Question about Sony Ericsson Walkman W810i Cellular Phone
Hellllllp i cannot use my w810i because the "*" key "0" key "#" cancel bubtton and the select button is not working, what should i do??????????
You should contact your operator or replace the phone and get a refund because your phone seems to be broken.
Posted on Oct 25, 2008
What is the calibrating code of toshiba e studio 2303a
(1)While pressing [0] and [5] simultaneously, turn the power ON. ? Adjustment Mode
(2) [SETTINGS] ? [USER FUNCTIONS] ? Select [DRAWER] ? Select [DRAWER1] ? Set the paper size to A4/LT. ? [OK] ? Set A4/LT for the paper in upper drawer.
(3) [CANCEL] ? [CANCEL] ? [SETTINGS] (Return to code entry screen.)
? [10]? [SETTINGS]? [START] (A gamma adjustment patch chart is printed out.)
(4)Place the patch chart for adjustment printed in step (3) face down on the original glass. Place the chart aligning its black side of the gradation pattern against the original scale.
(5)Key in a code "7165" and press the [START] button.
(6)If process finishes successfully, select "Yes" and press the [OK] button to apply the adjustments. (To cancel the reflection of adjustment results, press the [CANCEL] button.) In the case of an abnormal ending, "Error" is shown.
Press the [CANCEL] button to clear the error display. Next, confirm that the patch chart is oriented correctly on the platen and not at an angle, then do the process from step (4) again.
(7)Press [20] ? Press [SETTINGS] ? Press [START].
Notes:
•Compare with chart output in step (3), there should be no differences in patterns and no faint colors.
(8)Place the patch chart for adjustment printed in step (7) face down on the original glass. Place the chart aligning its black side of the gradation pattern against the original scale.
(9)Key in a code "7167" and press the [START] button.
(10)If process finishes successfully, select "Yes" and press the [OK] button to apply the adjustments. (To cancel the reflection of adjustment results, press the [CANCEL] button.)
In the case of an abnormal ending, "Error" is shown. Press the [CANCEL] button to clear the error display. Next, confirm that the patch chart is oriented correctly on the platen and not at an angle, then do the process from step (9) again.
(11)Turn the power OFF.
Sep 04, 2016 | Toshiba Office Equipment & Supplies
Tip
Waste ink full on Canon ip2000 series, and service mode
<Service mode operation procedures>
1) With the front cover closed, and the printer power turned off, while pressing the Resume/Cancel
button, press and hold the Power button. (DO NOT release the buttons. The LED lights in green
to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the
Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release
both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed,
the LED lights alternately in orange and green, starting with orange.) During initial operations,
the LED blinks in green.
4) When the LED light sin green, press the Resume/Cancel button the specified number of time(s)
according to the function listed in the table below. (Each time the Resume/Cancel button is
pressed, the LED lights alternately in orange and green, starting with orange.)
Time(s) LED Function Remarks
0 times Green Power off When the print head is not installed, the
carriage returns and locks in the home
position.
1 time Orange Service test print
2 times Green EEPROM information print
3 times Orange EEPROM initialization
4 times Green Waste ink counter resetting Proceed to the step 5), and follow the
Waste ink counter reset procedures.
5 times Orange Destination settings Proceed to the step 5), and following the
Destination settings procedures.
6 times Green Print head deep cleaning
7 to 9 times Orange Not used in servicing
10 times Green Return to the menu selection
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu
In the waste ink counter resetting mode, press the Resume/Cancel button the specified number of
time(s) according to the ink counter reset value listed in the table below, and press the Power button.
Time(s) LED Waste ink counter value
0 times Green Reset the main waste ink counter (0%).
1 time Orang
e
Reset the platen waste ink counter (0%)
2 times Green Re-set the main waste ink counter value to 50%.
<Destination settings procedures>
In the destination settings mode, press the Resume/Cancel button the specified number of time(s)
according to the destination listed in the table below, and press the Power button.
Time(s) LED Destination
0 times Green No change
1 time Orang
e
Japan
2 times Green Other than Japan (A4)
3 times Orang
e
Other than Japan (LTR)
on Jun 30, 2010 | Canon PIXMA iP2000 InkJet Printer
.error 1700 says waste ink absorber nearly
(In waste ink absorber replacement, perform
the EEPROM information print to identify if the main and/or platen
waste ink absorber should be replaced. After replacement, reset
the applicable waste ink counter(s).)
Waste ink counter reset See “Service mode operation
procedures” below.
The following 3 methods are available:
- Resetting the main waste ink counter (0%)
- Re-setting the main waste ink counter
value to 50%
- Resetting the platen waste ink counter
(0%)
Power button.)
position.
selection mode automatically.)
<Waste ink counter reset procedures>
1 time Orang
e
1 time Orang
e
Japan
3 times Orang
e
Other than Japan ltr
Jun 24, 2010 | Canon Office Equipment & Supplies
Hello - My Canon Pixma iP2000 won't print anymore as I get a dialogue box advising me that the ink absorber is full. How do I remedy this? Heather Knittel goodriddance@telus.net
Power button.)
position.
1 time Orang
e
Jun 23, 2010 | Canon PIXMA iP2000 InkJet Printer
Cancel auto-answer
Uh oh. Here we go. The first command is PROGRAM 21x, where x is 0 for Ring but the button controls, 1 for Voice, and 2 for Ring Only. It's programmed by PROG 21 STORE use the auto answer button to step between settings, then STORE again. The next one is 23. It can force Auto Answer and is normally set to OFF by default.
There are also soft keys and the Navigator button ENTER that make this easier. I have a 7735 phone on a TAW which has a similar instruction set so I don't have the soft keys you have. I guess one of them is SEL for select to replace the Auto ANS button in the above instructions.
Carl
Dec 18, 2009 | Panasonic KX-T7633 Corded Phone
I REPLACED MY TONER COLLECTION Minolta d520
Press Utility key and press in this order STOP-0-STOP-0-0-1,select COUNTER windows,select waste toner windows: for SET press C(cancel 10 keys pad) introduction 320000; for Counter press C.press Exit too quit,back the basic menu.
Feb 27, 2009 | Minolta DiALTA Di520 Laser Printer
Ink waste absorber
Try this:
Reset Waste Ink
1) Enter SERVICE MODE.
By pressing Menu, Copy, Scan, Copy, Copy
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [Set] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Not sure if it will work on your printer but worth a try
Jun 30, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Sony-Ericsson: Bluetooth Remote Control Navi Key Assignment
the bloothtooth remote conrol doesn't work properly on any sony erricson
Mar 14, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Sony Ericsson Walkman W810i Cellular Phone Logo
19 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
