Question about Kenwood KAC-9102D Car Audio Amplifier
Amp Light Won't Stay On
Installed the amp as per instruction manual yesterday. The power indicator light came on during the first test, but began to dim out. Again, without cycling the cars power, the light came on and dimmed again. It continued to do this, all while outputting no signal to the subs. When the car was powered on and off, the amp light will not come on anymore. All the wires were unplugged and replugged, but still no response.
  • 1 more comment
  • Siddhesh Patel Jul 22, 2006
    I'm going to probably say its with the wiring, because this is the second amp that started doing this. About a week ago, my old amp started having this problem. So I took it back to the retailer, I had purchased a four year warranty with it, and they replaced the amp, didn't really look into it. I hooked up the new one, and the same problem arose. I checked the wiring, and the 12 volt seems to be fine, I'm assuming it is something with the ground. I'll post anything I find. Thank you for your help.
    It was the 12-Volt in. I went out with a voltmeter and checked the REM and got approx. 12 volts to ground. Then I checked the battery and was getting only about 1 volt. I found a loose connection leading into a fuse. Tightened up the connection and was good to go. Thank you very much....
  • AARONMELTON5 Apr 21, 2009
    the amp i have has a problem,everything is hooked up right but the power light is turning off and on and my 10' sub goes in and out real slow and every 30a. fuse i put in the amp. blows.i swapped out the amp. and i have the same problem occurs but the light does not turn on the fuse blows every time power is connected...maby a dumb question but need help.
I had the same problem installing my amp as well. My solution was a bad ground. I have an S-10 so finding the proper place to ground was tough, I now have it grounded to the drivers seat under the torque bolt.
Posted on Jun 05, 2008
  • 215 Answers
Sounds as if you either have some bad wiring probably on the 12volt side or a major problem with the amp. Seeing as how it's new I'd be taking it back to the retailer. I just hope you didn't reverse the polarity of the 12 volts or maybe put 12 volts up a speaker output. That could mess with the warranty somewhat. Are you sure you have the 12 volts connected to a good solid supply and the earth a good one too. I always ensure any heavy drain equipment is connected directly to the battery with heavy duty wiring and well fused. BMW
Posted on Jul 22, 2006
Stunt copter won't sync
I presume you have lights & sound on the controller when you turn it on - fourteen quick beeps and then a different toned fifteenth beep. The screen lights (blue). Insert the battery (lettering facing up toward the helo fuselage unitl it's seated all the way - an LED inside the fuselage, visible from behind, quick flashes and then begins a slower blinking.
Once the helo battery is inserted, turn on the controller, which starts the aforementioned beeping. On the last controller beep the helo's LED will stay lighted, indicating the helo & controller are synched.
I had a problem making sure the battery was inserted all the way into the helicopter. You'll know it's inserted properly when the LED inside the helo flashes.
Dec 26, 2012 | Brookstone Stunt Copter RC Helicopter
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
Recieved an F1 code during the washing startup cycling; please advice
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$%
Jun 26, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Every time I start the machine the f1 error comes up within a few seconds. have to press pause & start about 3 times & it will finally start to work. have to do this several times during the entire...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^@#$%
Jun 02, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Year old Bosch SHU33A0UC won't start. Lights on
Light's on mean you have power.
Initiate the self test program by doing the following -
ON/OFF button.
RINSE & HOLD = NTC (temperature sensor) fault – note circulation motor stops shortly after it started
during an NTC fault
where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150ºF) and water won’t stop
Let me know what you figure out. I can repair these boards most of the time.
Dec 18, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Keeps stopping during cycle and flashes F1
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^%$@
Oct 28, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 during the fill cycle
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&^%$
Sep 26, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
The Air bag light came on solid
If you want your air bag to work, you should take the vehicle to a shop for service. This light indicates it probably won't deploy in an accident.
Charlie
Aug 22, 2009 | 1995 Volkswagen Jetta
Kenwood KAC-9102D Car Audio Amplifier Logo
770 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
