Question about Acer TravelMate 3260-4542 Notebook
Useing note book with data projector
What keys to i Push to set up note book with with data projector
  • bazzaciz Nov 03, 2008
    The manufacturers pass word was a nother problem thanks for your help
  • Anonymous Mar 25, 2014
    it crashed an got sent out to samsung in NJ.they put a generic os in w-8??help
    Genius:
  • Acer Master
  • 1,250 Answers
Connect through the vga port of the laptop, then press Fn key and the key mark monitor on your laptop, F5 together
Posted on Oct 21, 2008
The radio is asking me a code I don't have the book to unlock the radio
IMPORTANT NOTE:
You must have the security anti-theft code for your VW radio from the car manufacturer, or from a VW dealer!
You can find the radio code at: http://www.radio-code.co.uk/
The sequence of VW radio programming is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
For example: we have the security code "5079". Then:
3. By the no.# 1 key you will set up the first safe code digit. Push 5 times on the no.# 1 button. The "5" number will be setted.
4. By the no.# 2 key you will set up the second safe code digit. Push 10 times on the no.# 2 button. The "0" number will be setted.
5. By the no.# 3 key you will set up the third safe code digit. Push 7 times on the no.# 3 button. The "7" number will be setted.
6. By the no.# 4 key you will set up the four-th safe code digit. Push 9 times on the no.# 4 button. The "9" number will be setted.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed.
The radio is now ready for use!
Sep 08, 2011 | 1998 Volkswagen Passat
Radio is in safe mode the code in book dose not work
IMPORTANT NOTE:
May 03, 2011 | 2001 Volkswagen Cabrio
Radio is in safe mode the code in book dose not work was tol to take out radio to find the code
IMPORTANT NOTE:
May 02, 2011 | 1998 Volkswagen Cabrio
How do I connect the laptop to the projector using Power Point.
Connect the data projector to the video port on the laptop. Then power up the data projector and then the laptop, the video data will automatically be diverted to the data projector.
If you want to see the Windows image on your laptop screen as well you need to press and hold down the FN key plus one of the function keys on you laptop which has a screen symbol. Pressing this key will toggle between the laptop screen, data projector or both laptop screen plus data projector.
You can open Power Point and select your presentation as you would normally.
Nov 14, 2010 | Computers & Internet
Which function buttons do you push to switch the image form the laptop to the projector?
If you connect the projector to the laptop and power up the projector first and then the laptop, the video data will automatically divert to the video port/projector .
On most Presario press the Fn key and the F4 key The function key will have a screen symbol printed on the key.
Mar 06, 2010 | Compaq Presario 2140US Notebook
I can't project my image from my laptop to the projector..
A usb cable will not work that way--on your projector, it's used for data...you need to obtain a monitor cable which will plug into the vga connector on the laptop and into the connector on the projector (rgb in 1) or (rgb in 2) If you use the #2 rgb input, make sure the button IS NOT pushed in! If it is, the projector will be switched to OUTPUT mode on the #2 connector. Also, on the laptop, normal operation is "laptop only"...when you push the <alt F4> buttons, it should then switch to "laptop + external display(projector)", another <alt F4> push will give "external display only" mode. Then, another push will return you back to "laptop only". NOTE: Sometimes, you have to turn on the projector first, then immediately turn on the laptop--not to get technical but different equipment can get finicky about syncing up...just something to be aware of...
Aug 31, 2009 | Hitachi CP-X250 Multimedia Projector
I can't get the display from my laptop to project to a screen.
If you connect the data projector to your laptop and power it up first then your laptop, the video will switch to the data projector automatically.
If you had powered up the laptop first then you can divert the video information to the external video port/data projector by holding the Fn key and then press F4 key.
You can toggle between the LCD screen, the data projector or both LCD and data project together using the Fn & F4 keys.
May 25, 2009 | Compaq Computers & Internet
Need to see display on both laptop and projector
On most laptops pressing the Fn key plus the F5 key (in your model laptop) several times will cause the video to switch to different options
In the various laptops I've used with data projectors it is the same.
If you plug in the data projector and power it up then the laptop then the Windows image will be on the data projector (provided the laptop's screen resolution matches the data projector).
To toggle between the data projector only, the LCD screen, then LCD screen plus data projector, and or back through this sequence, just press the Fn key and the F5 key to get the displays you want .
May 20, 2009 | Toshiba Tecra M10 Notebook
Sanyo Projector & NEC Note Book Incompatible.
You have to select I think it is function F8 or Function something to show or activate dual display function. Go to help menu in the computer and that may help you in this matter. Let me know if this helps. Thank you Jay
Jan 29, 2008 | Office Equipment & Supplies
Acer TravelMate 3260-4542 Notebook Logo
109 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
