Question about Maytag Neptune MAH5500B Front Load Washer
What is the capacity of this washer
I have this, am looking to replace already because it now needs bearings
  • 725 Answers
Mah5500 has a 3.34 Cu. Ft. Capacity.
If you can stand be put on hold Call maytag customer service
complain about the washer they may fix it or send you a coupon discount for a new one
Call M-F from 8am-8pm Local Market Time
Sat 8:30am-5pm Local Market Time
Please locate the appliance's model and serial number before calling.
1 (800) 344-1274 U.S.
1 (800) 688-2002 Canada
Posted on Oct 26, 2008
  • 46 Answers
Hi would sugest that it would be 5.5 kgfrom the model no. but if you ring a maytag dist they should be able to tell you
cheers grant
Posted on Oct 22, 2008
I have an oily residue in my washer machine and my clothes how do I fix it
If its not from heavily soiled clothes like garage overalls then I would bet the drum bearing seal has gone and bearing grease is contaminating your wash. See if there is any water dripping underneath from the seal and if this seems to fit with your situation then you need a good DIY fixer or appliance engineer to have a look at it.
Aug 01, 2014 | GE WSLS1500JWW 26" Top Loader Washer with...
Ge super capacity plus washer
It sounds like your bearings are are whacked, if you have vertical
movement in the drum the bearings will need replacing , not a simple job as seals also need replacing
Dec 20, 2013 | Washing Machines
Heavy duty super capacity plus
You dont. If it is making noise drum bearings or idler needs replaced
Nov 03, 2013 | Kenmore 24032\24036 Top Load Washer
THERE'S A FUNNY NOISE COMING FROM THE BACK AND LOCATED AT THE DRUM NEAR TO WHAT SEEMS TO BE A GENERATOR (BY THE MAGNETS AND COILS INSIDE). KIND OF PLANE TURBINE SOUND. NEED TO KNOW HOW TO BRAKE IT APPART...
Your problem is a bearing of inner tub may also need spider assembly caused by overloading using non HE detergent 0r to much soap if noise gets worst it will take out seal and will start leaking thru-back side under stater motor that you call generator
Remove stater drum by holding inner drum and taking rear nut of stater drum after removing drum UN plug wire connections remove 4 bolts holding coil . then remove front of washer remove all counter waits remove all bolts from outer tub remove shocks remove springs and drain and vent hoses pull out the whole basket from unit pull tub in half remove inner tube Pop out both bearings back and front replace with new bearing and seal reverse back together same way you take apart may take 2 people heavy stuff
Oct 25, 2013 | LG WD-15517RD Front Loading Steam...
Washer has begun to sound like a four wheel drive vehicle going down the highway at 60 mph. The matching dryer had been squeaking and now has begun a thumping sound.
if it sounds like a jet plane taking off its the drum bearings and you need to replace these bearings,if your lucky you can find just the bearings and lip-seal,if not you will need to but the tub with the front bearing installed already and this gets expensive,otherwise to just replace these bearings and seal alone its about $500.00 to $900.00do it soon as the longer you wait the more labor intensive it gets
Aug 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Agitator drum is loose and making loud knocking noise
Hope this helps..The bearing has been worn out already connecting the drum..The washer might be too old or has been used frequently loading what is more than sufficient.loading excess more than its capacity..
Jun 19, 2011 | Frigidaire GLTF1670A Front Load Washer
I have a magic chef 20 lb capacity heavy duty washer model W20HN3S serial ME851474 with spin problems. Clothes come out soaking wet. Can I replace a belt?
If your washer will wash (agitate) your clothes but does not spin well, you will need to replace the "thrust bearing" in the washer. The repair is simple and will only take you a short to do. Here is a link to the "thrust bearing kit" you will need.
Jan 07, 2011 | Chef Cooking Magic Chef Washing Machine...
We have a very old Kenmore Heavy Duty 80 series washer and dryer. I have a 2 part question. 1.our dryer recently began stopping after a minute or so after turning it on. When you push the start button, it...
That growl is the motor bearing. The replacement is not difficult. The blower is reversed threads. I have repair photos HERE
The washer is an 18 pound (dry weight) capacity
Feb 15, 2010 | Dryers
Drum bearings need replaced
you can try to replace just the bearings yourself .. big job but if you want to do it check out tonytool.
you can replace the entire drum assembly with bearings already in but the parts alone are over $500.
I have the same problem and will buy a new washer !
Jul 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Replace bearing
You can try a puller but typically it is recommended to replace the entire rear outer tub half (which comes with the bearings already pressed into it). You will also need the tub seal that goes between the front and rear tub halves. Hope this helps.
Dec 02, 2008 | LG WM-1832C Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
321 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
