there will be a picture). Using the short cord that came with the S11, plug into the line jack on the back of your base and the other end into the slot on your telephone where you removed the handset cord. Plug the headset cord into the headset jack that is on your S11 base. Connect the the A/C power adapter to the S11 A/C jack and a wall outlet. Put on the headset. Press the handset/headset switch and pick up the handset off your telephone, set it aside to make calls. Slide the configuration switch (on the side of the S11 base) until you hear a clear dial tone.
Good luck from Headsets Direct!
Aug 24, 2010 | Plantronics (45647-04) for S10, T10, T20...
I try to connect my Sony Ericsson HBH-DS205
Hullo Tillgustaf
I understand you need an A2PD compliant bluetooth adaptor. I’ve just installed one on my PC at work, asked Windows to look for updated drivers on the internet and it has installed correctly.
You can get an A2PD adaptor from Amazon for £1.50 here
Best wishes,
Dec 29, 2009 | Sony Ericsson HBH-DS205 Bluetooth Earset -...
Cut Skullcandy cord and confusing splicing process.
well i dont know how to repair them but you can get the warranty for 50% off another pair. does that help?
Dec 18, 2008 | Skull Candy KB Electronics Skullcandy (...
Connectivity jabra bt150 and iPhone
Yes finalIy solved it myself. I went to the site of, they have made a great manual fotr the iPhone (and other brands).
Dec 05, 2008 | Jabra BT125 Headset
Jun 18, 2008 | Plantronics - Bluetooth Headset Plus Base...
Replacement ear pads
Jan 24, 2008 | Logitech Internet Chat Consumer Headset
Motorola slvr L6
go to cingular device support service and you will find the answers there.
Jan 24, 2007 | Motorola Mobility Earwrap Handsfree For...
No Internet
You need to contact your service provider, who will send you the required settings for internet.
Oct 25, 2006 | Motorola Mobility V600 / V620 Earbud Hands...
Problem with internet browser of k750i
Hey i am having the same problem with my k750i and i have also done everything you ve done, then the problem should be with the phones.
Aug 10, 2006 | Sony Ericsson HBH-610a (Auto Pairing)...
Sakar Adrenaline ComfortZone(78033) Headset Logo
24 people viewed this question
Top Sakar Headsets Experts
Brian Sullivan
Brian Sullivan
Are you a Sakar Headset Expert? Answer questions, earn points and help others
