Question about Dryers
Kenmore dryer, model 97580100, gas, not heating or turning off at end of cycle.
It runs fine but just stopped heating, the timer has gone out too. The knob will count down the minutes but it will never shut off.
hotuna
  • 288 Answers
SOURCE: Kenmore electric dryer won't stop running / no heat! 110.62512101
Without anymore info. is sounds like the timer motor on the setting controller (the main knob) is bad. The entire timer/control part is usually pricey but if its made to where you can just change the timer motor that will be less. If possible check the timer motor with a meter for continuity to be sure. the parts supplier will usually help you with this, if they are worth a shit.
Posted on Dec 19, 2007
Jimster
  • 240 Answers
SOURCE: Timer on dryer counting down too fast
Now that there is a good one. Everything you are saying leads to a control board failure. Did you replace the board yourself, or have someone else do it? I have before gotten a new control board of the shelf, and it be as bad as the one I was replacing. Just a thought. Let me look around and see if I can find some other information, just really sounds like a bad part.
Posted on Feb 15, 2008
kachbibi1
  • 979 Answers
SOURCE: Kenmore Dryer - no heat and timer doesn't stop
First turn off both breakers then back on. Next, check the wiring from the receptacle to the plug to the back of the dryer. Next, the thermal switch under the top of the dryer next to or near the drum may be bad. Bypass it and see if you get heat. If so, then replace it for about $20. Your heating element may be bad also. You can visually check it and see if it is burned in 2. Now your timer is probably bad. They are easy to replace and fairly inexpensive.
I guess after looking at all this, you need to decide if it is all worth it to fix it. If it is more than 10-12 years old, you may be seeing the beginning of the end. If the thermal switch, the element, the timer are all bad, you may want to make room at the curve and take the door off for safety. Dryers aren't that expensive especially when you consider the hassle. Good luck and let me know how and what you do.
Posted on Feb 11, 2009
aasc
  • 1606 Answers
SOURCE: Gas dryer not maintaining heat. 70 Series Kenmore/Whirlpool 76722
Fuse is ok . Problem is the soils on the burner valve . If the dryer heats when started , the electricity goes thru the coils to open the valve . Once the coils get warm , 1 will open (short) until it cools back down . The coils can be replaced just by removing the front panel . Only 2 screws hold the coils in place . No turning off gas , dissasembling dryer .
Posted on Jul 19, 2009
canbruce75
  • 1776 Answers
SOURCE: Kenmore Gas Dryer Gets Hot, Shuts Off Early in Cycle
Sounds like a faulty high limit or cycling thermostat. The thermostat tells the dryer to heat until the interior of the dryer reaches a certain temp. It should be mounted on the exhause duct inside the back of the dryer. It should look something like the one in the picture:
Hope this helped and best wishes.
Posted on Jul 27, 2009
Kenmore dryer model 110 does not stop during automatic cycle
Make sure the small orange wire is connected to the 250 limit at the base of the heater assy. That is what powers the motor on auto cycle.
Nov 27, 2013 | Kenmore Dryers
My Kenmore dryer series 90 continues to rum when I open the dryer door?
If the dryer stops at the end of the cycle or when you turn the dial to off,
The door switch has gone bad.
If it does not stop at the end of the cycle the timer has gone bad.
Sep 06, 2010 | Kenmore Dryers
Kenmore Elec Dryer timer & Heat Element Failed
if you set timer on time dry it will count down but if you have it set on more or less it will not advance without heat,change out the heater and you will be fine
Nov 04, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore 11070702990 Gas Dryer - Timer does not work
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 09, 2009 | Kenmore 60172 Electric Commercial Dryer
No heat....i turned the dial while it's running
Your complete problem may lie with a bad timer. Replace the timer and it will stop at the end of the cycle. If it still does not heat, update your post for the next step.
However, replacing the timer may solve both problems.
Apr 10, 2009 | Kenmore Dryers
Dryer timer still runs after auto-cycle is complete.
can you just leave the door open when not in use???????
Mar 30, 2009 | Kenmore Dryers
Dryer does not heat
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Kenmore Dryers
Kenmore gas dryer buzzes but does not run
sounds like the start windings in the motor have gone bad. The only way to fix this is to replace the motor.
Feb 04, 2009 | Kenmore 73932 Gas Dryer
Kenmore gas dryer Model 110
hi. thanks for the question . i would replace the timer . the contacts Y and BU. Are welded together . replace the timer . thanks the appliance doc.
Aug 01, 2008 | Kenmore 74602 Gas Dryer
Dryers Logo
146 people viewed this question
Top Dryers Experts
