Question about Kitchen Ranges
Coleman Model #5428 three burner propane stove leaks gas at the hose connection to the stove
5 Suggested Answers
  • 7 Answers
SOURCE: Whirlpool 465 Gas Stove conversion from propane to gas?
Do not use the stove until its properly converted back to natural gas. It's a serious carbon monoxide hazard.
Most ppl throw the orifices away, sometimes they are stored under the stovetop in the back, or behind it. The original natural gas orifices are the only parts you need. All orifices are labeled by a tiny stamp on the side. It will state the size and type, example: 10 LP.....meaning number 10 size and propane.
A nature gas should be labeled something like 12 NG.
Call a local parts dealer or order online the NG orifices for you model number.
I assume you do not have the setup instrctions that come new with the unit. Heres what you need to do:
1) Change the orifies to NG (the bigger the burner the higher the size number) so if you have two #10 size, one #12 and one #14...then common sence will tell you where they go.
2) convert the regulator. This is the part to which the inlet connects. Remove the vent cap,(a plastic cap, you'll see it) unscrew and flip the insert over and reinsert it (You'll usually see 'NAT' on one side and 'LP' on the other). Reinstall the cap, and that's done. The word NAT should be facing you where you can read it.
3) Then, find the brass orifice that supplies the bake burner (usually under the range, behind the drawer), and if included, the broil burner (usually inside the oven). These are adjustable, and, like adjustable top burners, are simply 'snugged' down clockwise with a 1/2 inch wrench. You need to screw these back up for natural Gas.
You know when the oven is correct, you should get a nice blue flame on top as well as in the oven. Flames with yellow tips are wrong!
Posted on Oct 28, 2008
joboo1
  • 257 Answers
SOURCE: Propane gas burner now has red flame instead of blue
Hi, If you have the same problem with your stove , furnace and water heater, Then you look for things in common that would cause the problem. Any change in the flames is an indication of a change in the fuel/air mix. The item that would be common to all would be the pressure diaphragm. This is not something a customer should work on without a through knowledge of how they work. I think you would be well advised to have a service call. Good Luck!
Posted on Feb 10, 2009
SOURCE: shipmate propane stove model #873,
Call JP at 954-817-1246 at Gearbusters or check his ebay store. He has the burners and all the knowledge you need to know.
Posted on Mar 09, 2009
SOURCE: kitchenaid gas stove left back burner won't light. hear clicking
I have a Kitchen Aid gas stove. All the burners will not light. No clicking, NOTHING. Is there a lighting switch or something that needs to be replaced ?? Or do I replace all 4 lighters ??
Posted on Jun 26, 2009
Can I buy a replacement grill?
You could try Coleman, they might be able to supply one.
The Coleman Company, Inc.
3600 North Hydraulic
Wichita, KS 67219
1-800-835-3278
TDD:316-832-8707
Jul 03, 2014 | Coleman Vintage Bernzomatic Deluxe Propane...
Primary burner won't light on electronic button propane stove
If it won't light with a match,then the orifice is plugged.If it will light with a match because you can hear the gas coming out,then your striker on the knob is bad.It's replaceable.
Apr 14, 2014 | Coleman 2 Burner Propane Stove 5430E700
Can a 20lb tank be hooked up to a Coleman 2 Burner Stove 5430A
Yes. There are multiple adapters made to fit this application. Your local walmart most likely will have them. http://www.walmart.com/ip/Coleman-5-High-Pressure-Propane-Hose-and-Adapter/19897422
Sep 18, 2013 | Coleman 2 Burner Propane Stove 5430E700
Coleman 5423b701
Try Coleman directly.
Wichita, KS 67219
1-800-835-3278
Sep 01, 2013 | Coleman Camping Stove 2 Burner Propane W/...
Why does my coleman stove regulator leak gas from the hole on the top of the regulator
Its a safety feature of the regulator. The regulator is designed with a pressure release valve. This has happened to me twice: once with a carbon dioxide tank for my kegerator and once on my propane stove. In both cases I left the regulator (designed with a max pressure rating of X psi) attached to a full bottle in the sun. The heat caused the pressure to exceed the limit of the regulator and the release valve popped. A welding supply store may be able to reset/replace the mechanism but in my case I just bought a new regulator for about $15.
Aug 14, 2011 | Coleman 2 Burner Propane Stove 5430E700
I have a Coleman two burner propane campstove and
Try cleaning the carbon out of the burners.
Jun 22, 2010 | Coleman Gas Grill Stove
My coleman stove does not let the propane pass from the hose to the burner. I have determined that the hose is releasing the propane as I can depress the nozzle and get the gas to flow. The stove is clean...
This is a camp stove issue. I fixed it with my tire pump. I opened up all the valves, duck taped the hose to the stove valve and pumped air thru the system. No more blockage. Works like a charm.
Susann
Jun 16, 2009 | Kitchen Ranges
Need to fix regulator for coleman stove 5410708
Just where the regulator attaches to the burner there is a small nut that may be loose. If you look closely at this and turn the regulator (stove off and hose detached!) you may see the nut hat turns easily. Tighten it and make sure the regulator does not rotate too freely, but still turns to adjust when attached to the hose or the smaller gas cartridge, if using that. Test carefully after this.
Feb 06, 2009 | Coleman 2 Burner Propane Stove 5430E700
Black is on the burners
the fuel to air mixture is set incorrectlty or your pressure at the ouitlet for the gas valve is too low.
you culd play around adjusting the first part of this but for the gas valve part you have to have a manaometer to check it out correctly. then it should be set at 10"wc. Good Luck
Jan 10, 2009 | Coleman Propane Grill Stove 9921-700
Kitchen Ranges Logo
217 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
