Question about Sony Cyber-shot DSC-W55 Digital Camera
Error Message E91:01
The flash on my DSC N2 Cybershot Camera is not working. The Error Message is E91:01.
Can you suggest repair action?
  • elizabeth75 Oct 25, 2008
    Same problem - Error 91:01 and the flash button just flashes but won't work. Any thoughts?
  • Anonymous Oct 26, 2008
    same here
  • 74 Answers
Press Menu button
togle across from REC Mode to setup
togle down thrice from camera to setup 1
togle across into sub menu
togle down from four times to Initialize
togle across again to the sub-menu
togle up from cancel to OK
press center button to accept the OK choice
Screen changes and so press okay again
It should restart the camera
Opening on the 'Clock Set' screen
togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
If it is working then don't forget to set your Clock.
Posted on Nov 03, 2008
I have a camera sony cybershot DSC-W350 and flash is not working. And I receive an error message E:91 01. What do I do?
Hi. Thanks for your question.
To get your camera back in working order you need to reset it to factory settings. Please click on the link below for a video from Sony website on how to perform reset.
http://esupport.sony.com/perl/tutorial-display.pl?tut_id=374&mdl=DSCW50
Thank You for using FixYa.
Jan 14, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
Sony cybershot soaked, turn power on and off again message
yes it is the effect of the beer,the beer molecules make shutter blades sticky resulting in failure of shutter operation,better go to service station
Mar 05, 2010 | Sony Cyber-shot DSC-N2 Digital Camera
Flash of sony cybershot dsc-w200 is not working
i think i had the same problem, if u press the home button and then press shooting then hit the flash button on the right hand side it should change the mode.
Jun 22, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
E91:01 error code W80
I will forward a link to a page where you can get the information regarding this error message.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C1002686
Jun 16, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Sony cybershot dsc-n2
I see the same type of reports on the internet for just about all types of Sony cameras.
It can occur when a memory stick goes bad or when the camera memory stick reader has a problem.
First try a reset of the camera.
You will have to check the User's Manual to see how to do this.
Next try a new (or different) memory stick and see if you get the same bad result.
If you do, it is likely the problem is in the camera.
Sony will probably want about $200 to fix the problem.
Jan 06, 2009 | Sony Cyber-shot DSC-N1 Digital Camera
Flash will not flash
Sounds like you need a new flash unit. It could be the system board, but this is not likely if you are not getting an error message from the camera.
Nov 12, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Sony CyberShot DSC-N2 - Unable to read memory card
Before anything else.... you must examine first if your card is not damage, How? Try to test it in the memory card readers or other camera that fit the same memory cards.
Some other cards do have lock option in the jacket of the card. Try to unlock it. After doing so reformat the memory card in to your cam.
Other option...... Some other cam do have internal memory, if you have the same, configured it out.
Oct 29, 2008 | Sony Cyber-shot DSC-N2 Digital Camera
Error E91:01 on DSC H7
If the camera works in all other respects, then that has something to do with the flash setting or some other setting in the menus. But this sounds like something with the flash directly.
Here is a link which may be able to help on the DSC H7: http://www.aakatz.com/whitepaper/whitepaper/appendix2.htm
Try also to reset all the menu setting back to what it was for the factory. Most digital cameras have a setting for that, and usually is something like "RESET ALL" or something close to that.
If nothing works, then the camera needs repair. This is an error to do with the flash only, it appears. So some of the internal parts could be weak, thus causing the error.
Jul 27, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Format Error in Sony Cybershot
ho un problema con la mia cybershot dsc-t5 come posso risolvere l'errore di formattazione C:13:1 su una memory stick duo prodotta da neo
Jan 02, 2008 | Cameras
Sony Cyber-shot  DSC-W55 Digital Camera Logo
122 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
