Sound cut Pls I am also finding it difficult to use my earphone port. It will cut the sound from the speakers and not produce sound from the earphone.
  • 063-Oz Oct 22, 2008
    My earphone is working perfectly and I even the change the board house the port and still had the same problem
    Problem Solver:
  • 10 Answers
Is your ear phone damaged.......or not working....
Posted on Oct 21, 2008
How to fix coby cv320 headphones
If you hear sounds from only one earphone then most likely there is a broken wire to the earphone that is not producing a sound.
It is difficult to determine exactly where the wire is broken and repair. I suggest you get a new earphone.
Jul 12, 2012 | Audio Players & Recorders
Hi. Greetings. I have one of this set. One day while i'm playing songs on it, my siblings accidentally plugged another wire into the earphone port. When i unplugged it, there isn't anymore sound...
Put a plug in the earphone port and wiggle it . Could be the little gadget inside is stuck. I had a tv that did that and ended up disconnecting the ear plug port.
Sep 21, 2017 | Altec Lansing VS4121 Computer Speakers
No sound but reading discs
Every one enjoys listening to music . When CD player stops doing its job we take it to a repair shop. But before doing that we can try out few simple ways to troubleshooting CD player which may save us from paying huge amount for repair.
Troubleshooting involving diagnosis and then fixing it by finding the cause for the problem. First step involves focusing on a specific problematic area . Next step would be to check if the connections are proper and the last step is to troubleshoot. Let us look at each step in detail..
You can start by checking the earphone port,By using an earphone jack,inserting into the earphone port...If no sound comes out from it, that means it's not from the speaker, but from the board of the radio.The sound IC has is damaged and will need to be replaced..
To fix these,you might need to contact a repair man.
But, if sound comes out from the earphone jack, That means it's a minor case,it will be a problem from the speaker of the Mini Disc Player.
Checking the speaker connection..You might need to open up the speaker
Test the speaker by using a AA battery with small wires on the positive and negative side of the speaker. If sound comes out,that means i wire has cut or remove from somewhere inside the speaker, But if still no sound coming out,That means will go back to IC on the bard of the radio..
Keep me posted when your done checking..
Thanks for using fixya
Aug 07, 2011 | Sony MDS-JE330 Mini Disc Player
The earphone jack connection produces sound in only one ear. Partially with drawing the jack produces sound in both ears. Clearly, the jack is not making a good connection once inside its 'port'.
This is usually the result of faulty earphones. Try replacing the earphones you are using with the ipod and it should work normally.
Good Luck!
Jan 13, 2011 | Apple iPod nano
Connect Logitech 2.1 to TV
i dont know how ur tv does not have a earphone jack i wonder now a days how they make such tv's , pls try to take sound from audio LR if it helps other wise no hope to get sound on speakers sorry pls try to find in manual if there is any hidden headphone jack some where see in manual
Feb 25, 2009 | Logitech X-530 Computer Speakers
I have no sound on my HP Pavillion laptop
I had the same problem, but now its solved!
Brieftly speaking, my internal speaker stopped producing sound, but when I plug earphones in, there is sound in the earphones.
Just plug in-and-out ur earphones several times (it took me 5 tries) and voila internal speakers work again!
I think there is a mechanical sensor inside the sound output (plug for the earphone) so that once it senses a plug getting in, it shuts internal speaker.
Maybe the mechanical sensor was jammed (spring problem i guess) and it still believe that u have ur earphones plugged-in. "Clogging" the hole for the earphones would allow the spring to spring back to initial position...
Hope it helps
Jan 13, 2009 | HP Pavilion dv9000z Notebook
I need your help
We can't call HP for you. You will have to do it. They also most likely didn't record the Key before shipping the laptop. If the product key is not on your laptop then you may need to purchase another copy of Vista.
Oct 21, 2008 | Compaq Presario C552US Notebook PC
Right part of the earphone is not working
THE RIGHT SPEAKER OF YOUR EARPHONE HAVE TO BE CHANGED
Aug 08, 2008 | Radio Communications
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
